VicoWang started following From coordinate hallucination to 7-token precision (LISP Sandbox)
Hi everyone, I've been thinking about the "AI taking over" discussion. Personally, I sit in the "Skeptical Co-Pilot" camp. I use LLMs, but natural language is too loose for CAD. I was trying to solve a very pragmatic problem: How do we get an LLM to generate hyper-precise CAD geometry without eating up a million tokens and spitting out hallucinated garbage? Natural language just doesn't cut it for drafting. So, I worked with an AI to invent a prototype "Universal Morphological Matrix" (I just call it V-Code). The idea was to reduce CAD commands down to an absolute, 256-token hex-based root system utilizing Reverse Polish Notation (RPN). (Full disclosure: I'm an architect, not a compiler engineer—I actually had to get the AI to explain what an RPN stack machine even was during our brainstorming sessions). For example, to draw a 10x10x10 box, place a radius 6 sphere at its center, and subtract it, the LLM only needs to output exactly 7 tokens: 10,10,10 ᖴ ᙶ 6 ᖴ ᙺ ᗣ (The ᖴ rune takes a comma-separated stream like 10,10,10 and unpacks it into 3 scalars on the stack. No syntax to hallucinate.) To show how this executes without needing API keys, I wrote an interactive, 3-step DCL sandbox in pure AutoLISP. It walks through the prompt, the V-Code payload, the RPN stack trace, and actually draws the CSG solid. (Runs on 2007+). ;;;---------------------------------------------------------------------------- ;;; V-Agent Interactive Sandbox v1.0 (Tensor Stream Decoding Edition) ;;; Architecture: LLM-Optimized Morphological RPN Parsing with SIMD ;;; Compatibility: AutoCAD 2007+ (Native Unicode Render) ;;; Author: Vico ;;;---------------------------------------------------------------------------- (vl-load-com) ;; --- Core Utilities --- (defun VA:Split ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (VA:Split (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ;; --- Virtual Machine & CSG Engine --- (defun VA:RunVCode (code_str / doc ms stack push pop-val tkns tkn h w l r pt o1 o2 obj raw sub-tkns st) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) ms (vla-get-ModelSpace doc) stack nil) (defun push (val) (setq stack (cons val stack))) (defun pop-val (/ v) (if stack (progn (setq v (car stack) stack (cdr stack)) v) nil)) (setq tkns (VA:Split code_str " ")) (foreach tkn tkns (if (/= tkn "") (cond ;; \U+15B4 [Bqb] : TEXT STREAM DECODING (Pop Tensor String -> Unpack -> Push Scalars) ((wcmatch tkn "*\U+15B4*") (setq raw (pop-val)) (if raw (progn ;; SIMD Unpacking: Split by comma for dimensional vectors (setq sub-tkns (VA:Split (vl-princ-to-string raw) ",")) (foreach st sub-tkns (push (atof st)) ) ) ) ) ;; \U+1676 [Tot] : BOX (Pop H, W, L) ((wcmatch tkn "*\U+1676*") (setq h (pop-val) w (pop-val) l (pop-val) pt (vlax-3d-point 0 0 0)) (if (not (vl-catch-all-error-p (setq obj (vl-catch-all-apply 'vla-addbox (list ms pt l w h))))) (push obj)) ) ;; \U+167A [Kok] : SPHERE (Pop Radius) ((wcmatch tkn "*\U+167A*") (setq r (pop-val) pt (vlax-3d-point 0 0 0)) (if (not (vl-catch-all-error-p (setq obj (vl-catch-all-apply 'vla-addsphere (list ms pt r))))) (push obj)) ) ;; \U+15E3 [Nan] : SUBTRACT (Pop Obj2, Obj1 -> Obj1 - Obj2) ((wcmatch tkn "*\U+15E3*") (setq o2 (pop-val) o1 (pop-val)) (if (and o1 o2) (vl-catch-all-apply 'vla-boolean (list o1 2 o2))) ; 2 = acSubtraction (push o1) ) ;; Default: Push raw token as unverified string (Dirty Data State) (t (push tkn)) ) ) ) ;; Visual Feedback: Fallback to _G (Gouraud) for wide compatibility (vl-catch-all-apply 'vla-put-Direction (list (vla-get-ActiveViewport doc) (vlax-3d-point 1 -1 1))) (vla-ZoomExtents (vlax-get-acad-object)) (vl-catch-all-apply 'vl-cmdf (list "_.SHADEMODE" "_G")) ) ;; --- Interactive Wizard --- (defun c:VAgent (/ dcl_tmp f dcl_id step res task v_l v_w v_h v_r prompt_data vcode_raw log_l log_r