Butch started following Parcel number and name problem
Hello! Is it possible to create this kind of parcele name or Maybe on number. As you can see in the picture attach it symbol / between two numbers. 3/180. Its writen in blue color so you have to look a bit carefully....my mistake Thank you
Worachai joined the community
enzolan joined the community
A couple of comments, the outside stairs use a rectang with a wipeout so it hides the windows behind. Also there is no inside support ? tr I am metric but not sure about 2x4 for rafters at that span, there is no @ what spacing. Ceiling 2 lines or even 3 with insulation shown. Concrete beam arrow did not point to it, and a conc beam should be shown as a "T" This detailing is wrong only show 12' beam not concrete at bottom. Cantilever balcony is shown wrong. see red lines. There is no way a 4' slab can cantilever that far. May need some help on structural layout of beams in slab. Enough from me, its about learning. I am sure others will comment.
Thank you for your feedback. It’s my first time working on this, so I didn’t realize I could upload the DWG file. I’ll share it so it’s easier to review. Thanks again for your time and advice! Drawing1.dwg
symoin started following Move any overlapped text and create a new line.
symoin replied to Sheep's topic in AutoLISP, Visual LISP & DCL
Hi, please share the TTT lisp -
samg joined the community
qq787116960 joined the community
Yes, we should see the peak of the roof from one side and the ridge from the other. Unless there's a flat section in the middle.
Then post a .dwg file that we can downloaded and view better. Right off the bat your roof cut section should appear differently in the two sections. Judging by what I can see it's very similar in both sections. This will be my last comment. Good luck on your submission.
Being a road designer for many years we would always sample wider than needed, as you suggest a small problem when a line ends on a face. Within the plot section you would set left and right limits so this would truncate a section to a fixed width, even though sections are wider. One clean up was we wanted natural surface to be wider than the design so would trim left and right section details to get that effect. Oh yeah the other is we always started a road before the actual start and after the end so could work out the blend correctly.
Excuse me. You're right. It's a combination of several things. Basically, the 'getfencesel' function, when the selected axis ends, with one of its ends, on one of the sides of the 3DFACEs it intersects, fails to capture that intersection and doesn't display it in the profile. This, in some cases, produces an error, and the command doesn't execute. There's something else, but I'll have to look into it later. When I'm done, I'll post the resulting code for anyone curious to try it out.
Thank you for taking the time to review my work. I appreciate your feedback. I just wanted to clarify that my question was specifically about the roof cut section.
Sakun joined the community
ozkanozgur joined the community
Re: roof. It's difficult to tell given the scale of the image above. That aside, I do have a few questions. Where are the closets in the bedrooms? Why are there no bathing facilities shown, like a shower or a tub, in either bathroom? Why are the hallways so large (almost room size)? Hallways tend to be much narrower than rooms. Where are the living rooms? And shouldn't counters/appliances such as a refrigerator, electric or gas range and a dishwasher be shown in your floor plan? Is the house completely wood framed or a combination of masonry and wood? Depending on the situation your sections would be different. Wouldn't a post or two be required under the first stair landing?
I’m sharing my drawing for your review. Could you please check if it looks correct? I think there may be an issue with the roof section, but I’m not sure what exactly is wrong.
Amine joined the community
Maybe post how you solved it for others.
keto joined the community
Magdonel13 started following ANSI B16.5 Flanges Lisp , How to use the LISP routines in this archive and ANSI B16.47 Flanges Lisp
I agree with what you said. (setq theblock (vla-InsertBlock mspace ip item xscale yscale zscale rot)) Editing the code like this fixed it. Thanks .
rlx started following Why is vla-insert different?
I think Steven is right , this is about redefining or not. When you insert a block without path , AutoCad uses the block definition allready present in active drawing. If you put a path to it , AutoCad will overwrite current block definition with the one on file. So , if you insert block for the first time , then edit it and after that insert the one from file , your edited definition will be overwritten again. Standard / classic / basic AutoCad behaviour.
