Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
Thread: steel shapes
  1. #11
    Full Member
    AutoCAD 2012
    Jan 2009
    31
    Quote Originally Posted by onkelbob View Post
    Yes this is fine but there are steel angles also used in steel design, they are also a pain to draw every time. I still would like to load my lisp program
    I am not sure how to add paths. or configure autocad in 2012
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Tools > Options > Files > Support File Search Path.
  3. #13
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Open the folder where you unzipped the files into, find the STL_Help.txt open it and read it.
  4. #14
    Full Member KevUK's Avatar
    AutoCAD 2014
    Nov 2009
    UK
    65
    You have only got to draw them once if you make them into a block!
  5. #15
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    I have been using the stl.lsp program for years and it works fine under 2012, 2011, 2010, 2009, 2007, 2004....just about any version I've run in the past it works. You just need to make sure that all the files ( and there are at least a dozen or so of them in this package) are all in your Support path. It works great for me. I know the newer versions of ACAD come with a complete library of the AICS manual but this program which was written years ago is still one of my favorites.
    It's deja vu, all over again.
  6. #16
    Full Member
    AutoCAD 2012
    Jan 2009
    31
    Default angles
    Quote Originally Posted by KevUK View Post
    there are inch and half inch sizes of angles up to 12 inches. That means each angle size may have a many unequal legs and various leg (web) thicknesses. I have no idea how many different sizes that would be.I know also that I can make blocks that stretch, but that turns into a lot of work too. The lisp program is still the best solution.
  7. #17
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Did you get it working?
  8. #18
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    there are inch and half inch sizes of angles up to 12 inches. That means each angle size may have a many unequal legs and various leg (web) thicknesses. I have no idea how many different sizes that would be.....
    To answer that question, there are 182 different L-Shapes in Al's Steel Mill just from 1/2" angle to 8" angle. But Steel Mill can generate an unlimited number of L-shapes because it has a feature that allows the the user to specify any flange thickness, and two flange lengths.... and that's just for L-Shapes. Additionally, dynamic blocks for steel cannot be "stretched" accurately as the fillets and radii on angles and beams are not proportional to either the thickness, or flange/web lengths. The only way a Dynamic block can accurately reflect a wide size range is via visibility states, or lookup tables. Furthermore, Steel Mill also generates any size or shape steel as a 3D Solid, or a Surface. IMO, the single advantage of using blocks for steel shapes is BOM.
    ... so onkelbob, did you get Steel Mill working?
  9. #19
    Forum Newbie JoshBero's Avatar
    Mechanical 2012
    May 2012
    3
    For anybody looking for shapes that does not have Mechanical, you can find them here. I am in the process of exporting the entire steel shapes library and placing the content online.
  10. #20
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,116
    Quote Originally Posted by JoshBero View Post
    Al's Steel Mill is a great add-on to vanilla AutoCAD and has been floating around for years.
    http://cadtips.cadalyst.com/standard...ypes-and-sizes
    Also, all Autodesk "vertical products" have an extensive steel library that comes standard, with great functionality since they are "AEC Objects".
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  1. Steel Shapes
    By Lemmesee in forum AutoCAD General
    Last Post: 6th Nov 2014, 07:06 pm
  2. Mechanical BOM partslist with steel shapes
    By JoeC in forum Mechanical & MDT
    Last Post: 6th Mar 2012, 07:30 am
  3. steel shapes. (sections)
    By IdoBrickner in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Apr 2011, 04:22 am
  4. Steel shapes
    By bolton78 in forum AutoCAD General
    Last Post: 3rd Jun 2008, 02:38 pm
  5. Structural steel shapes and dimensions catalog.
    By b.muqlueen in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2008, 05:26 pm
