Steven P started following Automatically drawing blocks
Where I see posts dug up from many years ago - particularly if there are several answers years later from the same accout - I am starting to assume there is some 'computer aided searching' going on.. not saying a AI bot explicitly but.....
- 6 replies
- 2
- network nodes
- data extraction
(and 2 more)
Tagged with:
Automated tool for converting unreferenced AutoCAD DWGs to georeferenced GIS Shapefiles in 12s
SLW210 replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
Your YouTube video wasn't very helpful. This also looks to be a paid service you are advertising. I wouldn't work off of old drawings in those cases, like @BIGAL, I would get a field survey. -
Looking to hire a programmer to update our AutoCad Lisp routines and menu's.
SLW210 replied to TommyB's topic in AutoLISP, Visual LISP & DCL
Welcome to CADTutor!! -
How to bring OpenStreetMap streets and buildings into AutoCAD (DWG/DXF) — what actually works
SLW210 replied to OSM2CDR's topic in AutoCAD Drawing Management & Output
Yes, they look to be selling a service to me. -
Converting scanned engineering drawings into accurate editable CAD geometry
We have sent old blueprints and microfiche out to a company to be put to digital at a previous company, they did a pretty good job, no telling the cost, this was quite a while ago. My boss did ask a few years ago about getting some paid interns to do some old blueprints that need scanned. Yes, if your company wants to spend the money, there are some pretty good software choices out there to make it easier. After a short learning curve I did very well with Raster Design and a few LISPs. I plan to see if my work will get this... HP AI Vectorization | HP® Official Site | HP® Official Site, at least see about a trial. -
Yes, they have already been warned twice about this.
- 6 replies
- 2
- network nodes
- data extraction
(and 2 more)
Tagged with:
EnM4st3r started following Automatically drawing blocks
@AONE_LED you do realize those are decade old posts you are answering to?
- 6 replies
- 2
- network nodes
- data extraction
(and 2 more)
Tagged with:
KronosY joined the community
2D Fluorescent light fixture blocks required
indiancad replied to JamFam's topic in Blocks, Images, Models & Materials
Try CAD Forum, CADblocksfree, or Zumtobel’s CAD library for fluorescent light fixture DWG blocks. Check the manufacturer drawings for accurate 2-lamp and 4-lamp fixture dimensions, including side and end views. -
AONE_LED replied to JamFam's topic in Blocks, Images, Models & Materials
Standard recessed fluorescent symbols are easy to draw yourself and then turn into blocks. In plan, a 2-lamp 2x4 (typically 600x1200 mm or 2'-0" x 4'-0") is a rectangle of those exact dimensions with a single diagonal, or two short lines for the lamps; a 2x2 (600x600 mm) uses a square and one diagonal. Put them on a dedicated lighting layer, insertion point at the centre so they sit cleanly on a ceiling grid. For the end and side views you asked for, draw a shallow housing (about 100-150 mm high) with two or four lamp circles or rectangles inside, and a small junction-box or ballast housing at one end if you need it. Make one block per type (2-lamp and 4-lamp) with a type attribute so you can schedule them later. Draw everything at 1:1 in model space. -
Don't try to insert a marshalling box the instant an eighth luminaire is placed. Place and number all luminaires first, then run a LISP that: (1) lets you select a group, or automatically clusters fixtures into groups of eight; (2) inserts the network-box block at the group's centroid or at a point you pick on the control route; (3) draws a polyline from the box to each luminaire in the group; (4) writes luminaire number, box number and a running count to a CSV for your BOM. Keep the "maximum 8 lamps per box" as a parameter, not hard-coded, because some boxes take fewer. DALI itself allows up to 64 short addresses on one bus; the eight-lamp limit is a wiring/marshalling constraint, not a protocol limit. That split keeps the drawing step and the takeoff step reliable.
- 6 replies
- network nodes
- data extraction
(and 2 more)
Tagged with:
The half-wall offset you want is just centre-to-centre spacing divided by two. Measure the room length L and width W, then decide how many fixtures you need in each direction (Nx and Ny). Spacing in X is L/Nx and in Y is W/Ny. Place the first fixture at (L/Nx)/2, (W/Ny)/2 from the corner, then ARRAY it Nx columns by Ny rows with those same column and row distances. That automatically keeps every fixture a half-spacing off the walls. ARRAY is enough for rectangular rooms; a LISP only needs two corner points plus Nx and Ny, then the same maths. Check the fixture's maximum spacing-to-mounting-height ratio so the grid is not too wide for the ceiling height. For non-rectangular rooms, hatch or BOUNDARY the area first and insert only inside that outline.