update-prompt build-stack) (setq dcl_tmp (vl-filename-mktemp "va_wizard.dcl") f (open dcl_tmp "w")) ;; Step 1 UI (write-line "va_step1 : dialog { label=\"V-Code Morphological Matrix Simulator\"; width=85;" f) (write-line " : text { key=\"step_title\"; font=\"bold\"; alignment=centered; label=\"Step 1: The Ambiguity of Natural Language\"; }" f) (write-line " : spacer { height=0.5; } : boxed_radio_row { label=\"Target Geometry Generation\"; key=\"task\";" f) (write-line " : radio_button { label=\"Solid Box\"; key=\"rb_box\"; value=\"1\"; } : radio_button { label=\"Solid Sphere\"; key=\"rb_sph\"; } : radio_button { label=\"Hollow Box (Boolean)\"; key=\"rb_hol\"; } }" f) (write-line " : boxed_row { label=\"Spatial Parameters (Customizable)\";" f) (write-line " : edit_box { label=\"Length:\"; key=\"v_l\"; edit_width=8; } : edit_box { label=\"Width:\"; key=\"v_w\"; edit_width=8; }" f) (write-line " : edit_box { label=\"Height:\"; key=\"v_h\"; edit_width=8; } : edit_box { label=\"Radius:\"; key=\"v_r\"; edit_width=8; is_enabled=false; } }" f) (write-line " : boxed_column { label=\"Simulated LLM Prompt (Natural Language Payload)\"; : list_box { key=\"prompt_view\"; height=9; width=81; fixed_width=true; } }" f) (write-line " : spacer { height=0.2; } : row { spacer; : button { key=\"next\"; label=\"Translate to V-Code >\"; is_default=true; width=24; } : button { key=\"cancel\"; label=\"Cancel\"; is_cancel=true; width=14; } } }" f) ;; Step 2 UI (write-line "va_step2 : dialog { label=\"V-Code Morphological Matrix Simulator\"; width=75;" f) (write-line " : text { font=\"bold\"; alignment=centered; label=\"Step 2: Dimensional Collapse (V-Code Matrix)\"; } : spacer { height=0.5; }" f) (write-line " : boxed_column { label=\"Cosmic Language (Morphological Payload)\"; : spacer { height=1; } : text { key=\"vcode_view\"; alignment=centered; font=\"bold\"; } : spacer { height=1; } }" f) (write-line " : boxed_column { label=\"Compression Metrics\"; : text { label=\"> Procedural AutoLISP required: ~180 Tokens\"; color=8; } : text { key=\"token_met\"; label=\"\"; } : text { label=\"> Spatial Hallucination Risk: 0% (Strict Type Casting)\"; } }" f) (write-line " : spacer { height=0.2; } : row { : button { key=\"back\"; label=\"< Back\"; width=12; } spacer; : button { key=\"next\"; label=\"Parse AST Engine >\"; is_default=true; width=24; } : button { key=\"cancel\"; label=\"Cancel\"; is_cancel=true; width=12; } } }" f) ;; Step 3 UI (write-line "va_step3 : dialog { label=\"V-Code Morphological Matrix Simulator\"; width=125;" f) (write-line " : text { font=\"bold\"; alignment=centered; label=\"Step 3: Stack-Based Virtual Machine Execution\"; } : spacer { height=0.5; }" f) (write-line " : row { : boxed_column { label=\"V-Code Stream\"; : list_box { key=\"log_l\"; height=12; width=28; fixed_width=true; } }" f) (write-line " : boxed_column { label=\"Local CAD Engine Execution Stack (Reverse Polish Notation)\"; : list_box { key=\"log_r\"; height=12; width=88; fixed_width=true; } } }" f) (write-line " : spacer { height=0.2; } : row { : button { key=\"back\"; label=\"< Back\"; width=12; } spacer; : button { key=\"next\"; label=\"Execute Geometry in CAD\"; is_default=true; width=30; } : button { key=\"cancel\"; label=\"Cancel\"; is_cancel=true; width=12; } } }" f) (close f) ;; State Init (setq task "rb_box" v_l "10" v_w "10" v_h "10" v_r "6" step 1) (defun update-prompt () (setq v_l (get_tile "v_l") v_w (get_tile "v_w") v_h (get_tile "v_h") v_r (get_tile "v_r") task (get_tile "task")) (cond ((= task "rb_box") (mode_tile "v_l" 0) (mode_tile "v_w" 0) (mode_tile "v_h" 0) (mode_tile "v_r" 1) (setq prompt_data (list "System: Hooking into LLM Context..." (strcat "> Prompt: \"Create a solid box measuring " v_l " by " v_w " by " v_h ".