indiancad started following BIGAL
Anindita joined the community
How do you handle very small details in a 3D model?
BIGAL replied to indiancad's topic in AutoCAD 3D Modelling & Rendering
@SLW210 yes lots of posts maybe need a "How do you" sub section. Maybe all posts should be in the "Autocad Beginners Area". -
Maybe this UCSORG set origin point to say a object point. UCSICON ON will display corner icon for current UCS.
indiancad started following Do you check the drawing units before starting work on a DWG?
Why does a 3D solid become difficult to edit after using UNION?
You're so welcome! It’s one of those things where having a few different workflows in your back pocket makes a huge difference, especially when a Boolean operation doesn't quite give you what you expected. -
Why does FILLETEDGE fail on some 3D solid edges?
Yeah ! but I was referring more to cases where the operation still fails despite adjusting the radius, particularly around complex geometry. I also see your point about using FILLET for regular edges. Thanks for the clarification. -
I understand your point. I can see that my posts have been repetitive in style, and I apologise for that. I'll take more care to contribute genuine experiences and useful technical information rather than creating similar discussions. Thank you for the feedback. -
Why does LOFT sometimes twist or fail unexpectedly?
I apologize for this and I can see how my repeated posts have come across as repetitive and spam-like. That wasn't my intention, but I understand the concern. I'll stop creating new threads for now and be much more careful about checking existing discussions before posting again. and thanks for pointing this out. -
Before sharing a model, I find it useful to check critical dimensions with MEASUREGEOM, inspect the part from multiple views, and verify that the geometry is suitable for the intended process. A visual check alone may not catch every issue. What checks do you normally perform before releasing a 3D model for manufacturing? -
Teduap joined the community
DPE4JC joined the community
anfinton254 joined the community
Using the folding grip in notepad++ does work. However you cannot select that way on any line, only the one with a grip. So the AHK routine, does not break any of the native N++ shortcuts and let you highlight any code or portion of code as long as it is between brackets. (Brackets ( ), { }, [ ] ) ymg
Paul Li started following ucs and drawing problem
Looks like your 1st dwg might not be in plan and 2d wire view. Try this sequence of command: _.VSCURRENT 2 _.Plan _W
Lisp Code for transforming list number to numbered block?
dber replied to dber's topic in AutoLISP, Visual LISP & DCL
This looks amazing! Thank you so much! I did notice a couple random multi-line blocks were placed on the 1st line, but other than that this is amazing! -
that is green line , after zoom Extents application , this shows away from ucs ( y-axis ). what to do to solve it ?
Yes, that's right, in this case it's a car roof that needs to be made without defects. I have been using Solidworks relatively recently, I am not a professional, but I am interested in 3D modeling and I want to develop in this. I decided to contact the forum because this is not the first time I have encountered the problem of creating and controlling just such a form (examples p1.jpg, p2.jpg) and I have not been able to understand how such a form can be made without defects. In this case, the roof has a shape: D1.jpg, mesh v2.The SLDPRT is based on this drawing, but as I now understand it, this construction approach is not correct. The video presents how I understand polygonal modeling. I would like to understand how this form can be done in the classic Solidworks approach
green line is line of y-axis of ucs , it is not a separate object. i have to bring this view in a form as that of new drawing, where green line ( of ucs ) is normal,
See if it makes a difference if you completely docked the command prompt instead of having it floating at the bottom
What's the "green line"? Hard to tell anything from an image. Please explain better or post the .dwg.
AU 2026 may be over, but the learning doesn’t have to stop. This year’s Autodesk University brought the global Design & Make community together to explore new ideas, sharpen skills, and see what’s next across industries. Now, AU 2026 sessions are available to watch on demand, so you can catch up on the AutoCAD content you missed, or revisit a favorite session whenever it works for you. From practical drafting techniques and the latest AutoCAD capabilities to AI, customization, connected data, specialized toolsets, and manufacturing workflows, there’s plenty to explore. Ready to start watching? We’ve rounded up AutoCAD sessions from AU 2026 to add to your list. Explore AU 2026 sessions on demand Discover What’s New and Work Smarter in AutoCAD AEC Roadmap: AutoCAD Get a closer look at what’s next for AutoCAD with the AutoCAD product team. This roadmap session explores the latest enhancements and previews upcoming capabilities designed to evolve the way you design and draft. Hear more about improvements across collaboration and AI-powered productivity, the product strategy guiding AutoCAD development, and how customer feedback continues to help shape what comes next. Watch AEC Roadmap: AutoCAD on demand AutoCAD Tips, Tricks, and the Most-Human Drafting Techniques There’s always another AutoCAD trick to discover. Autodesk Expert Elite member Donnie “The CAD Geek” Gladfelter returns with the ninth installment of his popular AU AutoCAD Tips session, packed with practical techniques for getting more done. Explore AutoCAD 2027 features including Geometry Cleanup, Smart Blocks, and Checkout, along with workflows for reducing repetitive manual processes, accelerating drawing delivery, and cutting down on rework. Whether you’re looking for new features or those deep-cut techniques that only come from years of AutoCAD experience, this is one to bookmark. Watch AutoCAD Tips, Tricks, and the Most-Human Drafting Techniques on demand Connect AutoCAD and Your Project Data AutoCAD and Autodesk Forma: A CAD Manager’s Playbook for Connected Project Data For CAD managers, keeping project files, references, standards, and team workflows connected can be a challenge. This session explores how Autodesk Forma Data Management Essentials can connect desktop AutoCAD workflows with unified, cloud-based project data. Take a closer look at Connected Support Files, Connected References, Connected Sheet Set Manager, Checkout, and other capabilities designed to help teams reduce friction and keep shared project data organized as work evolves. Watch