Another tip if your setting multiple variables. You can handle them with 4 lines of code.
(defun C:lnze (/ lyt)
  ;(setq oldEcho (getvar "CMDECHO")
  ;      oldNOMUTT (getvar "NOMUTT")
  ;      lyt (getvar "CTAB")
  (setq vars '(cmdecho nomutt ctab)  ;list of variables as many as you want.
        vals (mapcar 'getvar vars)   ;store old values to a list
  ;(setvar 'CMDECHO 0)
  ;(setvar 'NOMUTT 1)
  (mapcar 'setvar vars '(0 1))  ;this sets cmdecho 0 and nomutt 1, stops at short list so ctab isn't changed.
  (vl-catch-all-apply
    '(lambda ()
      (foreach lay (layoutlist)
        (setvar 'CTAB lay)
        (setvar 'CVPORT 1)
        (vl-cmdf "_.ZOOM" "_E")
  ;(setvar "CTAB" lyt)
  ;(setvar "CMDECHO" oldEcho)
  ;(setvar "NOMUTT" oldNOMUTT)
  (mapcar 'setvar vars vals)  ;restore old values
38 minutes ago, ronjonp said:
Side topic but I've found that this:
(setq ss (ssget "_X" '((0 . "VIEWPORT") (-4 . "!=") (69 . 1))))
Does not work with layouts that are not initialized.
CAB at TheSwamp put this together many moons ago and it's been solid ( don't remember what the function was originally named 😳)
(defun rjp-getvports (/ a b c lst ss)
  (if (setq ss (ssget "_X" '((0 . "VIEWPORT"))))
    (progn (foreach e (mapcar 'cadr (ssnamex ss))
	     ;;Paper space block
	     (if (and (setq a (cdr (assoc 330 (entget e))))
		      ;;Layout
		      (setq b (cdr (assoc 340 (entget a))))
		      ;;Viewport not wanted
		      (setq c (cdr (assoc 331 (entget b))))
	       (or (equal c e) (setq lst (cons (list e (cdr (assoc 71 (entget b)))) lst)))
  ;;Sort the list by taborder L 2 R
  (mapcar 'car (vl-sort lst (function (lambda (x y) (< (cadr x) (cadr y))))))
@ronjonp  When I first open the sample TrueViewports.dwg I shared in a previous post which defaults to Layout2 and I run (length (rjp-getvports)) I get 7. Even after initializing by clicking on Layout1. I still get 7.
But after clicking on Layout2 when I run @DavidP code I get 6:
(sslength(setq ss (ssget "_X" '((0 . "VIEWPORT") (-4 . "<>") (69 . 1) (410 . "~Model")))))
Likewise when I run my code I posted earlier I also get 6:
(sslength (ssget "_X" '((0 . "VIEWPORT") (67 . 1) (-4 . "/=") (69 . 1))))
I think mine & @DavidP code is similar. But what I don't see is whether @DavidP code is filtering out something more than compared to mine.
Just a comment using Bricscad only finds.
D05
returns 4
D03 = 4
D05
(sslength (setq ss (ssget "_X" (list (cons 0  "VIEWPORT") (cons 410 (getvar 'ctab))))))
returns 1 ie no normal viewports
D03 = 2 a pspace and 1 viewport
 The order of SS is Viewport...Viewport Pspace may be different in Acad. I copied viewports for testing. Then erased one by one using (ssname ss X) can not erase pspace of course.
 I assuming "<>" and "/n" filter produce the same result as they both mean "not equal" (assuming lisp supports both syntax)
Filter  410 . "~Model" may depend whether you have model space view ports or not. If you omit it and have no view ports in model space then the result should be the same.
Regarding the codes I don't believe they are consistent,  I did notice if its off screen we get  -1 but not always but  I haven't done enough testing to come to a conclusion.
Looping through the layouts is the only thing I found that makes the codes predictable.
I may test in BricsCad the morning to see how it behaves (if it supports the code as is).
FYI: my (67 . 1) filters out model space vports so only paper space vports will be selected.
BricsCAD reports the correct number of view-ports without requiring looping through the layouts first.
I have a Zoom Extents in Modelspace and Zooms Extents, then .9x in all layouts, it helps with the offset AutoCAD puts on some drawings when opening them, plus works for finding odd paperspace items, zooms just a little more to show the edges.
