Margo App joined the community
Xref hatches plot solid black and fonts change on my machine only
Paul Li replied to xurshid_viewport's topic in AutoCAD Beginners' Area
Double posted -
Paul Li started following Xref hatches plot solid black and fonts change on my machine only
Typically etransmit should be used. This way any fonts and plot styles can be packaged along with xrefs in the zip file. This is what I would request from the architect. But hatches plotting solid black is very odd. Could you share a sample dwg that includes theses hatches for us to test? -
So in keeping with posting some of my LISPs, I used this just the other day, and just was reminded with the recent resurrection of the Fillet 0 issue thread where the OP was doing 40,000, not sure what LISP they used. Per the latest resurrection, setting FILLETPOLYARC setting may or may not help depending on what you are trying to fillet. The few times I have seen Fillet 0 fail with the P option was when the fillet radii completed something like a half circle when adjacent corners are filleted (something like the ends of a slot). This can be handy dandy. There are others like this around. For my use this was better than a few of the ones I tried. You may need to change the FILLETPOLYARC=0 if you have issue using this with Radius=0. In those situations when I had an issue, the LISP just doesn't do anything to those fillets, so I just go back with a small radius and change them, then you should be able to Fillet=0 those. (defun c:MF () (c:MultiPolyFillet) ) (defun c:MultiPolyFillet (/ radius ss i ent) (setq radius (getdist "\nFillet radius: ")) (if radius (progn (setvar "FILLETRAD" radius) (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE")))) (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (command "_.FILLET" "_P" ent) (setq i (1+ i)) ) ) ) ) ) (princ "MultiPolyFillet complete.") (princ) ) (princ "\nMultiPolyFillet loaded. Type MultiPolyFillet or MF to run." ) (princ)
- 1
Fillet polylines to radius 0 not working
SLW210 replied to claire2017's topic in AutoCAD 2D Drafting, Object Properties & Interface
The OP and the 2nd person with a problem fixed their issues with resetting AutoCAD and resetting their profile. FILLETPOLYARC, can be handy set to 1 if you need to Fillet arc segments. Though it has it's faults. -
Peter de Vries replied to claire2017's topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi everyone, I've just read about this thread because I encountered the same issue of not being able to fillet a polyline with radius 0 when using the p-option. It works fine if I select separate straight sections of the polyline though, but that's not what I want. So, looking a bit further, I found the resolution to my problem in the systemvariable 'FILLETPOLYARC'. When setting this variable to '1', fillet radius 0 on polylines doesn't work. Setting this variable to '0', however, results in expected behaviour, filleting with another radius, thereby changing the existing arc segments by their new radius - including radius of 0. Let this tip help us all further in our (sometimes) struggle with Autodesk adding variables in new releases which change our expected ways of working. And remember, set the 'FILLETPOLYARC' variable to '0' Cheers! Peter -
Peter de Vries joined the community
Henchiri joined the community
DIYORBEK DUSHANOV joined the community
How do you modify a 3D solid without rebuilding it?
That really depends on the situation. If pretty simple to begin with it may be quicker to redo from the beginning. If not simple to redo, face editing can be quick and accurate and many options there, though just creating a new solid and using Subtract and/or Union could be the better option. Like I stated it really depends on the model and the change required. -
Especially welcome and invite developers, especially those in retirement status, to share and update the tools (plugins) you have created through VedaCAD, so that more people can benefit from your creations. These repositories for VCID's results will no longer fade away with time; they will enable those in need to obtain and use them. Especially, VedaCAD is now able to handle the release of plugins at the MSI level (official store). For any VedaCAD usage issues and suggestions, please feel free to contact me directly: vico@vedacad.com - Last week
STEP vs SAT: Which one preserves editable 3D geometry more reliably?
Why would that be interesting? STEP is very common and maintains information and accuracy. So if unknown usage why wouldn't that be the choice? I usually work with AutoCAD, so ACIS or .dwg is my first choice, then STEP if I need information retained for other programs, for 3D Printing simple objects, I sometimes will just do the .stl export. My 3D Printer slicing software can handle STEP files, I have yet to test some more intricate models, but, it eventually creates .stl and then a .3mf g-code file for the printing. It's very tedious painting multicolor parts in the slicer software, so I'll need to see how pre-coloring in AutoCAD>STEP works and which is better. That's just in reference to what AutoCAD can do (Mechanical for STEP), there are other options for different programs. -
Praveen joined the community
LM_B joined the community
xurshid_viewport replied to xurshid_viewport's topic in AutoCAD Beginners' Area
Thanks, SLW210. The plot preview shows the same thing as the PDF: the hatches are black there too, so it is not something that only happens at the plotter. On paper I haven't tried yet, I only printed to PDF. I'll check what XREFOVERRIDE and VISRETAIN are set to in my file tomorrow at the bureau and report back. I also want to see whether the hatch layer in his drawing has a plot style assigned that doesn't exist in my CTB. I'll read through the page you linked in the meantime. -
allen24 joined the community
@BIGAL I think using powershell method would be similar. User launches AutoCAD then runs lisp that would write the registry key (that designates the current profile) into powershell script along with item to add to Startup. But after running the powershell script, user is prompted to exit AutoCAD (without launching Appload) in order for the added item in the registry to be read on the relaunch of AutoCAD. -
Maybe like this and use a bat file that last line calls Autocad or Bricscad after editing the registry, note adding extra programs see second image. -
For CAD manager, Developer, and Users accustomed to communicating via email, feel free to contact me anytime: vico@vedacad.com -
I continue to monitor the situation and although we're still seeing the error message, the stats for this month indicate that bot activity is going down from a peak in September. Fingers crossed it continues to fall.