I prepared a block dwg file and a example dwg file. And of course the lsp file for comparison. I deleted the inner part of the block in the example dwg file. Without deleting this block, add the second block using the commands in the lsp file. Note 1 : link for vla-insertblock >> https://www.afralisp.net/archive/methods/lista/insertblock_method.htm (I just changed the item line to select it) Note 2 : After using the "al-insertblock" command in AutoCAD, run the regen command. BLOCK.dwg EXAMPLE.dwg EXAMPLE.lsp
foxesak joined the community
Steven P started following Why is vla-insert different?
Are you able to post a copy of the LISP so we can see what is happening? Sounds like your (command method is referring to the source file and the (vla- method is referring to your working file
Hi everyone, I encountered a problem yesterday. I have a Block.dwg file. I call the Block.dwg file into the A.dwg file and make edits within Block. After that, I run lisp. At this point, I encounter the following error. When I insert the same Block again If I insert it with (command "-insert"). It is based on the block in A.dwg and the block I insert looks like it. If I use the (vla-insertblock) function, it moves according to the inserted block and the blocks in A.dwg look like the block I inserted. What is the reason?
Hi @BIGAL. I’ve taken a look at TriangV0.6.7.lsp but one of the most important functions, c:Prof, doesn’t seem to work properly. I can’t manage to find correspondence between the intersection points of the selected line and the 3DFACEs with what they should be in reality. Has the correct functioning of this command been proven? PS: SOLVED
Help to modify routine lsp viewports...
mhupp replied to leonucadomi's topic in AutoLISP, Visual LISP & DCL
O mine is the other way around in that the viewport has to be existing in paperspace already with the sacle you want. ;;----------------------------------------------------------------------------;; ;; Creates Viewport outline and moves it to Model space (defun C:VP2M (/ SS vp elist MiscOn cen c40 c41 LL UR) (if (setq SS (ssget "_X" (list '(0 . "viewport") (cons 410 (getvar 'ctab))))) (foreach vp (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq elist (entget vp)) (if (> (cdr (assoc '69 elist)) 1) ; skip display viewport (progn (if (= (cdr (assoc '68 elist)) 0) ; is viewport active? (progn (setq MiscOn 'NO) (vl-cmdf "._Mview" "_on" "_si" vp) ; activate viewport ) (setq MiscOn 'YES) ) (setq cen (cdr (assoc '10 elist)) c40 (cdr (assoc '40 elist)) ;length c41 (cdr (assoc '41 elist)) ;width LL (list (- (car cen) (/ c40 2)) (- (cadr cen) (/ c41 2))) UR (list (+ (car cen) (/ c40 2)) (+ (cadr cen) (/ c41 2))) ) (vl-cmdf "_.Pspace") (vl-cmdf "_.Rectangle" LL UR) (vl-cmdf "_.Chspace" "_Last" "") (vl-cmdf "_.Pspace") (if (eq MiscOn 'NO) (vl-cmdf "_.Mview" "_off" "_si" vp) ; deactivate viewport ) ) ) ) ) ;(setvar 'Tilemode 1) ;switch to model space (princ) ) -
Like @mhupp I have a couple of make layouts I tend to use this front end which matches a user's title blocks. You can make multiple in one go using 2 different methods or pick a central point. It is two separate functions as you can check the rectangs 1st then make the layouts. Happy to discuss further. -
THANKS MASTER -
mhupp started following Help to modify routine lsp viewports...
I have a simpler version kicking around at home that ill post later tonight. -
oops forgot atoi to set X as an integer. in VBA you can just do math with strings if they are numbers "80" * 5 works the same as 80 * 5. not so much in lisp.
nuncito37 joined the community
Yet Another Bad Linetype Definition Thread
nuncito37 replied to dal-designs's topic in The CUI, Hatches, Linetypes, Scripts & Macros
After many months of avoiding this issue when I switched offices. I found out this happens when linetypes are created with .shp files required. If you have an issue where the linetyepes show incorrectly please just do the following to fix. 1. Type "OPTIONS" 2. Go to FILES tab 3. Support File folder, and navigate to the file that holds your fonts files and move it to the top of the list. 4. Finally, close cad and reopen. The hierarchy of the support files a crucial to what it loads and displays in cad. It will ignore the file needed if it is not prioritized in the support file folder correctly. You are welcome- 33 replies
- 1
- acad.lin
- error message
(and 1 more)
Tagged with:
leonucadomi started following Help to modify routine lsp viewports...