the connected project data session on demand From AutoCAD Toolsets to Inventor: Enabling Connected Workflows with Desktop Connector and Forma See how AutoCAD Electrical, AutoCAD Mechanical, Inventor, Desktop Connector, and Autodesk Forma can work together to create more connected manufacturing workflows. Through practical examples, this session explores ways to coordinate electromechanical data, connect 2D layouts with 3D models, reuse design information, and maintain data continuity as work moves between tools. The goal: fewer disconnected processes and less duplication and rework. Watch the connected manufacturing workflows session on demand Get More from AutoCAD Toolsets Accelerating Manufacturing Design: Unlocking the Top 10 Hidden Productivity Tools in AutoCAD Mechanical How much of AutoCAD Mechanical are you really using? Sridhar Subramani, Sr. Principal Product Owner at Autodesk, highlights 10 productivity tools designed to help manufacturing teams reduce repetitive drafting and get more from the toolset included with their AutoCAD subscription. See intelligent drawing commands, automated hidden-line management, parametric content libraries, power dimensioning, GD&T and welding symbols, integrated BOMs, engineering calculators, associative 2D documentation of Inventor models, and more in action. Watch the AutoCAD Mechanical session on demand Unlock the Power of AI for AutoCAD 2027 Toolsets Curious about where AI fits into CAD workflows? This technical deep dive explores AI-powered approaches across AutoCAD 2027 toolsets, with a focus on using automation to make complex and repetitive work more efficient. The session covers topics including intelligent object recognition, predictive drafting, automated dimensioning, interoperability, and other ways AI can support designers as they tackle everyday workflows. Watch Unlock the Power of AI for AutoCAD 2027 Toolsets on demand Explore AI, Automation, and AutoCAD Customization Ask the Experts Panel: AI in AutoCAD and Civil 3D, From Today’s Tools to Tomorrow’s Workflows Curious how AI is actually showing up in AutoCAD, AutoCAD Web, and Civil 3D? This expert panel looks beyond the hype to explore how AI is beginning to change everyday design workflows and support faster, smarter decisions. Explore where AI appears in workflows today, how Autodesk Assistant is evolving with Model Context Protocols (MCPs), and where AI may be headed as a more active partner across desktop and web. You’ll also come away with practical ideas for putting AI to work now, along with the opportunities and open questions to watch. Watch Ask the Experts: AI in AutoCAD and Civil 3D on demand Boosting Autodesk Development Using AI with AutoLISP and C# .NET If you customize AutoCAD—or want to start—this session looks at how AI can become a practical coding assistant for your development workflow. Learn approaches for using AI to generate AutoLISP routines and C# .NET code, support debugging and code translation, and accelerate plug-in development. Just as importantly, the session explores how to evaluate and validate AI-generated code before integrating it into your projects. Watch the AI, AutoLISP, and C# .NET session on demand A.I. Without Chaos: AutoCAD and Revit Plugin Development with Spec-Driven Development AI can help developers move faster, but maintaining consistency and reliability is just as important. Fernando Malard, Chief Technology Officer at ofcdesk, LLC, introduces Spec-Driven Development as a structured approach to AI-assisted plug-in development. Using AutoCAD and Revit plug-ins as examples, the session explores how persistent specifications can provide a source of truth, how separating business logic from platform-specific APIs can improve maintainability, and how teams can make AI-generated code more consistent and reviewable. Watch A.I. Without Chaos on demand Keep Learning with AU 2026 On Demand Whether you want to discover a new AutoCAD technique, see what’s coming next, connect your design data across tools, get more from the specialized toolsets, or explore how AI can support your workflows, AU 2026 gives you plenty of opportunities to keep learning long after the conference. And you don’t have to watch everything at once. Choose the sessions most relevant to the way you work, learn at your own pace, and come back whenever you’re ready for more. Explore all AU 2026 sessions on demand Happy watching! The post Watch Now: AU 2026 AutoCAD Sessions On Demand appeared first on AutoCAD Blog. View the full article
Danielm103 started following Python, Export manhole data to excel.
Testing a new version of PyRx’s KDTree. Maybe a useful example import traceback import pandas as pd from pyrx import Ap, Db, Ge, Ed @Ap.Command() def doit(): try: # 1. Select the text and block objects in AutoCAD ps, ss = Ed.Editor.select([(0, "MTEXT,INSERT")]) if ps != Ed.PromptStatus.eOk: return # 2. Extract block positions for spatial matching pnts = Ge.Point3dArray() for blkid in ss.objectIds(Db.BlockReference.desc()): blkref = Db.BlockReference(blkid) pnts.append(blkref.position()) # Build a spatial K-d tree to find the nearest block for each MText tree = Ge.Point3dTree(pnts) # 3. Process matched data into a structured list rows = [] for tid in ss.objectIds(Db.MText.desc()): mt = Db.MText(tid) indexes, _distances = tree.knnSearch(mt.location(), 1) if indexes: row_data = {} nearest_pt = pnts[indexes[0]] # split TODO: /P text_lines = mt.text().splitlines() for idx, line in enumerate(text_lines): row_data[f"Line_{idx + 1}"] = line row_data["Block_X"] = round(nearest_pt.x, 2) row_data["Block_Y"] = round(nearest_pt.y, 2) row_data["Block_Z"] = round(nearest_pt.z, 2) rows.append(row_data) df = pd.DataFrame(rows) print(df) output_file = "e:/temp/output_cad_data.xlsx" df.to_excel(output_file, index=False, sheet_name="CAD Extract") print(f"Successfully exported {len(df)} rows to {output_file}") except Exception as e: traceback.print_exc()
I am not exactly sure what your question is about, are you trying to create something similar to what's in V1? It seems to be something like the roof or hood of an automobile, is that correct? Are trying to freehand this or is there a sketch you started with? It would help to list the approaches you have tried so far. How long have you been using Solidworks? Here is a YouTube video for a Mini Cooper, this starts on #12 for the roof... How to make car roof in SolidWorks | Part 12 (Mini Cooper)| Modelling car roof
hi to all , i created a 100 ft wide rectangle, and applied zoom extents, saved and closed drawing. when i reopened drawing , green line was not collinear to y-axis. zoom previous did not worked. any solution to that ?
