CamDuy Posted August 29 Author Posted August 29 7 hours ago, symoin said: Can this be modified to include the hyperlinks, like that of publish command in autocad? https://drive.google.com/drive/folders/1RW3VS_e2hrR0-L4AcJnErnl0MR6DnZFp?usp=sharing When using this version, check the "Merge PDF" box to print in "Publish" mode. Quote
CamDuy Posted 17 hours ago Author Posted 17 hours ago On 8/29/2026 at 2:49 AM, symoin said: Can this be modified to include the hyperlinks, like that of publish command in autocad? Merging PDFs is equivalent to publishing. Quote
CamDuy Posted 17 hours ago Author Posted 17 hours ago - Update to the latest .exe (Add number of copies, add collate) https://drive.google.com/file/d/1FmN_TQNTGGzTXQojuRLd9H4SdH-Hqbov/view?usp=sharing - Update the LISP file. (Update the DCL interface) https://drive.google.com/file/d/1RDGjsKS0RruitLW83pHWcwq74ygik3wu/view?usp=sharing Quote
zaphod Posted 16 hours ago Posted 16 hours ago Looks neat, but is there any way to run/test it without the custom install? The IT department has us locked away from that type of thing. Quote
CamDuy Posted 8 hours ago Author Posted 8 hours ago (edited) 15 hours ago, zaphod said: Looks neat, but is there any way to run/test it without the custom install? The IT department has us locked away from that type of thing. Portable Version Download: https://drive.google.com/file/d/1PEI9H3FrJosMIUunhefGpuIUOMdsqf8Z/view?usp=sharing Run DwgToPdfPro.exe Edited 41 minutes ago by CamDuy Quote
zaphod Posted 54 minutes ago Posted 54 minutes ago when I looked in the zip folder it was empty, extracting it brought up this message. Quote
CamDuy Posted 40 minutes ago Author Posted 40 minutes ago 13 minutes ago, zaphod said: when I looked in the zip folder it was empty, extracting it brought up this message. Try again :https://drive.google.com/file/d/1PEI9H3FrJosMIUunhefGpuIUOMdsqf8Z/view?usp=sharing Quote
