Guitte Posted November 3, 2014 Share Posted November 3, 2014 Hi Guys, When opening a drawing i was busy with a week ago and want to carry on. How does it happen that some of the lines doesn't want to trim or extend checking the Z-axis, the EDGEMODE put it to 0 and 1 also select trim/right click/project/none, everything good. Still doesn't trim. Im not sure if it might be if someone else is opening my drawing that settings might change somehow. Any advice? Thanks. Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Think i know why this happens. The lines where i want to trim or extend to, is not on the z-axis set to 0. What blows my mind is that i cant figure out when going back to my previous drawings find that some of the lines are not set to 0 on the z-axis. Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 The Z value shouldn't have any affect on the trim command, unless your UCS is altered. Can you post a drawing showing the lines that need to be trimmed and the lines that should be used to trim too. It could be that your UCS has changed for some reason. Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Hi Steven-g, I honestly hope i did the "share-link" right. Here is it. https://www.dropbox.com/s/eoqlt3huclodu2p/FP003-ShpDwg-Zone08.dwg?dl=0 Please tell me if you can access it. Thanks. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 3, 2014 Share Posted November 3, 2014 Which lines that you can not trim and extend ? You did not indicate to them in the attached drawing . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 3, 2014 Share Posted November 3, 2014 If you have the Express Tools installed on your system , just type flatten and select the lines then try to trim or extend . Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 You can check any of the vertical steel posts (blue lines), some of them i did check that is where my previous "conclusion" post came from. Where the 2 posts meet there is a 30mm gap, that is where i found the problem. Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Seems Express Tools can only be used in 3ds Max, im using ACAD LT. Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 I got the file, but where should we be looking ? I can't find a 30mm gap, Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 The macro ^C^Cm;0,0;0,0,1E99;m;p;;0,0;0,0,-1E99; will work in this case to bring all your geometry to Z=0. Though you need to be very careful when you use this macro as to the sort of objects that you select because sometimes it can have a negative effect on drawings. (You need to select the items before running the macro - and I would recommend always using it on a copy of your drawing, just to be safe). Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 I'll try the Macro cautiously, thank you Steven-g. One last question, can it happen when someone else is using your drawing that it might change some settings on it? Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 The Macro i copied and paste in the command line, telling me its an unknown command. Is there something else i need to do to make it work? Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Steven-g, i have tried the Macro out. Copy and paste it in the command line, tells me it an unknown command. Do i need to do something else to make it work? Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 You have to run the macro from a toolpalette or create a new command in the CUI, if you want to drop it straight into the command line then you need to use the script version (NOTE there is a space after the word previous to accept the selection) move 0,0 0,0,1E99 move previous 0,0 0,0,-1E99 Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Jippy, at last i got it right how to create a macro...how do i know if it works? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 3, 2014 Share Posted November 3, 2014 Jippy, at last i got it right how to create a macro...how do i know if it works? Try it on the objects that you could not have it working before to check it out Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 Check the Z values before and after running the script of the objects you mentioned before that had the wrong Z values. Though as I mentioned before the Z value shouldn't effect how the trim/extend command works. Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 Dear Steven, i have run the macro "^C^Cm;0,0;0,0,1E99;m;p;;0,0;0,0,-1E99;". Going to properties the start and end Z value is -1.0E+99 and Delta Value is 0. Trim still doesn't want to play along. My first attempt I have tried the toolpallete with your other macro move 0,0 0,0,1E99 move previous 0,0 0,0,-1E99 Not sure how to use it and cant paste it in the CUI command macro space. Quote Link to comment Share on other sites More sharing options...
Guitte Posted November 3, 2014 Author Share Posted November 3, 2014 One of the lines i can move without using the move command and can only select one point. It cant trim or extend. Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 3, 2014 Share Posted November 3, 2014 which are the lines that won't trim or extend, can you post a screen shot or a marked up drawing, you're drawing has a lot of lines and I can't find where you mean Quote Link to comment Share on other sites More sharing options...