Still trying to determine what is wrong with Lee Mac VPOUTLINE LISP?
Are you looking for a count of true viewports?
I have a LISP that gives this report of true viewports in all layouts, as well as places a border in modelspace and creates/checks for my viewport layer.
          AutoVPBrdr REPORT
True layout viewports: 5
Viewport layer assignments: 5
Layer assignment failures: 0
Modelspace borders created: 5
Viewports skipped: 0
Layer: Viewport
Color: 45
Plot: OFF
It only places a border for a viewport referencing  Top/Plan view.
  • Thanks 1
Yeah fig so just left 410 in there to be safe.
Edited by mhupp
Here's another without command calls:
(defun c:zal (/ a d c tabs)
  ;; RJP » 2020-07-08
  (setq c (getvar 'ctab))
  (vlax-for x (vla-get-layouts (setq d (vla-get-activedocument (setq a (vlax-get-acad-object)))))
    (setq tabs (cons (list (vla-get-name x) (vla-get-taborder x)) tabs))
  ;; The sort makes sure that the tabs step left to right
  (foreach x (cdr (vl-sort tabs '(lambda (r j) (< (cadr r) (cadr j)))))
    (setvar 'ctab (car x))
    (vlax-put d 'mspace 0)
    (vla-zoomextents a)
  (setvar 'ctab c)
  • Like 3
These are ones I use:
To record the current zoom:
(setq currentzoom (list (getvar 'viewctr) (getvar 'viewsize)))
.. zoom as you want
And this returns you to where you were.
(vla-ZoomCenter (vlax-get-acad-object) (vlax-3d-point (car currentzoom)) (cadr currentzoom))
Never tried with viewports but some ssget types need the entities to be selected to be in view, maybe viewports are the same
  • Like 2
Here is my latest zoom .9x in all layouts.
I hadn't noticed the OP posted a .dwg, so i ran my Viewport Border into Model code on it.
Is the result you wanted?
          AutoVPBrdr REPORT
True layout viewports: 4
Viewport layer assignments: 4
Modelspace borders created: 3
Viewports skipped: 1
Layer: Viewport
Color: 45
Plot: OFF
ZE_Z9XP_1.1.lsp
@DavidP @mhupp as they say...there's more than one way to skin a cat... either with 67 or 410 or go crazy and do both 67 & 410...but the result is the same: vports from Model are filtered out
Edited by Paul Li
Like @SLW210 I had a move the title block in layouts to 0,0 and then zoom extents, had one user that would move the title block as it was the way he liked to draft. We had auto plot layouts so was part of our company standard to have title at 0,0.
On 10/29/2026 at 1:44 PM, DavidP said:
I added some prompt suppression...
(defun DP:llnze (/ lyt)
        lyt (getvar "CTAB")
  (setvar "CMDECHO" 0)
  (setvar "NOMUTT" 1)
  (vl-catch-all-apply
    '(lambda ()
        (setvar "CTAB" lay)
        (setvar "CVPORT" 1)
  (setvar "CTAB" lyt)
FYI, Your code works fine in your sample dwg because as you loop through each layout the space is already set in pspace. But the code fails when it encounters a layout with a vport set in mspace.
The following revised loop segment code accommodates for this:
(vl-catch-all-apply
    '(lambda ()
        (setvar "CTAB" lay)
;        (setvar "CVPORT" 1) ; this will error out if in mspace
        (setq cvport (getvar "cvport")) ; save current psace vport #
        (if (> 1 cvport) ; chk if in mspace
         (progn ; then
          (vl-cmdf "_.Pspace" "_.ZOOM" "_E" "_.Mspace") ; goto pspace then zoom extent and return to mspace
          (setvar "cvport" cvport) ; return to mspace of original vport #
         (vl-cmdf "_.ZOOM" "_E") ; else just zoom extent in pspace
		) ; if
      ) ; foreach
    ) ; lambda
i cannot replicate this. When i first open TrueViewports.dwg "Layout2" is already initialized.
Without initializing "Layout1" Running
-> i get 7
But running
-> i get 6
so at least for me on this test drawing file @ronjonps code seems to work without initializing the layouts.
