I don't know if there was ever another LISP/Program to do this type of get length at least I never found one, my original just did what I needed, I have since made it more generally useful (I hope).
As per the drawing I will attach, I just need to get the length of the center between the inner and outer of the perimeter of guards, etc. to determine the unrolled length.
Normally the guards are 3D and I create the profiles with SOLPROF which creates an anonymous block (I used to change these with UNANON) or sometimes in the past I have used SOLVIEW and SOLDRAW, the same issue arises that you just can't select them and get the profile length.
So originally that's what this LISP was created to do (I still have some of the older basic versions).
I have upgraded it to it's current state and also still working on another version, but only small enhancements.
For inside a block that is scaled, you will need to multiply the results by the scale factor, working through a viewport the viewport needs to be active, so I might tackle those issues as well as make a more detailed CSV. I also will try to make sure it works in non-AutoCAD like BricsCAD, CMS IntelliCAD, nanoCAD, etc. when I get time.
I lightly tested in most situations, I have no idea how it acts on non-uniformly scaled blocks, though.
It handles gaps and slight overlaps, I have some settings at the top, hopefully with enough instructions to modify on your own.
Where I work (except for the machine shop which uses decimal inches) they use Architectural units, I did not double check this in Metric, so if someone would report back on that it would help.
GetLenTest.dwg
GetLen.lsp
  • Thanks 1
@SLW210 did a little bit of testing and works ok in Metric dwt. The only thing is the Architectural result.
Limited Testing in Bricscad V25. made some shapes and inserted some blocks.
A rectang 5000x4000 mm or decimal units. For metric don't need Architectural units.
Curve length: 18000
Gaps: 0
Total: 18000
Architectural: 1500'-0" ??
For metric could do dwg is in mm but result is in metres to 3 decimals. You could use the Multi radio buttons.lsp to make choices. As its demand loaded you do not have to add it to your code.
Re CSV your more than welcome to use the defuns in Alan Excel.lsp to write direct to Excel. Could demand load a lisp with just the defuns needed as don't need all that is in the lisp.
Just a Ps a big file to screen copy maybe also post a file copy.
  • Thanks 1
Somebody else can add the Multi, it works great for my job right now.
I do not want direct to Excel as I plan to use LibreOffice when away from work, in the beginning of updating I had thoughts of making it an option, that is still on the table.
I may remove the code and just paste the file, so at least a sign-in is required. As for a long code to copy, just double-click the first character then shift-click the end.
As for the Architectural: 1500'-0", you didn't change the values in the code to convert to mm, I put them at the top.
Quote
PROFILE 1
Block scale: 1.00000000
Objects traced: 1
  LWPOLYLINE  Handle=275  Length=18000.000000
Curve length: 18000.000000
Gaps: 0.000000
Total: 18000.000000
Architectural: 59'-5/8"
I need to do a few changes on that output when metric, I'll see if the next version was already doing that.
That's the reason I posted this version, to see what I didn't think of before the final version.
I think I started the next version to include a DCL to switch instead of commandline as well as the report, as well as multiple selections and more columns in CSV.
Is there a big need for meters in something like this?
I know in the USA sheet metal is normally Metric in mm and Imperial is inches, sometimes on certain things they use Meters and Architectural, but I have seldom seen that.
I do need to add the inches option as well, so Meters should be an option I suppose.
I need to do more gap and overlap testing, most of my actual job is actually ends touching, I just needed to get them through a Viewport and in an anonymous block (I used to need to change to a regular block, then go to block editor, etc.), SOLPROF is lines and arcs, etc. so a lot of work .
I'll finish up my work work and see if I have time to work on this some more.
Thanks for the Metric test and BricsCAD test.
If any GstarCAD, NanoCAD, CMS IntelliCAD users could test, that would be nice. I go over their sites and see if I can see what users report working and not working, but that probably doesn't cover everything or account for those that just made an error using the code.
For USA that use both Metric and Imperial, would reporting both be beneficial? That might yet again be more options needed.
P.S. My 3 grandkids from near me in Florida are now in Australia until the End of October, so last night my time they Facetimed me, so I got very little done at home.
Yes outputting results as both may be the simplest way.
Re make a dcl, I use say multi radio buttons.lsp as it only needs 3 lines of code to work, you comment out the vla-deletefile, so the dcl code remains, I then use the RLX convert dcl to lisp so paste the converted code into my programs, using the multi just saves typing to make the source dcl. Just another comment, I have a make a radio button dcl from a dwg. RLX was looking into doing similar.
I have code also for Libreoffice Calc reading and writing plus more. Happy to post. Opening is not as straight forward as Excel.
Where are the grand kids ? I am north of Sydney.
Convert dcl 2 lisp rlx.lsp
Edited by BIGAL
  • Thanks 1
I have all of that from you and @rlx, thanks though, I have a DCL built for this already, I made it a little fancy with the options, I might go simpler though.
I made some improvements to the Metric side. When I have time I'll get it cleaned up and on here.
I was thinking about instead of the commandline having the results in a DCL on screen and put options to make the CSV, Excel, Print, etc., though that will be when I have time.
I am not sure how many actually would have use of this, but I plan to get it finished hopefully this week, hopefully I can wrap up my CAD work and get back on this.
My grandkids are in a small town 268 km (167 mi) NE of Melbourne just into New South Wales and a little ways west of Lake Hume and 457 km (284 mi) SW of Sydney.
I hate the time difference, but not too bad, they wake up when I'm eating supper or going to bed, they are getting ready for bed when I am getting to work.
Post that, I was working on some of that from the thread a while back, but do not remember how far I went.
Here is libreoffice code. Hopefully it is the correct one.
Re display answers. The simplest is use Alert just add the "\n" in string for multi lines. Yes can do a dcl its made up of text paragraphs. And message boxes as last idea.
(alert "This is line one\nline 2\nline 3")
; make text dcl from list
; By Alan H july 2026
(defun AHmakepara (lst / fo x dcl_id)
  (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
  (write-line "AHpara: dialog {" fo)
  (write-line (strcat "	label = " (chr 34) "Current values" (chr 34) "  ;") fo)
  (write-line " : column {" fo)
  (write-line " width =25;" fo)
  (write-line " : paragraph {" fo)
  (setq x 0)
  (repeat (length lst)
    (write-line " : text_part {" fo)
    (write-line (strcat "label = " (chr 34)  (nth x lst) (chr 34) ";") fo)
	(setq x (1+ x))
    (write-line " }" fo)
  (write-line "spacer_1 ;" fo)
  (write-line "ok_cancel ; }" fo)
  (close fo)
  (setq dcl_id (load_dialog fname))
  (if (not (new_dialog "AHpara" dcl_id))
    (exit)
  (action_tile "accept" "(setq ans 1)(done_dialog)")
  (action_tile "cancel" "(setq ans 2)(done_dialog)")
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete fname)
  (princ ans)
; (if (not AHmakepara)(load "Multi para.lsp"))
; (setq lst (list "This is line 1 " "this is line 2" "line 3" "A big line 4 like this"))
; (AHmakepara lst)
; this allows for a time so message closes.
(defun MsgBox (title options message time / WshShell)
   (setq WshShell (vlax-create-object "WScript.Shell"))
    (vlax-invoke WshShell 'Run
	 (strcat "mshta.exe vbscript:close(CreateObject(\"WScript.Shell\").Popup(\""
		  message "\"," (itoa time) ",\"" title "\"," (itoa options)"))"
   (vlax-release-object WshShell)
(MsgBox "this is me" 0 "have a good day" 1) ; pretty sure can do multi line, using \n or \r ?
libre2.lsp
