Starkey Posted January 12, 2007 Share Posted January 12, 2007 Anyone have a hatch for the curvy lines usually associated with insulation? Or send me to a tutorial where I can make my own if you so choose :wink: -Taylor Quote Link to comment Share on other sites More sharing options...
Dommy2Hotty Posted January 12, 2007 Share Posted January 12, 2007 How about a linetype? AutoCAD has a linetype named BATTING. I created a LISP routine to load the linetype and draw a line that has the correct scale based on the insulation size and drawing scale...I can give it to you, if you want... Quote Link to comment Share on other sites More sharing options...
Starkey Posted January 12, 2007 Author Share Posted January 12, 2007 Correct me if I'm wrong, but I can't run LISP routines in AutoCAD LT correct? But I will search for that linetype...I didn't even think to check that. Thanks Quote Link to comment Share on other sites More sharing options...
Dommy2Hotty Posted January 12, 2007 Share Posted January 12, 2007 Correct me if I'm wrong, but I can't run LISP routines in AutoCAD LT correct? But I will search for that linetype...I didn't even think to check that. Thanks Oops...I didn't look before I posted... Quote Link to comment Share on other sites More sharing options...
Starkey Posted January 12, 2007 Author Share Posted January 12, 2007 Oops...I didn't look before I posted... That's cool...I found the linetype, and scaling the line down wasn't a problem at all. Another problem solved on the cadtutor forums! Quote Link to comment Share on other sites More sharing options...
Austriker Posted August 18, 2007 Share Posted August 18, 2007 i have the same problem but didnt get mine to work so easy, some help please!!! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 18, 2007 Share Posted August 18, 2007 Can you at least give us a little information about what the problem is? Is it a problem with a hatch pattern or a problem with a lisp routine or a problem with a linetype or a problem with scaling? Quote Link to comment Share on other sites More sharing options...
Starkey Posted August 18, 2007 Author Share Posted August 18, 2007 Second the more information part....are you using Civil 3D 06 and having this problem? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted August 18, 2007 Share Posted August 18, 2007 Is this what you looking for??? BATTINSUL.zip Quote Link to comment Share on other sites More sharing options...
alec Posted September 24, 2007 Share Posted September 24, 2007 hi, I use Batting a lot for my insulation sections - I just opened that attachment and all I got was a page full numbers - lots of numbers. Is there something else I shopuld do to it or have I got something set wrong? cheers, Smudger Quote Link to comment Share on other sites More sharing options...
Noahma Posted September 25, 2007 Share Posted September 25, 2007 Here is a lisp routine that I got from a friend years ago (still works great) insul.lsp should do the trick Quote Link to comment Share on other sites More sharing options...
hugha Posted September 25, 2007 Share Posted September 25, 2007 (edited) Here's a more efficient version of that BATTINSUL hatch. It looks the same, but all the unnecessary duplication and differing spacings have been removed. *BATTINSUL,BATTINSUL (efficient small version) ;---------------------------------------------------------------------- ; Pattern written by HatchKit v2.7 Hatch Pattern Editor ; HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2007. ; [url="http://www.cadro.com.au/hatchkit/"]www.cadro.com.au/hatchkit/[/url] ;---------------------------------------------------------------------- ;-Template=BATTINSUL,BATTINSUL ;-Source =C:\Documents and Settings\Hugh\My Documents\BATTINSUL.PAT ;-Date =25/09/2007 ;-Time =9:02:49 PM ;---------------------------------------------------------------------- 74.8352172299,0.1771,0.9579,12.8711770908,0.0268730411076,0.111,-13.9382297459 -67.1012536037,0.2036,0.7338,2.47190993325,0.0439687288314,0.2558,-8.33088282042 -14.064635312,0.08823,0.1448,4.8119408458,0.040597225286,0.08127,-9.2185165207 