\"") "" "> Action: Injecting V-Code 256-Rune Dictionary..." "> Note: Numeric streams must be unpacked via Decode Rune \U+15B4." "> Command: Translate human request to Morphological Matrix.")) (setq vcode_raw (strcat v_l "," v_w "," v_h " \U+15B4 \U+1676")) ) ((= task "rb_sph") (mode_tile "v_l" 1) (mode_tile "v_w" 1) (mode_tile "v_h" 1) (mode_tile "v_r" 0) (setq prompt_data (list "System: Hooking into LLM Context..." (strcat "> Prompt: \"Create a solid sphere with a radius of " v_r ".\"") "" "> Action: Injecting V-Code 256-Rune Dictionary..." "> Note: Numeric streams must be unpacked via Decode Rune \U+15B4.")) (setq vcode_raw (strcat v_r " \U+15B4 \U+167A")) ) ((= task "rb_hol") (mode_tile "v_l" 0) (mode_tile "v_w" 0) (mode_tile "v_h" 0) (mode_tile "v_r" 0) (setq prompt_data (list "System: Hooking into LLM Context..." (strcat "> Prompt: \"Create a " v_l "x" v_w "x" v_h " box, create a radius " v_r " sphere,") " and subtract the sphere from the box.\" " "" "> Action: Injecting V-Code Dictionary..." "> Note: Raw text streams must be decoded via \U+15B4.")) (setq vcode_raw (strcat v_l "," v_w "," v_h " \U+15B4 \U+1676 " v_r " \U+15B4 \U+167A \U+15E3")) ) ) (start_list "prompt_view") (mapcar 'add_list prompt_data) (end_list) ) (defun build-stack () (cond ((= task "rb_box") (setq log_l (list (strcat v_l "," v_w "," v_h) "\U+15B4" "\U+1676") log_r (list (strcat "-> PUSH: \"" v_l "," v_w "," v_h "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(3 Scalars)" "-> EVAL: \U+1676 (Rune 'Tot' / 3D BOX)" " | POP(3), Evaluate vla-addbox, PUSH(Ptr_Solid_A)")) ) ((= task "rb_sph") (setq log_l (list v_r "\U+15B4" "\U+167A") log_r (list (strcat "-> PUSH: \"" v_r "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(1 Scalar)" "-> EVAL: \U+167A (Rune 'Kok' / SPHERE)" " | POP(1), Evaluate vla-addsphere, PUSH(Ptr_Solid_A)")) ) ((= task "rb_hol") (setq log_l (list (strcat v_l "," v_w "," v_h) "\U+15B4" "\U+1676" v_r "\U+15B4" "\U+167A" "\U+15E3") log_r (list (strcat "-> PUSH: \"" v_l "," v_w "," v_h "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(3 Scalars)" "-> EVAL: \U+1676 | Draw BOX -> PUSH(Ptr_Solid_A)" (strcat "-> PUSH: \"" v_r "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(1 Scalar)" "-> EVAL: \U+167A | Draw SPHERE -> PUSH(Ptr_Solid_B)" "-> EVAL: \U+15E3 | SUBTRACT (A-B) -> PUSH(Ptr_Final)")) ) ) ) ;; Main Event Loop (if (>= (setq dcl_id (load_dialog dcl_tmp)) 0) (progn (while (and (> step 0) (<= step 3)) (if (new_dialog (strcat "va_step" (itoa step)) dcl_id) (progn (cond ((= step 1) (set_tile task "1") (set_tile "v_l" v_l) (set_tile "v_w" v_w) (set_tile "v_h" v_h) (set_tile "v_r" v_r) (update-prompt) (action_tile "task" "(update-prompt)") (action_tile "v_l" "(update-prompt)") (action_tile "v_w" "(update-prompt)") (action_tile "v_h" "(update-prompt)") (action_tile "v_r" "(update-prompt)") (action_tile "next" "(done_dialog 2)") ) ((= step 2) (set_tile "vcode_view" (strcat "[VCODE] " vcode_raw " [/VCODE]")) (set_tile "token_met" (strcat "> V-Code Matrix consumed: " (itoa (length (VA:Split vcode_raw " "))) " Tokens (Compression: 97.4%)")) (action_tile "back" "(done_dialog 1)") (action_tile "next" "(done_dialog 3)") ) ((= step 3) (build-stack) (start_list "log_l") (mapcar 'add_list log_l) (end_list) (start_list "log_r") (mapcar 'add_list log_r) (end_list) (action_tile "back" "(done_dialog 2)") (action_tile "next" "(done_dialog 4)") ) ) (action_tile "cancel" "(done_dialog 0)") (setq res (start_dialog)) (setq step (if (>= res 0) res 0)) ) (setq step 0) ) ) (unload_dialog dcl_id) ) ) (vl-file-delete dcl_tmp) (if (= step 4) (progn (princ (strcat "\n[V-Code] Received Native Payload: " vcode_raw)) (princ "\n[V-Code] AST collapsing to physical reality...") (VA:RunVCode vcode_raw) (princ "\n[Success] Spatial execution complete.") ) ) (princ) ) (princ "\n[VedaCAD/v-code] Sandbox loaded. Type VAGENT to launch the Simulator.") (princ) The above code can also be installed and used through VedaCAD developed by me via VCID: PLG96B The full 256 token V-Code is open-sourced on GitHub: https://github.com/VedaCAD/v-code Would love to hear your thoughts. Enjoy the sandbox! Note: English is not my native language. I use Google AI to translate and polish my posts to ensure clarity and respect for the community's technical depth. -
