We have some text objects that having long text strings like 500 character so i need a lisp that can split the text into 45-45 characters and make them separate object of 45 character. the reason of this is we have to export the text in other software and that software don't support more than 45 character string. so now we are manually spiting them.
  • Replies 31
  • subodh_gis
    11
  • pBe
    6
  • ReMark
    4
  • BIGAL
    4
Posted Images
Easy done using (substr new_line X Y) where x is start and y is the number of characters in your case Y=45 x=1 x=46 etc you need to just (Repeat for the number of characters in a line divide by 45 last Y is balance. I dont have a length of text characters answer someone will help then code is easy.
I am new to lisp please can u code it for me .length may vary. we can get the string length by selecting it.
Found it STRLEN string if I can find some time will do very easy, but need to know what to do with the 45 long texts do you want answer exported to a text file, lines of text in cad ? Are you picking multiple text ?
Please find the attachment of the example what i need actually.
Thanks
This will put it in a list:
(defun c:test ()
  (setq str "This is a test of a function to divide a long string in a series of shoter string.  The new shorter string must be a maximum of 45 characters.  The OP has not specified if the new string must be separated on a logical break like SPACE or punctuation mark.  Anyway here goes")
  ; Here without logical separation  ;
  (setq x 1 len 45 strlst nil strlst2 nil)
  (repeat (+ (/ (strlen str) 45) 1)
    (setq strlst (cons (substr str x (- len 1)) strlst)
               x (+ x len -1)
  (setq strlst (reverse strlst))
  (foreach s strlst
    (print s)
Would probably be a good idea to remove any "\n" for your string prior
to processing.
ymg
ymg3 same thoughts if on 1 line the different text styles and just the words make seperating correctly quite difficult as text will overlap or have different spacing.
A line by line is easiest, at (Print S) adding pick pt, text ht, then adjust XY adding text. Subodh_gis your turn now.
Thanks for both of you.
But code is not doing what i need actually. code should first ask to select the text and then split it.
i m not getting u properly sir, what u actually want to say. :(
Upload a sample drawing with before and after process .
1st part
Thanks for both of you. But code is not doing what i need actually. code should first ask to select the text and then split it.
Good time to start learning lisp the line (setq str is a sample line for testing purposes, do a bit of searching about entsel or ssget, entget & assoc these work together to allow you to pick the text and return the text string which you would set to str in the code above. just read a few of the lisp examples you will see how very quickly.
2nd part read Tharwat post, then final solution will come.
see the attached image in this thread.
Please see the attached image as example
(Defun c:m45 (/ str ent ll [t 45:s txt ur)
;;;		pBeMay2014		;;;
 (princ "\nSelect Text objects")
 (if (setq strs (ssget "_:L" '((0 . "TEXT"))))
   (repeat (Setq i (sslength strs))
     (setq ent	(entget (ssname strs (setq i (1- i))))
    pt	(cdr (assoc 10 ent))
    str	(cdr (assoc 1 ent)) cl 1
     (repeat (1+ (/ (strlen str) 45))
(setq 45:S (substr str 1 45))
(setq txt (entmakex (list (cons 0 "TEXT")
			  (cons 10 pt)
			  (Cons 1 45:S)
			  (assoc 7 ent)
			  (assoc 40 ent)
			  (cons 62 cl);<-color for identification
(vla-getboundingbox (vlax-ename->vla-object txt) 'll 'ur)
(setq ur (vlax-safearray->list ur))
(setq pt  (list (car ur) (cadr pt))
      cl  (1+ cl)
      str (substr str 46)
     (entdel (ssname strs i))
But i do agree with BIGAL
@ymg
Watch out:
(setq strlst (cons (substr str x [b](- len 1)[/b]) strlst) x [b](+ x len -1[/b]))
Produce a list of 44 characters string per item
Not sure but should that be just
(setq strlst (cons (substr str x [b]len[/b]) strlst)  x[b] (+ x len )[/b])
Edited by pBe
Are you telling me you need to REPLACE the selected TEXT entity with DIVIDED 45 CHARACTER string on the same SPOT? Because it doesnt look that way on your posted image at post 13 and someplace else in the world.
The good in me will only give you ONE more chance at this subodh_gis . As tharwat already requested, PLEASE POST A SAMPLE DRAWING
The problem with a lisp routine like this is one is liable to get results that look like this...
The language commonly used to describe the ba
ttle going on inside the Republican Party is wron
g and misleading. The fights this spring are not
between the "grass roots" and "the establishme
nt," but between two establishment fractions sp
ending vast sums to gain the upper hand. Thei
r confrontation has little to do with the long-ter
m philosophical direction of the GOP. Very rich
See what I mean? Words would be cut off unnaturally and no hyphens would be inserted, as in normal written text, as they should be. In my opinion it is a bad idea.
Here is my variation but have no time to test the code cause I have to leave the office now .:D
(defun c:Test (/ _l ss)
 ;;    Tharwat 18. May. 2014        ;;
 (defun _l (e / a b l)
   (vla-getboundingbox (vlax-ename->vla-object e) 'a 'b)
   (setq l (mapcar 'vlax-safearray->list (list a b)))
   (distance (car l) (cadr l))
 (if (setq ss (ssget "_:L" '((0 . "TEXT"))))
   ((lambda (i / sn st pt e en j n)
      (while (setq sn (ssname ss (setq i (1+ i))))
        (if (> (strlen (setq st (cdr (assoc 1 (setq en (entget sn)))))) 45)
          (progn (setq pt (cdr (assoc 10 en))
                       e  (cdr (assoc -1 (entmod (append en (list (cons 1 (substr st 1 45)))))))
                       st (substr st 46)
                 (repeat (1+ (/ (strlen st) 45))
                   (setq
                     e (entmakex (append (vl-remove-if-not '(lambda (x) (member (car x) '(0 8 62 40 41 50))) (entget e))
                                               (cons 10 (setq pt (polar pt (cdr (assoc 50 (entget e))) (_l e))))
                   (setq st (substr st 46))
     -1
) (vl-load-com)
I know what you mean ReMark ... but our "Last Chance" OP did say:
....the reason of this is we have to export the text in other software and that software don't support more than 45 character string....
I guess it would still "look" normal if the program will split the string onto the same spot.
EDIT: hang on. i believe the OP did say export the result to a external file. maybe you have somethng there ReMark, [now i'm confused]
FWIW: code updated at post# 14
@Tharwat
Throw in 7 in there for TEXTSTYLE
...(member (car x) '(0 [b]7[/b] 8 62 40 41 50))..
Edited by pBe
Yes REPLACE the selected TEXT entity with DIVIDED 45 CHARACTER string on the same SPOT. see the attached drawing.
sample.dwg
