Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Senior Member
    AutoCAD 2010
    Oct 2004
    England
    207
    Default 3D Solids after Union
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Why? Will the "lines" be invisible when the piece of furniture is built?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,105
    Is there a slight misalignment in the pieces?
    Post the .dwg.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    The one on the far left can be made to disappear if you union the vertical piece to the "L".
    Just curious. What is being modeled and what material (wood, masonry, metal, other) would be used to construct it?
  5. #5
    Senior Member
    AutoCAD 2010
    Oct 2004
    England
    207
    Quote Originally Posted by SLW210 View Post
    Post the .dwg.
    3D Solids.dwg
    ReMark, there is no material attached as I only want to build a simple visual.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I didn't ask you if there was a material attached. I asked you what material would the object be built out of?
    OK...looking at your drawing I would assume the building is masonry and either concrete block with a stucco finish or poured concrete. Is that correct?
    This isn't supposed to be a house is it? The walls of the building seem to be quite thick; more so than the privacy walls on the exterior.
    The horizontal span that bridges the opening between the two walls seems too long to be only supported at both ends. How exactly will it be constructed so it won't collapse of its own weight?
    Why does such a small building need such thick walls?
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    Try setting VSEDGES to 0.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  8. #8
    Senior Member
    AutoCAD 2010
    Oct 2004
    England
    207
    Thanks rKent's suggestion changed VSEDGES to 0, but then all outlines invisible only panes with different shade of grey.
    I have tried also make changes to the Properties without success.
    There must be something I missed.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    What are you referring to by the words "outlines" and "panes"? Are you talking about the flat two dimensional windows? You do realize that the majority of the inside of your building is one big solid and that the windows are basically drawn on the front and side faces. You cannot peer into them and see the building's interior. Nothing about the windows is really 3D.
    rkent's suggestion does work.
  10. #10
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    There is something strange going on with your model. When I isolate that curved piece, the image below is what I see. This is all one piece and is listed as a 3D Solid. I'm not sure what's happening here, but you might want to reconstruct that piece.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. how do you un-union solids?
    By dumfatnhappy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Mar 2015, 03:34 pm
  2. why I can't hide hidden lines after an union solids?
    By stenews in forum AutoCAD General
    Last Post: 20th Jan 2011, 08:03 pm
  3. Removing unwanted solids after union command
    By MARTIN PETERS in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jul 2010, 07:43 pm
  4. Problem with union and solids
    By Yorick in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2007, 12:18 pm
  5. Creating a Union between non co-planar solids.
    By steamwise in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Sep 2006, 02:37 pm