Thank you. Sorry it took me awhile to respond. I got something to sink my teeth into. I worked on it before I recieved your reply. The ctb file is different from others I have used, thus my quest to print something out. I have attached the dwg file, see the layout tabs. I have made suggestions to add additional lineweights on the lineweights tab. We'll see if this falls flat or not. Don't look at all the layers they may frighten you.... quite a few repeats. general kip ctb.dwg
ACTCAD changed their profile photo -
Make it stop! autosaving in the middle of a command
SLW210 replied to MikeP's topic in AutoCAD General
Never have I needed Autosave. CTRL+S is just a habit now, even in non-AutoCAD programs. I also frequently Right-Click one of the Drawing Tabs and select Save All. I also know the difference between Qsave and Save and use both appropriately. (Note: they are the same in AutoCAD LT or used to be, I am not sure about newer LT versions) Saving your work is your job, not AutoCAD's. I wonder if a LISP with a reactor would be less troublesome for those that do not trust going without an Autosave? Or maybe this? A Better Autosave | AfraLISP Or... (command ".save") to Visual LISP - AutoLISP, Visual LISP & DCL - AutoCAD Forums Or... make a copy of current open drawing & place it into a predetermine folder - AutoLISP, Visual LISP & DCL - AutoCAD Forums And... LISP - Automatic Save that runs at set intervals -
ketxu started following Dynamic blocks with Dynamic text and count
ketxu replied to Shri95's topic in AutoCAD Drawing Management & Output
You have to make two Field, once for Distance of Block, then Once for Arrray Object (item or column * row). Cause an Array Object now is include all block, all Field of length in per Array is fixed -
tanmay.lakhan joined the community
Danielm103 started following Python, Change precision of all fields in a drawing
Danielm103 posted a topic in .NET, ObjectARX & VBA
from pyrx import Ap, Ax, Db, Ed, Ge, Br def getAllFieldsIds(db: Db.Database): ids: list[Db.ObjectId] = [] nod = Db.Dictionary(db.namedObjectsDictionaryId()) fieldListId = nod.getAt("ACAD_FIELDLIST") fieldList = Db.Core.entGet(fieldListId) for fieldItem in fieldList: if fieldItem[0] == 330 and fieldItem[1].isDerivedFrom(Db.Field.desc()): ids.append(fieldItem[1]) return set(ids) @Ap.Command() def doit() -> None: db = Db.curDb() field_ids = getAllFieldsIds(db) for id in field_ids: field = Db.Field(id, Db.OpenMode.kForRead) fmt = field.getFormat() if 'pr3' in fmt: field.upgradeOpen() new_fmt = fmt.replace('pr3', 'pr4') field.setFormat(new_fmt) field.evaluate(Db.FieldEvalContext.kDemand, db) print(f"Updated field format from {fmt} to {new_fmt}")-
- 1
alankst101 joined the community
@CamDuy gave it a try it appears to only look for a text object the OP wants an attribute in a block also to be updated.
Ms. Brittany joined the community
rkmcswain replied to MikeP's topic in AutoCAD General
Agreed. I am 100% on the side of [turn Autosave OFF] and use one of the many ways to save your data file every time you do something you don't want to lose. -
rkmcswain started following Make it stop! autosaving in the middle of a command
@RobDraw - or 8 more years later ? -
Try it! CFP_ChangeFieldPrecision.lsp
Insert a copy of the block at the specified point. CopyRenameBlockV1-5.lsp /Lee Mac/
Wow! It's super! Thanks!!! @CamDuy -
PollyannaDraws joined the community
PollyannaDraws replied to MikeP's topic in AutoCAD General
So did you ever figure out how to do it, OP? I don't know how someone doesn't manually save like every 5 min. I can tell now that this is not a natural reaction for everyone. I am a millennial and it's been metaphorically beaten in my head throughout my all school years to save often. I save after every small bit of changes that I make. Hope you found a way that works for you, though!! -
