Revit Error - 'Autodesk.Revit.DB.Level'
C4C
 Share
When trying to use the 'Revit Fabrication Export' Addin i get the following message when trying to save out as a RIF.
Steps so far.
Select the required system
store design line & graphical element
Select 'out'
Save As 'Rif'
... then i get the error message.
My goal is to get the Revit file into Autodesk Fabrication.
Any help would be much appreciated
That's a new one with me. I personally do not use the Fabrication area of Revit since it's nothing more than DWG imports. You may need to put in a ticket with Autodesk on this one.
-TZ
 Share