ABDERRAHIM UNIARCHI joined the community
Steven P started following New AutoCAD Museum Forum
Didn't notice this one before - The Smaller Boy has a pad like this - I am tempted to give it a go
shibuasharaf joined the community
Spot on! You found it. Yes, it is 100% by design. Enjoy! -
BIGAL replied to dber's topic in AutoLISP, Visual LISP & DCL
Made the notes in Word with a hexagon font. The indents are Character plus a period, that is why second hexagon appears, looking at setting Word style not "A." but "A" only. Can do numbers as well. Copied to Bricscad but the font is not supported in Bricscad to old a font, yes found that out. removed period from bullet style. If you open your notes in word should be able to reset the bullets and save then into MTEXT. In Bricscad with a bit of care you can highlite the bullet character and change it to another font, ie a hexagon font. Hopefully only need to do once. and save your notes, then you add or remove paragraphs. The one above is called HEX:gon Expanded. Above 9 get two hexagons. A-Z is ok tested on Word Doc. -
Romero replied to dber's topic in AutoLISP, Visual LISP & DCL
code: ;;; HEXENUM 1.5.1 | CN: markers beside unchanged MTEXT | CNC: relocated paragraphs. ;;; CNR: renumber existing markers; CN replaces recognized markers in the left column. ;;; Base block: side 0.1801, NUM height 0.10; insertion scale = MTEXT height / 0.10. ;;; Single line: centered. Wrapped paragraph: centered on its first two lines. ;;; Existing block definitions are never cleared/redefined. Compatible ones are reused. ;;; SOLID fill ACI 255. Uniform XYZ scale, non-explodable block. AutoCAD Windows. ;;; Single-column, non-annotative MTEXT on WCS XY; no fields or vertical writing. ;;; Complex mixed-height/stacked text needs visual verification of line placement. (vl-load-com) (defun R0:CN-Fail (msg) (setq cn-msg msg) (exit)) (defun R0:CN-Prefix (frames / result frame) (setq result "") (foreach frame (reverse frames) (setq result (strcat result "{" frame))) result) (defun R0:CN-Close (frames / result) (setq result "") (repeat (length frames) (setq result (strcat result "}"))) result) (defun R0:CN-Records (s / i n ch next token frames part visible result j brk start) (setq i 1 n (strlen s) frames (list "") part "{" visible nil) (while (<= i n) (setq start i ch (substr s i 1) next (substr s (1+ i) 1) brk nil) (cond ((or (= ch (chr 10)) (= ch (chr 13))) (setq brk T) (if (and (= ch (chr 13)) (= next (chr 10))) (setq i (1+ i))) (setq i (1+ i))) ((= ch "\\") (cond ((= next "P") (setq brk T i (+ i 2))) ((= next "N") (R0:CN-Fail "Column breaks found. Set the MTEXT to a single column.")) ((member next '("\\" "{" "}" "~")) (setq part (strcat part (substr s i 2)) i (+ i 2)) (if (/= next "~") (setq visible T))) ((member next '("A" "C" "c" "F" "f" "H" "Q" "T" "W" "p" "S")) (setq j (+ i 2)) (while (and (<= j n) (/= (substr s j 1) ";")) (setq j (1+ j))) (if (> j n) (R0:CN-Fail "Incomplete MTEXT formatting code.")) (setq token (substr s i (1+ (- j i))) part (strcat part token) i (1+ j)) (if (= next "S") (setq visible T) (setq frames (cons (strcat (car frames) token) (cdr frames))))) ((member next '("L" "l" "O" "o" "K" "k")) (setq token (substr s i 2) part (strcat part token) i (+ i 2) frames (cons (strcat (car frames) token) (cdr frames)))) ((and (= next "U") (= (substr s (+ i 2) 1) "+")) (setq part (strcat part (substr s i 7)) i (+ i 7) visible T)) (T (setq part (strcat part ch) i (1+ i) visible T)))) ((= ch "{") (setq frames (cons "" frames) part (strcat part ch) i (1+ i))) ((= ch "}") (if (null (cdr frames)) (R0:CN-Fail "Unbalanced formatting braces.")) (setq frames (cdr frames) part (strcat part ch) i (1+ i))) (T (setq part (strcat part ch) i (1+ i)) (if (not (member ch (list " " (chr 9)))) (setq visible T)))) (if brk (progn (if visible (setq result (cons (list (strcat part (R0:CN-Close frames)) (1- start) (R0:CN-Close frames)) result))) (setq part (R0:CN-Prefix frames) visible nil)))) (if (/= (length frames) 1) (R0:CN-Fail "Unbalanced formatting braces.")) (if visible (setq result (cons (list (strcat part (R0:CN-Close frames)) n (R0:CN-Close frames)) result))) (reverse result)) (defun R0:CN-Split (s) (mapcar 'car (R0:CN-Records s))) (defun R0:CN-Normalize (s) (while (vl-string-search (strcat (chr 13) (chr 10)) s) (setq s (vl-string-subst "\\P" (strcat (chr 13) (chr 10)) s))) (while (vl-string-search (chr 13) s) (setq s (vl-string-subst "\\P" (chr 13) s))) (while (vl-string-search (chr 10) s) (setq s (vl-string-subst "\\P" (chr 10) s))) s) (defun R0:CN-Register (obj) (setq cn-created (cons obj cn-created)) obj) (defun R0:CN-Box (obj / lo hi) (vla-Update obj) (vla-GetBoundingBox obj 'lo 'hi) (list (vlax-safearray->list lo) (vlax-safearray->list hi))) (defun R0:CN-Props (obj src) (vla-put-Layer obj (vla-get-Layer src)) (vla-put-TrueColor obj (vla-get-TrueColor src)) obj) (defun R0:CN-Text (space src content width h at attach / obj) (setq obj (R0:CN-Register (vla-AddMText space (vlax-3d-point at) width content))) (R0:CN-Props obj src) (vla-put-StyleName obj (vla-get-StyleName src)) (vla-put-Height obj h) (vla-put-Rotation obj 0.0) (vla-put-AttachmentPoint obj attach) (vla-put-InsertionPoint obj (vlax-3d-point at)) (vla-put-LineSpacingStyle obj (vla-get-LineSpacingStyle