tusupbek joined the community
This is a simple ranking list, showing how many plugins or bundles you have released as a creator or curator, and how many times these plugins or bundles have been downloaded in total. -
ceejayy joined the community
zeluyvenca joined the community
BIGAL replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
Just a comment one option I did not see is a plot range I have a simple plot lisp it asks for start layout and end layout handy to plot one or more. Perhaps even 1-2,7-8,12 plots multiple layouts as suggested. Also what about Bricscad version it has BRX not ARX. -
BIGAL replied to Danielm103's topic in Application Beta Testing
My Bricscad after appload, yes brx and xrc are in a support path. I moved that path to top of support path list. Then appload. Version V25.2.06 I checked the download files and looked at properties and ticked off the "Unlock" file as this sometimes does what it says. I have tried unloading and that fails not sure why. Sent you a pm with my email. - Last week
I checked and indeed there are some similarities, but the overall logic may be different. Thank you for the information. -
CivilTechSource replied to VicoWang's topic in AutoLISP, Visual LISP & DCL
That is cool! But didn't AutoCAD 2027 released something tiny bit similar (project workspace?) -
VedaCAD is still a relatively new platform and client. Thank you to everyone who has been testing the offline Base Mode of our client—your suggestions and bug reports are highly welcome. Under offline BASE Mode, the client will never actively connect to the internet, making it convenient for those who need a purely local, long-term tool without network dependencies. I'd really love to introduce the "Online" side of our platform today. Our user tiers are generally divided into 6 levels: BASE, FREE, PRO, TEAM, CORP, and CORP (DED). They are all unified within a single client (the .vlx file shared above). Apart from the BASE mode, the other 5 tiers require periodic internet connectivity. Before diving into the tiers, I want to mention our online account system. There are no passwords in our system, We primarily support four login methods: OAuth Login: Currently supporting Google, Microsoft, and Autodesk platforms. Magic Links: Enter any email address to receive a real-time, secure login link. OIDC (SSO): Supported exclusively for the two CORP tiers (e.g., Auth0, Microsoft Entra ID). Client Reverse-Login: Once logged into the CAD client, your machine acts as a hardware identity token. Anytime you click the Manage or SOPs (for enterprise employees) button in the client, it securely bypasses passwords and logs you straight into your Web Portal. BASE Tier: As you have seen, you can mount local LSP, FAS, and VLX plugins. The maximum size per asset is capped at 1MB (which is more than enough for pure LISP scripts), and the client acts as a proxy loader. We guarantee that the BASE mode will never actively initiate network requests., and there are absolutely no quantitative limits for local use (no limit on mounted assets, no limit on config imports/exports). FREE Tier: This is our community edition for individuals and students. You just need to register a free account. It supports the same LSP, FAS, and VLX formats (local or via VCID), but the single asset limit is raised to 3MB. This tier is free forever. Besides managing local assets, FREE users can publish assets to generate and share VCIDs. You can also combine your published assets with downloaded plugins to create a bundle, generating a B- prefix VCID. You or anyone with this Bundle VCID can input it via "Install via VCID" to batch-pull the entire toolkit. (Note: If a FREE user pulls a bundle