14.0646353119,0.1671,0.125,4.48784567492,0.0405972252861,0.08127,-9.21851652067 -74.8352172299,0.1281,1.065,1.17805265514,0.0268730411076,0.111,-13.9382297459 25.0089453241,0.206,1.065,2.59721654072,0.0353121802716,0.1414,-10.5502515941 52.4486755958,0.2459,0.1448,2.8099019349,0.052977168901,0.1374,-6.98917048922 -52.448675596,0.004471,0.2537,4.3166685543,0.052977168901,0.1374,-6.9891704892 83.8125227449,0.004471,0.2537,12.5016343296,0.011072157934,0.2459,-33.8527400974 67.1012536037,0.03078,0.4982,6.11477288716,0.0439687288314,0.2558,-8.33088282042 -25.0089453241,0,1.125,8.09443505337,0.0353121802716,0.14144,-10.5502115941 -83.8632671306,0.3033,0.4982,9.09534825883,0.030199681935,0.2459,-12.2557392326 83.2549943627,0.1305,0.7338,3.40577841418,0.0663597207299,0.2257,-5.46367789881 -83.2549943627,0.1771,0.9579,2.28359948464,0.0663597207299,0.2257,-5.46367789881 There's no reason for hatch patterns to contain that level of repetition. Hugh Adamson www.cadro.com.au BATTINSUL.zip Edited October 29, 2012 by SLW210 Code Tags!! Quote Link to comment Share on other sites More sharing options...
bold architecture design Posted February 20, 2008 Share Posted February 20, 2008 Here is a lisp routine that I got from a friend years ago (still works great) [ATTACH]2703[/ATTACH] should do the trick Hi, pretty new to the Forum and with a Vectorworks background, but slowly (after 5 years!) picking up ACAD. This routine is great but each time I use the command 'Insul' it turns off my OSNAP settings and I have to turn them on again and they've all been turned off by default. Little bit frustrating as I need the OSNAP generally each time I use the Insul lsp routine. Any advice greatly appreciated. Quote Link to comment Share on other sites More sharing options...
hugha Posted February 20, 2008 Share Posted February 20, 2008 Open the insul.lsp wsith a text editor (even Notepad) and comment out this line (setvar "OSMODE" 0) with a semicolon prefix like this. ; (setvar "OSMODE" 0) Save the file - you will then keep your osnaps as is. I haven't tested how it will affect the routine's operation but it could be worth a try. Quote Link to comment Share on other sites More sharing options...
hakelu Posted December 3, 2008 Share Posted December 3, 2008 Hi guys. I tried to use the hatch file you provided, but it wont draw curves, but non-continueous lines crossing each other, it is ugly. I tried the lisp routine as well, but once finished setting parameters, it works for a few seconds, countinueously writing: "A" is unkown order", and so on... and then nothing happens. I use AutoCAD 2007 hungarian version. Any suggestions? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Audryb Posted December 19, 2008 Share Posted December 19, 2008 Here is a lisp routine that I got from a friend years ago (still works great) [ATTACH]2703[/ATTACH] should do the trick this is a great lisp routine, but I'm wondering if there's a way to edit it so that the angles of the insulation from one arc to the next are a little steeper? I'd like arcs of the finished batt to come closer together or even touch, but I'm not sure what variables to tweak. thanks! Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted December 29, 2008 Share Posted December 29, 2008 I have created a menu that has a few different linetypes in it to download. For those that aren't familiar with installing a menu, I also have created an installation guide. And all this will also work in LT too. http://www.thirdistudio.com.au/ThirdiStudioDownloads.html Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted December 29, 2008 Share Posted December 29, 2008 By the way, the site isn't finishes as yet so hoepfully no complaints. Quote Link to comment Share on other sites More sharing options...
Cyberkid Posted March 7, 2009 Share Posted March 7, 2009 Do anyone know how to get an LISP rutine that makes a zigzag insulation like this: best regards to all cyberkid Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted March 7, 2009 Share Posted March 7, 2009 theres already a linetype in AutoCAD called zig zag Quote Link to comment Share on other sites More sharing options...