src)) (vla-put-LineSpacingFactor obj (vla-get-LineSpacingFactor src)) obj) (defun R0:CN-CenterY (obj box cy / mid) (setq mid (/ (+ (cadar box) (cadadr box)) 2.0)) (vla-Move obj (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list 0.0 (- cy mid) 0.0))) obj) (defun R0:CN-Discard (obj) (vla-Delete obj) (setq cn-created (vl-remove obj cn-created))) (defun R0:CN-Initial (/ s n valid) (while (not valid) (setq s (getstring (strcat "\n" cn-label " | Starting NUMBER <1>: "))) (if (= s "") (setq s "1")) (if (and (<= (strlen s) 9) (vl-every '(lambda (c) (and (>= c 48) (<= c 57))) (vl-string->list s))) (setq n (atoi s) valid T) (princ "\nEnter an integer from 0 to 999999999."))) n) (defun R0:CN-Annotative (ename / data) (setq data (assoc -3 (entget ename '("AcadAnnotative")))) (and data (member '(1070 . 1) (cdr (cadr data))))) (defun R0:CN-Select (/ pick en data layer done) (while (not done) (setvar "ERRNO" 0) (setq pick (entsel (strcat "\n" cn-label " | Select the MTEXT to number <Exit>: "))) (cond ((and (null pick) (= (getvar "ERRNO") 7)) (princ "\nNothing selected. Click the MTEXT again; Enter exits.")) ((null pick) (setq done T en nil)) (T (setq en (car pick) data (entget en) layer (if data (tblsearch "LAYER" (cdr (assoc 8 data))))) (cond ((null data) (princ "\nObject no longer available. Select another MTEXT.")) ((/= (cdr (assoc 0 data)) "MTEXT") (princ "\nSelect an MTEXT object, not single-line text or a block.")) ((null layer) (princ "\nCannot read the object layer. Select another MTEXT.")) ((/= 0 (logand 5 (cdr (assoc 70 layer)))) (princ "\nThe MTEXT layer is locked or frozen. Select another MTEXT or press Enter to exit.")) ((minusp (cdr (assoc 62 layer))) (princ "\nThe layer is turned off.")) (T (setq done T)))))) en) (defun R0:CN-Scale (height) (/ height 0.10)) (defun R0:CN-Side (height) (* 0.1801 (R0:CN-Scale height))) (defun R0:CN-Height (box) (- (cadadr box) (cadar box))) ;;; Safe prefix boundaries: never cut a formatting code, Unicode escape or stack. (defun R0:CN-Cuts (s / i n ch nx j depth visible cuts) (setq i 1 n (strlen s) depth 0) (while (<= i n) (setq ch (substr s i 1) nx (substr s (1+ i) 1) visible nil) (cond ((= ch "{") (setq depth (1+ depth) i (1+ i))) ((= ch "}") (setq depth (1- depth) i (1+ i))) ((= ch "\\") (cond ((member nx '("A" "C" "c" "F" "f" "H" "Q" "T" "W" "p" "S")) (setq j (+ i 2)) (while (and (<= j n) (/= (substr s j 1) ";")) (setq j (1+ j))) (if (> j n) (R0:CN-Fail "Incomplete paragraph formatting.")) (setq i (1+ j) visible (= nx "S"))) ((and (= nx "U") (= (substr s (+ i 2) 1) "+")) (setq i (+ i 7) visible T)) ((member nx '("L" "l" "O" "o" "K" "k")) (setq i (+ i 2))) (T (setq i (+ i 2) visible T)))) (T (setq i (1+ i) visible (not (member ch (list " " (chr 9))))))) (if visible (setq cuts (cons (list (1- i) depth) cuts)))) (reverse cuts)) (defun R0:CN-PrefixAt (s cut / out) (setq out (substr s 1 (car cut))) (repeat (cadr cut) (setq out (strcat out "}"))) out) ;;; Measure the first rendered wrap using balanced prefixes of the actual paragraph. ;;; Uses the source font, width and line spacing; no hard-coded interline distance. (defun R0:CN-AnchorOffset (probe paragraph fullHeight / cuts firstHeight threshold low high mid sample twoHeight) (setq cuts (R0:CN-Cuts paragraph)) (if (not cuts) (R0:CN-Fail "Cannot measure an empty paragraph.")) (vla-put-TextString probe (R0:CN-PrefixAt paragraph (car cuts))) (setq firstHeight (R0:CN-Height (R0:CN-Box probe)) threshold (+ firstHeight (* 0.20 firstHeight))) (if (<= firstHeight 1e-12) (R0:CN-Fail "Cannot measure the first line of text.")) (if (<= fullHeight threshold) (/ fullHeight 2.0) (progn (setq low 0 high (1- (length cuts))) (while (< low high) (setq mid (fix (/ (+ low high) 2))) (vla-put-TextString probe (R0:CN-PrefixAt paragraph (nth mid cuts))) (setq sample (R0:CN-Height (R0:CN-Box probe))) (if (> sample threshold) (setq high mid) (setq low (1+ mid)))) (vla-put-TextString probe (R0:CN-PrefixAt paragraph (nth low cuts))) (setq twoHeight (R0:CN-Height (R0:CN-Box probe))) (/ (min fullHeight twoHeight) 2.0)))) (defun R0:CN-BlockCompatible (blk / obj typ ok pl att hatch coords expected k a data) (setq ok (and (= (vla-get-Count blk) 3) (= (vla-get-Units blk) (getvar "INSUNITS")) (= (vla-get-BlockScaling blk) 1) (= (vla-get-Explodable blk) :vlax-false) (= (vla-get-IsXRef blk) :vlax-false) (equal (vlax-safearray->list (vlax-variant-value (vla-get-Origin blk))) '(0.0 0.0 0.0) 1e-9))) (vlax-for obj blk (setq typ (vla-get-ObjectName obj)) (cond ((= typ "AcDbPolyline") (if pl (setq ok nil)) (setq pl obj)) ((= typ "AcDbAttributeDefinition") (if att (setq ok nil)) (setq att obj)) ((= typ "AcDbHatch") (if hatch (setq ok nil)) (setq hatch obj)) (T (setq ok nil)))) (if (and ok pl att hatch) (progn (setq coords (vlax-safearray->list (vlax-variant-value (vla-get-Coordinates pl))) k 5) (repeat 6 (setq a (* pi (/ k 3.0)) expected (cons (* 0.1801 (cos a)) (cons (* 0.1801 (sin a)) expected)) k (1- k))) (setq ok (and (equal coords expected 1e-8) (= (vla-get-Closed pl) :vlax-true) (equal (vla-get-Elevation pl) 0.0 1e-9) (equal (vlax-safearray->list (vlax-variant-value (vla-get-Normal pl))) '(0.0 0.0 1.0) 1e-9) (= (strcase (vla-get-TagString att)) "NUM") (= (vla-get-Constant att) :vlax-false) (= (vla-get-Invisible att) :vlax-false) (equal (vla-get-Height att) 0.10 1e-8) (= (vla-get-Alignment att) 10) (equal (vlax-safearray->list (vlax-variant-value (vla-get-TextAlignmentPoint att))) '(0.0 0.0 0.0) 1e-8) (= (strcase (vla-get-PatternName hatch)) "SOLID") (= (vla-get-Color hatch) 255))) (setq k 0) (repeat 6 (if (not (equal (vla-GetBulge pl k) 0.0 1e-10)) (setq ok nil)) (setq k (1+ k))) (if (not (equal (vla-get-Area hatch) (* 1.5 (sqrt 3.0) 0.1801 0.1801) 1e-8)) (setq ok nil)) (if (not (equal (R0:CN-Box hatch) (list (list -0.1801 (- (* 0.1801 (/ (sqrt 3.0) 2.0))) 0.0) (list 0.1801 (* 0.1801 (/ (sqrt 3.0) 2.0)) 0.0)) 1e-8)) (setq ok nil))) (setq ok nil)) ok) (defun R0:CN-NewBlock (doc name / blk k a coords arr pl hatch loop att dict order) (setq blk (vla-Add (vla-get-Blocks doc) (vlax-3d-point '(0.0 0.0 0.0)) name) cn-newblock blk k 5) (vla-put-Units blk (getvar "INSUNITS")) (repeat 6 (setq a (* pi (/ k 3.0)) coords (cons (* 0.1801 (cos a)) (cons (* 0.1801 (sin a)) coords)) k (1- k))) (setq arr (vlax-make-safearray vlax-vbDouble '(0 . 11))) (vlax-safearray-fill arr coords) (setq pl (vla-AddLightWeightPolyline blk arr)) (vla-put-Closed pl :vlax-true) (vla-put-Layer pl "0") (vla-put-Color pl 0) (vla-put-ConstantWidth pl 0.0) (vla-put-Lineweight pl 0) (setq hatch (vla-AddHatch blk 0 "SOLID" :vlax-false 0) loop (vlax-make-safearray vlax-vbObject '(0 . 0))) (vlax-safearray-put-element loop 0 pl) (vla-AppendOuterLoop hatch loop) (vla-put-Layer hatch "0") (vla-put-Color hatch 255) (vla-put-EntityTransparency hatch "0") (vla-Evaluate hatch) (setq att (vla-AddAttribute blk 0.10 0 "Number" (vlax-3d-point '(0.0 0.0 0.0)) "NUM" "1")) (vla-put-Layer att "0") (vla-put-Color att 0) (vla-put-StyleName att "Standard") (vla-put-Height att 0.10) (vla-put-Alignment att 10) (vla-put-TextAlignmentPoint att (vlax-3d-point '(0.0 0.0 0.0))) (vla-put-BlockScaling blk 1) (vla-put-Explodable blk :vlax-false) (setq dict (vla-GetExtensionDictionary blk) order (vl-catch-all-apply 'vla-GetObject (list dict "ACAD_SORTENTS"))) (if (vl-catch-all-error-p order) (setq order (vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable"))) (vlax-safearray-put-element loop 0 hatch) (vla-MoveToBottom order loop) name) (defun R0:CN-BlockDef (doc / name i blocks blk compatible ready) (setq name "CN_HEX" i 0 blocks (vla-get-Blocks doc)) (while (not ready) (if (not (tblsearch "BLOCK" name)) (progn (R0:CN-NewBlock doc name) (setq ready T)) (progn (setq blk (vla-Item blocks name) compatible (vl-catch-all-apply 'R0:CN-BlockCompatible (list blk))) (if (and (not (vl-catch-all-error-p compatible)) compatible) (setq ready T) (progn (setq i (1+ i) name (strcat "CN_HEX_14_" (itoa i))) (if (> i 1000) (R0:CN-Fail "Too many conflicting marker block names."))))))) (if (> i 0) (princ (strcat "\nExisting block definitions preserved. Using " name "."))) name) (defun R0:CN-Marker (space src center number / obj scale side atts att found box w h factor) (setq scale (R0:CN-Scale (vla-get-Height src)) side (R0:CN-Side (vla-get-Height src)) obj (R0:CN-Register (vla-InsertBlock space (vlax-3d-point center) cn-blockname scale scale scale 0.0))) (R0:CN-Props obj src) (setq atts (vlax-safearray->list (vlax-variant-value (vla-GetAttributes obj)))) (foreach att atts (if (= (strcase (vla-get-TagString att)) "NUM") (progn (setq found T) (vla-put-TextString att (itoa number)) (vla-put-StyleName att (vla-get-StyleName src)) (vla-put-Height att (vla-get-Height src)) (vla-put-Alignment att 10) (vla-put-TextAlignmentPoint att (vlax-3d-point center)) (setq box (R0:CN-Box att) w (- (caadr box) (caar box)) h (R0:CN-Height box) factor (min 1.0 (/ (* side 1.45) (max w 1e-12)) (/ (* side 1.2) (max h 1e-12)))) (if (< factor 1.0) (vla-put-Height att (* (vla-get-Height att) factor))) (vla-put-TextAlignmentPoint att (vlax-3d-point center)) (vla-Update att) (if (/= (vla-get-TextString att) (itoa number)) (R0:CN-Fail "Could not verify the NUM attribute."))))) (if (not found) (R0:CN-Fail "Marker has no editable NUM attribute.")) obj) (defun R0:CN-InPlace (space src content records height width point initial / probe single lineProbe box top left side rec prefix total partHeight offset cy center number previous overlaps) (setq probe (R0:CN-Text space src content width height point (vla-get-AttachmentPoint src))) (vla-put-Visible probe :vlax-false) (setq box (R0:CN-Box probe) top (cadadr box) left (caar box) side (R0:CN-Side height) number initial overlaps 0) (vla-put-AttachmentPoint probe 1) (vla-put-InsertionPoint probe (vlax-3d-point point)) (setq single (R0:CN-Text space src "M" width height point 1) lineProbe (R0:CN-Text space src "M" width height point 1)) (vla-put-Visible single :vlax-false) (vla-put-Visible lineProbe :vlax-false) (foreach rec records (setq prefix (strcat "{" (substr content 1 (cadr rec)) (caddr rec))) (vla-put-TextString probe prefix) (setq total (R0:CN-Height (R0:CN-Box probe))) (vla-put-TextString single (car rec)) (setq partHeight (R0:CN-Height (R0:CN-Box single)) offset (R0:CN-AnchorOffset lineProbe (car rec) partHeight) cy (- (+ (- top total) partHeight) offset) center (list (- left side (* 0.7 height)) cy (caddr point))) (if (and previous (< (abs (- previous cy)) (* (sqrt 3.0) side))) (setq overlaps (1+ overlaps))) (R0:CN-Marker space src center number) (setq previous cy number (1+ number))) (R0:CN-Discard lineProbe) (R0:CN-Discard single) (R0:CN-Discard probe) (if (> overlaps 0) (princ (strcat "\n[!] " (itoa overlaps) " adjacent marker pairs may overlap." " Increase paragraph spacing or use CNC; original MTEXT was not moved."))) number) (defun R0:CN-Relocate (space src parts height width point initial / number side apothem para obj box realHeight offset upper lower cy bottom probe delta) (setq number initial side (R0:CN-Side height) apothem (* side (/ (sqrt 3.0) 2.0)) probe (R0:CN-Text space src "M" width height point 1)) (vla-put-Visible probe :vlax-false) (foreach para parts (setq obj (R0:CN-Text space src para width height (list (+ (car point) side (* 0.7 height)) (cadr point) (caddr point)) 1) box (R0:CN-Box obj) realHeight (R0:CN-Height box) offset (R0:CN-AnchorOffset probe para realHeight) upper (max apothem offset) lower (max apothem (- realHeight offset)) cy (if bottom (- bottom (* 0.8 height) upper) (cadr point)) delta (- (+ cy offset) (cadadr box))) (vla-Move obj (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (list 0.0 delta 0.0))) (R0:CN-Marker space src (list (car point) cy (caddr point)) number) (setq bottom (- cy lower) number (1+ number))) (R0:CN-Discard probe) number) (defun R0:CN-Cleanup (rollback / obj result) (if rollback (progn (foreach obj cn-saved (vl-catch-all-apply 'vla-put-TextString (list (car obj) (cadr obj))) (vl-catch-all-apply 'vla-Update (list (car obj)))) (foreach obj cn-erased (if (not (entget obj)) (if (not (entdel obj)) (princ "\n[!] Could not restore an old marker; use UNDO.")))))) (if (and rollback cn-retiring cn-source (null (entget cn-source))) (if (not (entdel cn-source)) (princ "\n[!] Check whether the original MTEXT was restored."))) (if rollback (progn (foreach obj cn-created (if (not (vlax-erased-p obj)) (progn (setq result (vl-catch-all-apply 'vla-Delete (list obj))) (if (vl-catch-all-error-p result) (princ "\n[!] Could not remove an output object; use UNDO to review this run."))))) (if cn-newblock (vl-catch-all-apply 'vla-Delete (list cn-newblock))))) (if cn-highlight (vl-catch-all-apply 'redraw (list cn-source 4))) (if cn-undo (vl-catch-all-apply 'vla-EndUndoMark (list cn-doc))) (foreach obj cn-vars (vl-catch-all-apply 'setvar (list (car obj) (cdr obj)))) (princ)) (defun R0:CN-Run (relocate / *error* cn-msg cn-created cn-source cn-highlight cn-doc cn-undo cn-vars cn-retiring cn-newblock cn-blockname cn-label cn-erased cn-saved oldmarkers src data content records parts height width rotation normal style initial option point space number obj) (defun *error* (msg) (R0:CN-Cleanup T) (cond (cn-msg (princ (strcat "\n[!] " cn-label ": " cn-msg))) ((and msg (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*,*EXIT*"))) (princ (strcat "\n[!] " cn-label ": " msg))) (T (princ (strcat "\n" cn-label " canceled. Original preserved.")))) (princ)) (setq cn-label (if relocate "CNC" "CN") cn-doc (vla-get-ActiveDocument (vlax-get-acad-object)) cn-vars (list (cons "DYNMODE" (getvar "DYNMODE")) (cons "DYNPROMPT" (getvar "DYNPROMPT")) (cons "ERRNO" (getvar "ERRNO")))) (setvar "DYNMODE" 3) (setvar "DYNPROMPT" 1) (if (setq cn-source (R0:CN-Select)) (progn (setq src (vlax-ename->vla-object cn-source) data (entget cn-source) content (R0:CN-Normalize (vla-get-TextString src)) height (vla-get-Height src) width (vla-get-Width src) rotation (vla-get-Rotation src) normal (cdr (assoc 210 data)) style (tblobjname "STYLE" (vla-get-StyleName src))) (if (and normal (not (equal normal '(0.0 0.0 1.0) 1e-8))) (R0:CN-Fail "This version requires text on a plane parallel to WCS XY.")) (if (vl-string-search "%<" content) (R0:CN-Fail "MTEXT fields are not supported.")) (if (and (assoc 75 data) (/= 0 (cdr (assoc 75 data)))) (R0:CN-Fail "Disable MTEXT columns before numbering.")) (if (or (= (cdr (assoc 72 data)) 3) (/= 0 (logand 4 (cdr (assoc 70 (tblsearch "STYLE" (vla-get-StyleName src))))))) (R0:CN-Fail "Vertical text is not supported.")) (if (or (R0:CN-Annotative cn-source) (and style (R0:CN-Annotative style))) (R0:CN-Fail "Use non-annotative MTEXT and a non-annotative style.")) (if (<= height 0.0) (R0:CN-Fail "Invalid text height.")) (setq records (R0:CN-Records content) parts (mapcar 'car records)) (if (not parts) (R0:CN-Fail "No non-empty paragraphs found.")) (if (> (length parts) 10000) (R0:CN-Fail "The limit is 10000 paragraphs per run.")) (redraw cn-source 3) (setq cn-highlight T) (princ (strcat "\n" (itoa (length parts)) " paragraphs | Hexagon side: " (rtos (R0:CN-Side height) 2 5) " | Scale: " (rtos (R0:CN-Scale height) 2 4))) (if (or (vl-string-search "\\H" content) (vl-string-search "\\S" content)) (princ "\n[!] Height overrides/stacked text found; visually check the first-two-line alignment.")) (setq initial (R0:CN-Initial)) (if (> (+ initial (length parts) -1) 999999999) (R0:CN-Fail "The final number would exceed 999999999.")) (if relocate (progn (initget "Keep Delete") (setq option (getkword "\nCNC | ORIGINAL [Keep/Delete] <Keep>: ")) (initget 1) (setq point (trans (getpoint (strcat "\nCNC | Center of FIRST hexagon (" (itoa initial) "): ")) 1 0))) (setq option "Keep" point (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint src))))) (setq space (vlax-ename->vla-object (cdr (assoc 330 (reverse data))))) (if (and (= 1 (logand 1 (getvar "UNDOCTL"))) (= 0 (logand 8 (getvar "UNDOCTL")))) (progn (vla-StartUndoMark cn-doc) (setq cn-undo T))) (if (not relocate) (progn (setq oldmarkers (R0:CN-FindMarkers src)) (foreach obj oldmarkers (if (not (R0:CN-Editable obj)) (R0:CN-Fail (strcat "Existing marker layer is locked, frozen or off: " (cdr (assoc 8 (entget obj))) ". No markers replaced.")))) (if oldmarkers (princ (strcat "\nCN | Replacing " (itoa (length oldmarkers)) " existing markers beside this MTEXT."))))) (setq cn-blockname (R0:CN-BlockDef cn-doc)) (setq number (if relocate (R0:CN-Relocate space src parts height width point initial) (R0:CN-InPlace space src content records height width point initial))) (foreach obj cn-created (if (not (equal rotation 0.0 1e-12)) (vla-Rotate obj (vlax-3d-point point) rotation)) (vla-Update obj) (if (not (entget (vlax-vla-object->ename obj))) (R0:CN-Fail "Could not verify the output."))) (if (/= (length cn-created) (* (if relocate 2 1) (length parts))) (R0:CN-Fail "The output is incomplete.")) (R0:CN-RetireMarkers oldmarkers) (vla-Regen cn-doc 0) (redraw cn-source 4) (setq cn-highlight nil) (if (= option "Delete") (progn (setq cn-retiring T) (if (not (entdel cn-source)) (R0:CN-Fail "Could not delete the original.")))) (setq cn-created nil cn-retiring nil cn-newblock nil cn-erased nil) (R0:CN-Cleanup nil) (princ (strcat "\n[OK] " (itoa (length parts)) " paragraphs | Numbers " (itoa initial) " to " (itoa (1- number)) " | " (if relocate (strcat "Original " (if (= option "Delete") "deleted." "preserved.")) "Original MTEXT unchanged.")))) (R0:CN-Cleanup nil)) (princ)) ;;; Recognize only this routine's marker families and an editable NUM attribute. (defun R0:CN-NumAttribute (obj / att found) (if (= (vla-get-HasAttributes obj) :vlax-true) (foreach att (vlax-safearray->list (vlax-variant-value (vla-GetAttributes obj))) (if (= (strcase (vla-get-TagString att)) "NUM") (setq found att)))) found) (defun R0:CN-IsMarker (en / obj name) (if (= (cdr (assoc 0 (entget en))) "INSERT") (progn (setq obj (vlax-ename->vla-object en) name (strcase (if (vlax-property-available-p obj 'EffectiveName) (vla-get-EffectiveName obj) (vla-get-Name obj)))) (and (or (= name "IR_HEX") (= name "CN_HEX") (wcmatch name "CN_HEX_14_#,CN_HEX_14_##,CN_HEX_14_###,CN_HEX_14_####")) (R0:CN-NumAttribute obj))))) (defun R0:CN-Owner (en) (cdr (assoc 330 (reverse (entget en))))) (defun R0:CN-Editable (en / layer) (setq layer (tblsearch "LAYER" (cdr (assoc 8 (entget en))))) (and layer (= 0 (logand 5 (cdr (assoc 70 layer)))) (> (cdr (assoc 62 layer)) 0))) (defun R0:CN-Unrotate (p origin angle / x y c s) (setq x (- (car p) (car origin)) y (- (cadr p) (cadr origin)) c (cos angle) s (sin angle)) (list (+ (car origin) (* x c) (* y s)) (+ (cadr origin) (- (* y c) (* x s))) (caddr p))) (defun R0:CN-InColumn (p box height) (and (>= (car p) (- (caar box) (* 4.0 height))) (<= (car p) (- (caar box) (* 0.5 height))) (>= (cadr p) (- (cadar box) (* 0.10 height))) (<= (cadr p) (+ (cadadr box) (* 0.10 height))) (equal (caddr p) (caddar box) (max 1e-8 (* height 1e-6))))) ;;; Legacy markers have no ownership metadata: use a narrow, text-local left column. ;;; Never search inside definitions or across model/paper-space owners. (defun R0:CN-FindMarkers (src / en owner space probe box point rotation height ss i candidate obj p found) (setq en (vlax-vla-object->ename src) owner (R0:CN-Owner en) space (vlax-ename->vla-object owner) point (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint src))) rotation (vla-get-Rotation src) height (vla-get-Height src)) (if (not (R0:CN-Editable en)) (R0:CN-Fail "The selected text layer is locked, frozen or off.")) (if (and (assoc 210 (entget en)) (not (equal (cdr (assoc 210 (entget en))) '(0.0 0.0 1.0) 1e-8))) (R0:CN-Fail "Marker detection requires MTEXT parallel to WCS XY.")) (setq probe (R0:CN-Text space src (vla-get-TextString src) (vla-get-Width src) height point (vla-get-AttachmentPoint src))) (vla-put-Visible probe :vlax-false) (setq box (R0:CN-Box probe)) (R0:CN-Discard probe) (setq ss (ssget "_X" '((0 . "INSERT"))) i 0) (if ss (repeat (sslength ss) (setq candidate (ssname ss i) i (1+ i)) (if (and (equal owner (R0:CN-Owner candidate)) (R0:CN-IsMarker candidate)) (progn (setq obj (vlax-ename->vla-object candidate) p (R0:CN-Unrotate (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint obj))) point rotation)) (if (R0:CN-InColumn p box height) (setq found (cons candidate found))))))) found) ;;; Defer removal until new output is verified; record every erased reference for rollback. (defun R0:CN-RetireMarkers (items / en) (foreach en items (if (not (R0:CN-Editable en)) (R0:CN-Fail (strcat "Existing marker layer is locked, frozen or off: " (cdr (assoc 8 (entget en))) ". No markers replaced.")))) (foreach en items (setq cn-erased (cons en cn-erased)) (if (not (entdel en)) (R0:CN-Fail "Could not replace an existing marker.")))) (defun R0:CN-SortMarkers (items angle / rows en obj p index) (setq index 0) (foreach en items (setq obj (vlax-ename->vla-object en) p (R0:CN-Unrotate (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint obj))) '(0.0 0.0 0.0) angle) rows (cons (list en (car p) (cadr p) index) rows) index (1+ index))) (mapcar 'car (vl-sort rows '(lambda (a b) (cond ((/= (caddr a) (caddr b)) (> (caddr