created by a PRO user that contains ARX or DLL files, the system will actively drop those advanced formats).For example, the following two real testable plugins: [Codebase Packer] VCID: 0FBGZB @ VedaCAD [Quick Annotator] VCID: 7JAU18 @ VedaCAD In addition to format and size limits, FREE users have a generous cap of publishing up to 50 assets per day. What happens if you delete your account? This is something you need to know, and I’ll try to explain it clearly. We will execute compliant data anonymization. If an asset you published was only ever used by you, it will be destroyed from our system. If your asset was downloaded at least once by someone else (especially if an enterprise incorporated it into their asset pool), the physical plugin will remain in the system, but the author will be fully anonymized. This ensures the stability of the entire CAD ecosystem so someone else's workflow doesn't suddenly break because a plugin vanished. PRO Tier: This is designed for professionals. Besides the features in the FREE tier, the main differences are: Single asset size limit is increased to 15MB to accommodate ARX and DLL plugins. Asset format support is aligned with the Enterprise matrix. Plugins include: LSP, FAS, VLX, ARX, DLL. Environment configs include: CTB, STB, DWT, SHX, PAT, LIN, TXT, XML, JSON, INI, PGP, SCR, CUIX, DWS, PC3, PMP, ATC. (Note: All environment config files can only be published as private assets requiring authentication. Essentially, they are for your own use—even if someone knows your VCID, their download will be blocked). Tip-Jar Linking: If a PRO user configures a sponsor link, a tip button will appear in these locations: upon first download, via a dedicated toast popup when the command finishes executing 24 hours after installation, when the asset is selected in the manager, during bundle pulling, and on the user's public profile (if visible, e.g., vedacad.com/@vico). You can also connect Webhooks (Discord, Slack) to receive real-time tipping intent notifications. Can accept and mount ARK- Project Ark Visas issued by General Contractors to sync environmental standards. Push Updates: You can push updates to your plugins (e.g., patching to v1.1 with a new file) without changing the distributed VCID. On the user's end, the update will execute manually or automatically based on their workspace policy. Personal Cloud Config Sync: You can PUSH your entire local state to the cloud and PULL it on a new PC for a sub-second full environment restoration. What you need to know about cloud sync: even absolute local paths (e.g., D:/CADTools/abc.lsp) are mapped and synced. As long as the new PC has that file in the same D-drive path, the migration is complete. (Note: Ark Visas are strictly isolated and are never synced via cloud config). Syncing is a manual action to avoid overriding correct setups. We provide three strategies: push local to cloud, pull cloud to local, and smart merge. If unsubscribed, you naturally downgrade to the FREE tier. Account deletion follows the FREE tier rules. TEAM, CORP, CORP (DED) Tiers: These are our Enterprise tiers. Note that when a TEAM+ tier expires, the workspace is physically frozen (Archived), not downgraded to FREE, because enterprise data structures are fundamentally different. Here is the general enterprise logic flow: The Foundry (Enterprise Asset Pool): When an admin adds and publishes an asset in the client, it is pushed to the web-based Enterprise Foundry. Admins can also mount external VCIDs (from independent devs) or Ark Visas into this pool. This is a centralized, pending-allocation list. Admins can attach SOPs (Standard Operating Procedures) to environment files and plugins (including external ones). Our system supports GIF + Markdown for SOPs. Internal Squads: Admins create groups (e.g., Architecture Squad) and assign employees and assets to them. An employee might belong