C4C Posted February 2, 2016 Share Posted February 2, 2016 When trying to use the 'Revit Fabrication Export' Addin i get the following message when trying to save out as a RIF. Steps so far. Select the required system store design line & graphical element Select 'out' Save As 'Rif' ... then i get the error message. My goal is to get the Revit file into Autodesk Fabrication. Any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 2, 2016 Share Posted February 2, 2016 That's a new one with me. I personally do not use the Fabrication area of Revit since it's nothing more than DWG imports. You may need to put in a ticket with Autodesk on this one. -TZ Quote Link to comment Share on other sites More sharing options...