BIGAL replied to OSM2CDR's topic in AutoCAD Drawing Management & Output
What is available for Australia ? -
Hire a casual, student, some one wanting experience drafting, raster to vector can be a hit or miss. Use Ortho a lot when tracing over, and like others read the dims, using ortho start point, drag then type dim value. A secret underlay is a pdf. -
BIGAL replied to TommyB's topic in AutoLISP, Visual LISP & DCL
Welcome aboard Tommy there are a few people here who can help you. My questions, where are you in the world ? What discipline are you in, helps to get people with similar skils. Sent you a PM. -
BIGAL replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
My comments "Decades-old municipal or plant drawings ", yes that is where the water main is located according to the onsite meeting with the water authority representative, We then got a service locator to really confirm where is water main. It took a meandering path due to road conditions not a straight line as shown on the water plan. So the plans are only asgood as "Ist baout here somewhere. Another telecommunication authority its a line on a plan no idea of actual offsets etc, conduits do not go square out of pits rather run along a boundary then cross a road so many stories about services, a 22,000KV elec underground cable missed by 100mm because another crew took on doing some trenching, we had already dug and deptrhe id. For us a day to day task. Just have to work out how to solve. Solution may need a current field survey tying known points to world co-ordinates etc. -
Steven P replied to OSM2CDR's topic in AutoCAD Drawing Management & Output
It says pay without registering -
Steven P replied to indiancad's topic in AutoCAD Drawing Management & Output
Raster images - Tiffs - complete redraw using whatever dimensions are available, what I don't know you can infer a lot (for example a wall thickness near a known dimension can infer another dimension) and after that it is down to experience and knowledge with the odd "go over there with a tape measure". Mapping websites are OK for buildings - use 2 or 3 and average out the distances can help if there are absolutely no known dimensions (again inferring distances from known things... including counting bricks from a street view), mapping I have a tool to draw perpendicular polylines off the first line angle which helps a lot. Small parts are often drawn to fractions of the scale (0.5mm, 1mm, 2.5mm etc.... 1/100th inch or whatever) - so once drawn can snap entities to a grid... gets close enough which is all you can do if you cannot be supplied with dimension or a part / site visit to work more accurately from Used to have Paintshop Pro (7 I think) that had a tool to correct parallax errors somewhat. -
TommyB posted a topic in AutoLISP, Visual LISP & DCL
We’re looking for an experienced programmer to update our AutoCAD LISP routines and menus. Our routines are used in AutoCAD 2011 and include a parcel script. If you have experience with AutoLISP and customizing AutoCAD, please reply with a brief description of your experience, examples of similar work, and your availability. Please include your preferred rate and how you’d like to discuss the project. Thanks! -
TommyB joined the community
Pramod Kumar replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
Thanks for the question and the sharp reality check, @SLW210! To answer your first question: It works for standard AutoCAD (.DWG / .DXF), Civil 3D, and Map 3D drawings. The parser extracts 2D/3D polylines, pipe network linework, layer hierarchies, and block attributes directly without requiring an active Autodesk Map 3D / Civil 3D seat on the client machine. Regarding subcontractors submitting incomplete drawings: You are 100% right on contract protocol. On new builds under active contract, non-compliant CAD files should definitely be rejected and kicked back to the sub. Where our users run into the real headache is in scenarios where "sending it back" is no longer an option: 1. Legacy archives & brownfield utility assets: Decades-old municipal or plant drawings where the original drafter/firm is long gone, drawn in local 0,0 plant coordinates with zero projection metadata. 2. Cross-team handoffs: When civil drafters (who only work in 2D AutoCAD LT) hand off files to municipal GIS teams who need instant OGC Shapefiles or PostGIS layers with invert depths and pipe diameters intact. 3. Rapid feasibility & bidding: When estimating contractors receive messy tender CAD files and need to overlay them onto Google Earth KMZ or GIS parcel boundaries in minutes rather than spending half a day rubber-sheeting. We're trying to eliminate that tedious manual linework cleaning and coordinate mapping when teams are stuck with what they have. Would love your thoughts on what edge cases you see break Map 3D exports most frequently! -
I have used Raster Tools with some great success before. For badly distorted drawings, I create blocks and scale in both directions, no matter the method used to create the linework. If it is a critical part that needs to be drawn very accurate or just a terrible plot, scan, etc., I just look at the drawing and totally redraw from scratch using the indicated dimensions or even better for small objects I just measure the object if available. -
Is this a free service? -
Is this for AutoCAD, Civil 3D, Map 3D or all of them? As stated on another thread, if a subcontractor submitted incomplete drawings, they would be sent back or not paid. -
Associative Textbox (Lee Mac)
Steven P replied to sachindkini's topic in AutoLISP, Visual LISP & DCL
Select both entities, the text and the text box? Edit: Thinking about it, probably best to copy just the text and recreate the textbox to be sure to keep the new text and box associated, -
OSM2CDR replied to OSM2CDR's topic in AutoCAD Drawing Management & Output
Follow-up for anyone who just needs a city rather than a custom rectangle: there are ready-made city pages now, e.g. London https://osm2cdr.com/en/map/united-kingdom/england/london/ and New York https://osm2cdr.com/en/map/united-states/new-york/new-york/ — the DWG/DXF there comes split into layers (roads, buildings, water, landuse) in the CRS you pick. Disclosure: I'm the developer. -
Paul Li started following Converting scanned engineering drawings into accurate editable CAD geometry
Paul Li replied to indiancad's topic in AutoCAD Drawing Management & Output
Hopefully there are dimensions noted on the scan. That's what I would typically use to manually redraw it accurately in CAD from scratch.