a) (caddr b))) ((/= (cadr a) (cadr b)) (< (cadr a) (cadr b))) (T (< (cadddr a) (cadddr b)))))))) (defun R0:CN-Renumber (/ *error* cn-msg cn-created cn-source cn-highlight cn-doc cn-undo cn-vars cn-retiring cn-newblock cn-erased cn-saved cn-label ss i en obj items found candidate angle initial number att) (defun *error* (msg) (R0:CN-Cleanup T) (cond (cn-msg (princ (strcat "\n[!] CNR: " cn-msg))) ((and msg (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*,*EXIT*"))) (princ (strcat "\n[!] CNR: " msg))) (T (princ "\nCNR canceled. Previous numbers restored."))) (princ)) (setq cn-label "CNR" cn-doc (vla-get-ActiveDocument (vlax-get-acad-object)) cn-vars (list (cons "DYNMODE" (getvar "DYNMODE")) (cons "DYNPROMPT" (getvar "DYNPROMPT")) (cons "ERRNO" (getvar "ERRNO")))) (setvar "DYNMODE" 3) (setvar "DYNPROMPT" 1) (princ "\nCNR | Select MTEXT to detect its markers, or select the hexagon blocks: ") (setq ss (ssget '((0 . "MTEXT,INSERT")))) (if ss (progn (if (and (= 1 (logand 1 (getvar "UNDOCTL"))) (= 0 (logand 8 (getvar "UNDOCTL")))) (progn (vla-StartUndoMark cn-doc) (setq cn-undo T))) (setq i 0) (repeat (sslength ss) (setq en (ssname ss i) i (1+ i) obj (vlax-ename->vla-object en)) (setq found (cond ((= (vla-get-ObjectName obj) "AcDbMText") (R0:CN-FindMarkers obj)) ((R0:CN-IsMarker en) (list en)))) (foreach candidate found (if (not (member candidate items)) (setq items (cons candidate items))))) (if (not items) (R0:CN-Fail "No recognized hexagons found. Select the marker blocks directly.")) (if (> (length items) 10000) (R0:CN-Fail "Select at most 10000 markers.")) (setq angle (vla-get-Rotation (vlax-ename->vla-object (car items)))) (foreach en items (setq obj (vlax-ename->vla-object en)) (if (not (R0:CN-Editable en)) (R0:CN-Fail (strcat "Marker layer is locked, frozen or off: " (cdr (assoc 8 (entget en))) ". No numbers changed."))) (if (not (equal (sin (/ (- (vla-get-Rotation obj) angle) 2.0)) 0.0 1e-6)) (R0:CN-Fail "Select one text orientation at a time."))) (setq items (R0:CN-SortMarkers items angle)) (princ (strcat "\nCNR | " (itoa (length items)) " markers | Top to bottom in text orientation.")) (setq initial (R0:CN-Initial) number initial) (if (> (+ initial (length items) -1) 999999999) (R0:CN-Fail "Final number exceeds 999999999.")) (foreach en items (setq att (R0:CN-NumAttribute (vlax-ename->vla-object en))) (setq cn-saved (cons (list att (vla-get-TextString att)) cn-saved)) (vla-put-TextString att (itoa number)) (vla-Update att) (if (/= (vla-get-TextString att) (itoa number)) (R0:CN-Fail "Could not verify a new number.")) (setq number (1+ number))) (vla-Regen cn-doc 0) (setq cn-saved nil) (princ (strcat "\n[OK] CNR | " (itoa (length items)) " markers | " (itoa initial) " to " (itoa (1- number)) " | Geometry and positions unchanged.")))) (R0:CN-Cleanup nil) (princ)) (defun c:CNR () (R0:CN-Renumber)) (defun c:CN () (R0:CN-Run nil)) (defun c:CNC () (R0:CN-Run T)) (princ "\nHEXENUM 1.5.1 | CN: number/replace | CNC: create elsewhere | CNR: renumber.") (princ) Hi @dber I’ve got the final version fully polished and working perfectly. Here is the updated code and a quick GIF showing it in action. All your requests are covered: Commands: Renamed to CN and CNC. Block Scaling & Style: The CN_HEX block now uses uniform scaling, matches your MTEXT text style and height perfectly, and won't distort or explode. Hexagon Positioning: Single and double lines are perfectly centered. For 3+ lines, the hexagon is now precisely aligned between the 1st and 2nd lines. Bonus features included: CNR Command: Use this to easily renumber existing hexagons if you ever need to change the starting number. Smart Replacement: If you run CN again, it automatically replaces the old markers without creating duplicates. Auto-Realignment: If you change the MTEXT width grip, just run CN again and it realigns everything instantly. Give it a try and let me know how it works for your project! Best, Romero -
Hi! There is a form that cannot be made, I tried to use various approaches, but solidworks in any case creates a form with a distorted surface. I’ve probably tried all possible options, except for the one that works, and it already seems to me that this form cannot be created in solidworks, it’s just funny, but in fact it cannot be done even if I wanted to. I will attach two files: v1 is an example of the required surface from the point of view of the absence of defects. v2 is a frame of a shape that cannot be made even. Just please understand correctly the v2 frame does not pretend to be the form from it; I made it in order to convey an understanding of what form is needed. v1.SLDPRT v2.SLDPRT
resullins started following Detail View Split Across Multiple Pages
Ok... my current company uses a Revit Template that uses Drafting Views for our Single Line (signal flow, functional, whatever) diagrams for projects. This works really well for most things. However, occasionally we get a functional that is too large to fit on a single page. Since we use Drafting Views, we can't have an "Overall" with dependents like we could on a floor plan. This means that sometimes I have to switch back and forth between 2 or 3 views when working on a single system. Is there ANY way to do this other than putting these diagrams onto a floor plan?
