CamDuy Posted July 24 Posted July 24 (edited) Hello everyone, I've just finished developing MPL (Multi Plot Layout/Model), a free AutoLISP tool that helps you batch print drawings in AutoCAD. Main Features MPL includes all the essential functions found in other batch plotting LISP tools, plus several improvements: Smart and intuitive DCL interface Merge all plots into a single PDF (no additional software or virtual PDF printer required) Automatically open the output file or folder after plotting, with customizable file name and save location Zone-based plotting – organize messy drawings and print them in the correct order based on defined zones Batch plot multiple layouts – rearrange the printing order of layout tabs without dragging the tabs at the bottom of AutoCAD Print Preview mode Add Selection feature – easily add more drawings to the current print list without starting over Export/Import plot configuration for quick reuse Download and user guide: https://drive.google.com/drive/folders/1WwmkXVgHFWTy8zIhARJYCH_G2OC2A_3D?usp=sharing Feel free to download it, give it a try, and let me know your feedback. Your suggestions will help improve MPL even further! Update for the BatchPlot.exe installation version. Free download: https://drive.google.com/drive/folders/16RZS69S2tzZZzFnYW0H6QNQ3klwxB2C6?usp=drive_link Edited 1 hour ago by CamDuy 3 Quote
rlx Posted July 24 Posted July 24 (edited) Welcome to CadTutor CamDuy and thank you for sharing your program, looks like you put a lot of effort in this. The world (and this site) needs more people like you Edited July 24 by rlx ps. MPL or CAMDUY not working 1 Quote
CamDuy Posted July 24 Author Posted July 24 (edited) download: https://www.vedacad.com/ type code: A7CEHQ Drawing test MPL: https://drive.google.com/file/d/1WgMLRDxaiLchbshI3o_f3WHrV7rHX03e/view?usp=sharing AutoCAD: https://shrinkme.click/Multi_Plot_MPL BricsCAD: https://shrinkme.click/Multi_Plot_MPL_BricsCAD ZwCAD: https://shrinkme.click/Multi_Plot_MPL_ZwCAD Edited September 15 by CamDuy 1 Quote
VicoWang Posted July 29 Posted July 29 I tried using it with VedaCAD, and it didn't work in 2014 but ran perfectly in 2022. I thought it was a problem with the VedaCAD proxy, so I loaded the VLX file from the cache separately, and it still didn't work in 2014 but could run in 2022. Does this plugin have a minimum version requirement? Quote
Nikon Posted July 29 Posted July 29 On 7/25/2026 at 1:56 AM, CamDuy said: AutoCAD: https://shrinkme.click/Multi_Plot_MPL The link doesn't work for me, could you please attach the archive? Quote
CamDuy Posted July 29 Author Posted July 29 3 hours ago, VicoWang said: I tried using it with VedaCAD, and it didn't work in 2014 but ran perfectly in 2022. I thought it was a problem with the VedaCAD proxy, so I loaded the VLX file from the cache separately, and it still didn't work in 2014 but could run in 2022. Does this plugin have a minimum version requirement? I think AutoCAD 2014 is too old; versions from 2015 onwards work just fine. because it was built on a higher version. Quote
CamDuy Posted July 29 Author Posted July 29 12 minutes ago, Nikon said: The link doesn't work for me, could you please attach the archive? Drop me an email "phantrongduybn@gmail.com" I'll send it to you. Quote
VicoWang Posted July 29 Posted July 29 1 minute ago, CamDuy said: I think AutoCAD 2014 is too old; versions from 2015 onwards work just fine. because it was built on a higher version. When I develop vedacad, it is different. My main coding and compilation are done on 2006, avoiding the use of advanced features and ensuring that vedacad can punch through all versions of 2026 from 2006. However, it is true that most people have already done their daily work on the higher version. My test environment is 2006,2014 and 2022. Quote
CamDuy Posted July 29 Author Posted July 29 1 minute ago, VicoWang said: When I develop vedacad, it is different. My main coding and compilation are done on 2006, avoiding the use of advanced features and ensuring that vedacad can punch through all versions of 2026 from 2006. However, it is true that most people have already done their daily work on the higher version. My test environment is 2006,2014 and 2022. Thank you for your feedback. I will update the version for 2014 and earlier. Quote
BIGAL Posted July 30 Posted July 30 Just a comment one option I did not see is a plot range I have a simple plot lisp it asks for start layout and end layout handy to plot one or more. Perhaps even 1-2,7-8,12 plots multiple layouts as suggested. Also what about Bricscad version it has BRX not ARX. Quote
CamDuy Posted August 5 Author Posted August 5 https://www.cadviet.com/forum/index.php?app=forums&module=forums&controller=topic&id=213313 1 Quote
HypnoS Posted August 13 Posted August 13 Hi, you've created a very cool tool. I admit I've been looking for something like this for some time. However, I'm wondering if it's possible to print drawings of different dimensions to PDF? For example, I have a .dwg file with drawings measuring 297x1110mm or 594x930mm. The overall dimensions vary. I print them from paper rolls with widths of 297mm, 420mm, 594mm, and 841mm, but the lengths vary. I'd like the program to automatically detect the frame dimensions and adjust the PDF dimensions. Is this possible? Quote
BIGAL Posted August 13 Posted August 13 @HypnoS if your using title blocks then it is possible to detect the name of the title block and use the correct plot settings, for example a A4 in landscape or portrait mode. Just using say layout extents can return wrong answers as even where I worked there was occasional junk in a layout outside of the title block. 2 Quote
CamDuy Posted August 21 Author Posted August 21 2026/08/18 - Version V13: Added Custom Name and Draw Temp Layout features Link Drive: https://drive.google.com/file/d/1McaDZI-gqSdi3zAdaHNu5LQ14_2JsDOj/view?usp=sharing Quote
Nikon Posted August 21 Posted August 21 (edited) 1 hour ago, CamDuy said: 2026/08/18 - Version V13: Added Custom Name and Draw Temp Layout features Link Drive: https://drive.google.com/file/d/1McaDZI-gqSdi3zAdaHNu5LQ14_2JsDOj/view?usp=sharing The code doesn’t work (Autocad 2021 localized ) command: MPL Unknown command "MPL" Edited August 21 by Nikon Quote
CamDuy Posted August 21 Author Posted August 21 1 hour ago, Nikon said: The code doesn’t work (Autocad 2021 localized ) command: MPL Unknown command "MPL" I am still using it with AutoCAD 2021. Quote
HypnoS Posted August 26 Posted August 26 (edited) @CamDuy Would your program be able to create a pdfs with such dimensions? or even higher? The problem is that each one has a different length and some kind of dimension detection would be useful. Edited August 26 by HypnoS Quote
BIGAL Posted August 26 Posted August 26 (edited) Provided you have made custom sheet sizes in the PLOT dialog. There is no reason why you can not have a title block or rectangle that is used to define the sheet size. Wether it be PDF or plot direct to roll plotter. Using layouts is best as the overall size will be at 1:1 eg 297x2010. Basically the custom size must exist, There was a post about making custom sheet sizes on the fly but very difficult to achieve. Me like a lot of others here can read the layouts and plot, there is plenty of examples of plot lisp's. Edited August 26 by BIGAL 1 Quote
CamDuy Posted August 27 Author Posted August 27 Update for the BatchPlot.exe installation version. Free Download: https://drive.google.com/drive/folders/16RZS69S2tzZZzFnYW0H6QNQ3klwxB2C6?usp=drive_link Quote
symoin Posted August 28 Posted August 28 Can this be modified to include the hyperlinks, like that of publish command in autocad? Quote