lrm started following ucs and drawing problem
@LIU very simple. If UCSICON is set to OR (origin) and 0,0,0 of the current UCS is near to the left border of the graphics window boundary, or below the boundary, or not within the viewing window then the UCS ICON will move to be near the bottom left of the window and will not be postioned at 0,0. Note, the little square that you see on the icon indicates that you the WCS is active.
indiancad started following SLW210
indiancad started following ReMark
That's great ! Choosing the format based on the receiving application and the intended use seems like the most practical approach. I also find your point about using STEP when the end use is unknown interesting. -
I used to use AutoCAD's LIGHTS(Point & Distant), CAMERA, ACTION(SCENE) commands to setup visual renderings in AutoCAD. But starting with AutoCAD 2007 when the entire rendering engine was changed and the SCENE command was dropped and never replaced, what does everyone use now to replicate the SCENE command? Or does anyone setup scenes at all which used to offer the end user the option to assign different light sources to a particular view.
Using Arraypath function via scripting, duplicating lines are created in opposite direction of curve path
SLW210 replied to harshil's topic in AutoCAD LT
I can move the geometry a good bit away and it works fine. The original LISP works, the exact location seems an issue and something is messing up the direction. Are there other examples of where it fails? I added prompts for Layer, Path and number. AUTOHPA_SLW.lsp -
Danielm103 started following Python Slide(.SLD) to wxImage
Python Slide(.SLD) to wxImage In the next release (3.1.16), I added a function, image: wx.Image = Gs.Core.slideToWxImage(test_slide_path, width, height, [R, G, B]) for people that are used to using slides in their dialogs.
- 3
I do not recall having many issues with any of them. AutoCAD cannot export directly to STEP, only Mechanical (which is a FREE toolset though). Normally I determine the type by what is needed by the program that needs it, if any will work normally ACIS (.sat) would be preferred and if the program can I just keep it as a .dwg. For 3d Printing I use .stl and ultimately .3mf. If unknown what the end use will be, STEP is usually the best bet. -
When transferring a mechanical model between CAD applications, choosing an exchange format can affect more than just how the model looks. Face boundaries, analytic surfaces, and solid recognition can influence how easily the imported part can be modified. A model may import successfully but still require extra work before features can be edited or downstream operations can be performed reliably. I’m interested in practical experience rather than just format specifications. When exchanging 3D solids between different CAD systems, have you found STEP or SAT more reliable for preserving usable geometry? Does your choice change depending on the type of model? -
@LIU When I first open your dwt template dwg this is how it looks like with the UCSICON on the lower left corner but no red or green lines shown: Then I scroll the mouse to zoom outward then eventually the red & green lines show up with the UCSICON now positioned at the location where they cross: But once I use the scroll mouse to zoom in again to the point where the green and red lines are close to the lower left hand corner of the drawing window, the UCSICON is displayed no longer at the location where the two lines cross over: This is normal display behavior because AutoCAD is trying to display the UCSICON at the origin where X (red line) and Y (green line) crosses = 0,0. If you don't want to see the UCSICON constantly moving then enter the following at the command prompt: UCSICON NoOrigin Now when you zoom in and out, the UCSICON is no longer constantly moving to try and position itself at the corner of the green & red lines. But instead the UCSICON is now always positioned in the lower left corner of the drawing area: Hope this answers your question.
sorry, i had a problem with autocad, this is the drawing file , open the drawing and roll wheel to yourself. what is problem with red and green lines parallel to x-axis and y-axis My-Architectural-Templyte-1.dwt
Muralidharan joined the community
@aridzv Thank you for the correction. This post indeed mainly discusses the management of individual users, and it was off-topic. The previous discussion was mainly about answering your question about why it developed into the cloud. At the level of individual user management, VedaCAD's Base mode (100% local, not actively connected to the internet) has a similar approach to your solution: In the Base mode, the same file migration is required to transfer to a new machine using VC. You just need to export the configuration file from the old computer's VC, copy the plugin folder (for example, the folder on the old computer is: E:/CADTools/), and then import the configuration file on the new computer, and copy the CADTools/ folder to the same location on the new computer (E:/CADTools/), and the migration is complete. (The exported configuration file is a small database, mainly mapping relationships and custom configurations, not specific plugin files) If it is the FREE tier, you can even use the self-use bundle method to achieve the ability to restore and synchronize the entire configuration with one click, Results like the PRO level (the VC system has opened up configuration cloud synchronization capabilities specifically for the PRO level, truly realizing the ability to sync the entire working environment configuration with one click) Most importantly, the VedaCAD client is just a VLX plugin, and it does not modify any registry, ignores any supported path issues, and achieves capabilities similar to your existing solution, such as on-demand loading.