to multiple squads simultaneously; our algorithm deduplicates their assets. When the employee logs into the CAD client, the unified asset list is silently deployed to their local sandbox. On the next heartbeat or manual sync, the client checks for missing files or updates and executes silent replacements. The SOPs button in the employee's panel links directly to the online SOPs of their assigned assets. Admins can also monitor the "Out of Sync" status of any specific plugin for any employee via the dashboard. Project Arks: Arks are decoupled from the main enterprise seats. You might have a 20-seat Enterprise plan but purchase 100 Ark slots because Arks manage external sub-contractors. Arks are strictly limited to environment config files (no executable plugins allowed). GCs issue Visas to external PRO users or sub-contracting firms. Arks have expiration dates and a unique Paid Archive Status: For a retainer fee (monthly/yearly), the Ark version is frozen (e.g., snapshotted on July 30, 2026), and includes 2 maintenance slots. If modifications are needed in 2028, the GC issues the 2 slots, and the sub-contractors will pull the exact environment state from that archived day (even if the active config has iterated to v2.0 since then). Employee Onboarding: TEAM relies on Magic Links. CORP allows direct OIDC (SSO) login, but employees enter a buffer pool awaiting admin approval before consuming a paid seat. Domain Hegemony: Our system anchors enterprise ownership to the corporate email domain. If an employee previously registered a personal FREE or PRO account using their corporate email, when the Enterprise workspace is created, their next login will trigger a forced choice: DESTROY their personal space to join the enterprise, or SPLIT (transfer) their PRO assets and billing to a personal email (like Gmail), leaving the corporate email clean for enterprise approval. This ensures absolute domain sovereignty. Tier Differences: TEAM includes SOPs, Magic Links, and on-demand Arks. CORP includes all TEAM features plus SSO, BYOS (S3) (add-ons) storage mounting, and EDR(add-ons) sandbox threat interception. CORP (DED) is identical to CORP but operates on an isolated, dedicated physical database tenant (requires manual admin deployment). If you are interested in the enterprise features, you can check out our Enterprise Dashboard Demo by clicking the Get Demo button next to the TEAM or ENTERPRISE cards at vedacad.com/pricing. -
CamDuy replied to Nikon's topic in AutoLISP, Visual LISP & DCL
CopyRenameBlockV1-5_byCamDuy.lsp Try using this file. @Nikon -
Thank you for your feedback. I will update the version for 2014 and earlier. -
VicoWang replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
When I develop vedacad, it is different. My main coding and compilation are done on 2006, avoiding the use of advanced features and ensuring that vedacad can punch through all versions of 2026 from 2006. However, it is true that most people have already done their daily work on the higher version. My test environment is 2006,2014 and 2022. -
Drop me an email "phantrongduybn@gmail.com" I'll send it to you. -
I think AutoCAD 2014 is too old; versions from 2015 onwards work just fine. because it was built on a higher version. -
Nikon replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
The link doesn't work for me, could you please attach the archive? -
I tried using it with VedaCAD, and it didn't work in 2014 but ran perfectly in 2022. I thought it was a problem with the VedaCAD proxy, so I loaded the VLX file from the cache separately, and it still didn't work in 2014 but could run in 2022. Does this plugin have a minimum version requirement? -
povilasltu joined the community
MAQBOOL AHMED joined the community
Danielm103 replied to Danielm103's topic in Application Beta Testing
Also, make sure the xrc file is in the same folder, if you moved the BRX
