Automated tool for converting unreferenced AutoCAD DWGs to georeferenced GIS Shapefiles in 12s
Hello CADTutor community,
As someone working with civil engineering infrastructure datasets, one of the most frustrating bottlenecks has always been data migration from AutoCAD into GIS environments (QGIS, ArcGIS, PostGIS).
Often, drawings received from subcontractors sit at arbitrary (0,0) origins with zero projection metadata, line layers lack topology, and pipe invert tags are trapped as plain CAD text.
To tackle this, we developed a tool called GeoMorph AI (https://propertyrock.in) that automates the extraction and georeferencing pipeline in ~12 seconds:
Key Features:
- Direct Ingestion: Parses raw DWG/DXF layers, text tags, and invert levels using Python ezdxf.
- Autonomous Coordinate Alignment: Pattern-matches local CAD layout features to real-world WGS84/UTM coordinates without manual rubber-sheeting.
- Topology Rebuilding: Converts unjoined polylines into clean network topology for water/sewer/telecom lines while preserving diameters and depths.
- Multi-Format Export: ESRI Shapefile bundle (.shp, .shx, .dbf, .prj), GeoPackage (.gpkg), GeoJSON, and direct PostGIS 3.4 database sync.
- 3D WebGL Map: Interactive browser viewer for instant visual quality control.
▶️ 1-Minute Video Demonstration:
https://youtu.be/V9LtA6QLPz0
We would genuinely appreciate thoughts and critique from draftsmen and CAD managers:
- What edge cases (e.g. 3D solids, complex dynamic blocks, splines) usually break your exports into GIS?
- How does your current workflow handle local grid to national projection transformations?
If anyone has a sample tricky DWG they would like to test, feel free to share or test it directly on the platform!
Best regards,
Pramod Kumar
Is this for AutoCAD, Civil 3D, Map 3D or all of them?
As stated on another thread, if a subcontractor submitted incomplete drawings, they would be sent back or not paid.
Thanks for the question and the sharp reality check, @SLW210!
To answer your first question: It works for standard AutoCAD (.DWG / .DXF), Civil 3D, and Map 3D drawings. The parser extracts 2D/3D polylines, pipe network linework, layer hierarchies, and block attributes directly without requiring an active Autodesk Map 3D / Civil 3D seat on the client machine.
Regarding subcontractors submitting incomplete drawings: You are 100% right on contract protocol. On new builds under active contract, non-compliant CAD files should definitely be rejected and kicked back to the sub.
Where our users run into the real headache is in scenarios where "sending it back" is no longer an option:
1. Legacy archives & brownfield utility assets: Decades-old municipal or plant drawings where the original drafter/firm is long gone, drawn in local 0,0 plant coordinates with zero projection metadata.
2. Cross-team handoffs: When civil drafters (who only work in 2D AutoCAD LT) hand off files to municipal GIS teams who need instant OGC Shapefiles or PostGIS layers with invert depths and pipe diameters intact.
3. Rapid feasibility & bidding: When estimating contractors receive messy tender CAD files and need to overlay them onto Google Earth KMZ or GIS parcel boundaries in minutes rather than spending half a day rubber-sheeting.
We're trying to eliminate that tedious manual linework cleaning and coordinate mapping when teams are stuck with what they have.
Would love your thoughts on what edge cases you see break Map 3D exports most frequently!
My comments "Decades-old municipal or plant drawings ", yes that is where the water main is located according to the onsite meeting with the water authority representative, We then got a service locator to really confirm where is water main. It took a meandering path due to road conditions not a straight line as shown on the water plan. So the plans are only asgood as "Ist baout here somewhere. Another telecommunication authority its a line on a plan no idea of actual offsets etc, conduits do not go square out of pits rather run along a boundary then cross a road so many stories about services, a 22,000KV elec underground cable missed by 100mm because another crew took on doing some trenching, we had already dug and deptrhe id.
For us a day to day task. Just have to work out how to solve. Solution may need a current field survey tying known points to world co-ordinates etc.
Edited by BIGAL
Your YouTube video wasn't very helpful.
This also looks to be a paid service you are advertising.
I wouldn't work off of old drawings in those cases, like @BIGAL, I would get a field survey.
You are 100% right @BIGAL and @SLW210. An unreferenced CAD drawing cannot replace SUE Quality Level A potholing/survey. Our tool is designed to ingest the surveyor's GCP tie-points to snap the CAD geometry to real-world ground truth
"surveyor's GCP tie-points to snap the CAD geometry to real-world ground truth"
Here in Australia a lot has a Field notes plan submitted as part of lot registration, tying to known PSM's, Rivets, Nails etc But the plan is hand drawn you can have a plan that shows details at say a few metres and has a tie to a point a Km away all in the one plan so there is no true scale to the plan. They are drawn and have to be printable so no points a Km away. You would have to redraw it at true scale.
Spot on, BIGAL—that's a critical distinction between diagrammatic cadastral field sketches and true-scale engineering infrastructure models.
You've hit on the classic COGO (Coordinate Geometry) dilemma: Australian field notes and title plans are drafted for A3/A4 paper-space readability, where a 1 km tie to a State Survey Mark (PSM) or recovery rivet is visually condensed or broken with a dimension annotation, rather than drawn at 1:1 ground distance. If you just take raw polyline vertices from those sketches, the geometry is obviously distorted.
Our pipeline currently targets 1:1 ModelSpace engineering drawings—like civil water networks, road corridors, and solar EPC layouts where 1 CAD unit = 1 meter (or 1 foot) in real space, and surveyors shoot 3+ GCPs at boundaries/manholes to compute a rigid Helmert 7-parameter or affine transformation into MGA2020 / GDA2020.
For diagrammatic field notes, automated OCR/COGO parsing of bearing-and-distance text is an active research challenge. In your day-to-day workflow, do you manually traverse and key in the bearings/distances in BricsCAD, or do you use a specific LISP/Civil routine to reconstruct the boundary?
I previously worked for a Municipal Authority and they had a Licensed Surveyor so he had the problem of tying things together. Sometimes easy sometimes very complex. Most of our projects were field surveyed so were current and tied to world co-ordinates.