hello : I found a good routine that I really like but I would like it to skip the last two steps. select areas in the model space and create the same number of viewports in the paperspace I want that when the viewports are finished being created, the routine ends and it no longer asks me if I want to return to the model or if I want to make more viewports. some help please. here code: ; NVM creates mspace vports ; Modified: ; 1. Vport layout placement is at lower left corner ; 2. Default setting to switch back to Model vs staying in Layout ; 3. Layout selection defaults to previous selection ; 4. Offers option to select multiple Model views ; 5. Offers dialog selection on scales based on ScalelistEdit ; 6. NVM loops until Esc or Enter during first point of view selection ; OP: ; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-create-multiple-viewport/m-p/12728443#M464938 (defun c:NVM (/ *error* _RestoreView _GetScaleProp ans count ct doc ll vpscl vpsclp mp p1 p2 ptlst res sc sci scitmp sl tmp vc vp vpdoc vpp vs ) (vl-load-com) (defun *error* (Msg) (princ "Error: ") (princ Msg) (if ct (_RestoreView)) (princ) ) (defun _RestoreView () (setvar "ctab" ct) (vla-ZoomCenter (vlax-Get-Acad-Object) (vlax-3d-Point (trans vc 1 0)) vs) ) ; _GetScaleProp returns list of scalelist name assoc with paper units & drawing units ; modified from: ; https://forums.augi.com/showthread.php?107333-Using-vlisp-to-access-scales-list (defun _GetScaleProp (/ csobj ent entnm index scaleDict scaleDictName scaleObject scllst sclnam unidwg unippr) (setq scaleDict (dictsearch (namedobjdict) "ACAD_SCALELIST")) (setq scaleDictName (cdar scaleDict)) (setq csobj (vlax-ename->vla-object scaleDictName)) (setq index 0) (repeat (vla-get-count csobj) ; loop through all scalelist names (setq scaleObject (vlax-invoke-method csobj 'item index)) (setq entnm (vlax-vla-object->ename scaleObject)) ; convert from obj to entity (setq ent (entget entnm)) ; get entity data (setq sclnam (cdr(assoc 300 ent)) ; scalelist name car itm unippr (cdr(assoc 140 ent)) ; paper units cadr itm unidwg (cdr(assoc 141 ent)) ; drawing units caddr itm scllst (append (list(cons sclnam (list unippr unidwg))) scllst) index (+ index 1) ) ) ; repeat (setq scllst (append scllst (list (list "User" 1.0 1.0)))) ; add user scale (reverse scllst) ) ; (if (/= (getvar "cvport") 1) ; add (progn (setq ; set Model defaults doc (vla-get-ActiveDocument (vlax-get-acad-object)) ct (getvar "ctab") vs (getvar "viewsize") vc (getvar "viewctr") ; start loop p1 T count 0 ; view count vpsclp (_GetScaleProp) ; get scalelist property vpscl (mapcar '(lambda (x) (car x)) vpsclp) ; create list of just first item in assoc pair for list box ll ; build layout list (vlax-for % (vla-get-layouts doc) (setq res (cons (list (vla-get-name %) % (vla-get-TabOrder %) ) res ) ) ) ll (cdr (vl-sort ll '(lambda (a b) (< (last a) (last b)) ) ) ) ) ; setq ; start loop (while p1 (setq ptlst '() count 0) ; reset count & layout list (while p1 ; (if (and (setq p1 (getpoint "\nSelect first point of view or Enter to Exit: ")) (setq p2 (getcorner p1 "\nSelect second point of view: ")) ) (progn ; build list of view points (setq ptlst (append ptlst (list (cons p1 (list p2))))) ; show # of views selected (if(zerop count) (princ (strcat "\n" (itoa (setq count (1+ count))) " View Selected...")) (princ (strcat "\n" (itoa (setq count (1+ count))) " Views Selected...")) ) ) ) ; if ) ; while (if ptlst ; if list of view points (progn ; (princ (strcat"\n" (itoa (length ptlst)) " Views Selected...")) ; add scale selection dialog (if(not sci) (if (not(setq sci (vl-position "1:50" vpscl))) ; select 1:50 as default (setq sci 1) ; else set 2nd item as default ) ) (if (setq scitmp (cd:DCL_StdListDialog vpscl sci "Viewport Scale" "Select Scale:" 40 15 2 nil T T)) (if (eq "User" (nth scitmp vpscl))(setq scitmp nil)(setq sci scitmp)) ) (if scitmp ; then get scale = 3rd item in the prop list (setq sc (fix(caddr(nth sci vpsclp)))) ; else type in scale (setq sc (cond ( (getint (strcat "\nWhat is Viewport Scale 1: <" (itoa (setq sc (cond (sc) (50)))) ">: " ) ) ) ( sc ) ) ) ) ; if ; add highlight of previous layout item selection (if(not sl)(setq sl 0)) (if (setq sl (cd:DCL_StdListDialog (mapcar ' car ll) sl "NewViewport" "Select layout:" 40 15 2 nil T T)) ; (progn (setvar "ctab" (car (nth sl ll))) (vla-put-MSpace doc :vlax-false) ; cycle through all selected view points (setq count 1) (foreach itm ptlst (setq p1 (car itm) p2 (cadr itm) ) ; (if (setq vpp (getpoint (strcat "\nSelect Point for " (itoa count) " of " (itoa (length ptlst)) " Viewports: "))) (progn (if (< (car (trans p2 1 0)) (car (trans p1 1 0)) ) (setq tmp p1 p1 p2 p2 tmp) ) (setq mp (list (/ (+ (car p1) (car p2)) 2) (/ (+ (cadr p1) (cadr p2)) 2) 0.0 ) ) (setq vpdoc (vla-get-PaperSpace doc) vp (vla-AddPViewport vpdoc ; move vport so placement point is at lower left corner ; (vlax-3d-point vpp) (vlax-3d-point (list (+ (car vpp) (/ (abs (/ (- (car p2) (car p1)) sc)) 2) ) (+ (cadr vpp)(/ (abs (/ (- (cadr p2) (cadr p1)) sc)) 2) ) 0.0 ) ) ; (abs (/ (- (car p2) (car p1)) sc)) (abs (/ (- (cadr p2) (cadr p1)) sc)) ) ) (vla-display vp :vlax-true) (vla-put-MSpace doc :vlax-true) (vla-put-ActivePViewport doc vp) (vla-ZoomCenter (vlax-get-acad-object) (vlax-3d-point mp) 1.0 ) (vla-put-CustomScale vp (/ 1. sc)) (vla-put-MSpace doc :vlax-false) (vla-put-DisplayLocked vp :vlax-true) ) (progn (princ "\n** Invalid Point ** ") (if ct (_RestoreView)) ) ) ; (setq count (1+ count)) ) ; foreach ; ) ; progn (princ "\n** Layout not selected ** ") ) ; set default (if(not *ans*)(setq *ans* "Yes")) ; (initget "Yes No") (setq ans (cond ; ( (getkword "\nBack to model space [Yes/No] <No>: ") ) ( (getkword (strcat "\nBack to model space [Yes/No] <" *ans* ">: ")) ) ( *ans* ) ; ( "No" ) ) ) ; reset default (setq *ans* ans) ; (if (= ans "Yes") (_RestoreView)) ; ) ; progn ptlist (princ "\n** Invalid Point ** ") ) ; if ; ) ; while ) ; progn ; add loop end (princ "\nStart Program in Model Space ") ) (princ) ) ; defun NVM ; =========================================================================================== ; ; Okno dialogowe z lista (list_box) / Dialog control with list (list_box) ; ; Data [list] - lista do wyswietlenia / list to display ; ; Pos [INT] - pozycja poczatkowa na liscie / select list position ; ; Title [STR/nil] - tytul okna / window title ; ; ListTitle [STR/nil] - tytul list_box / list_box title ; ; Width [INT] - szerokosc / width ; ; Height [INT] - wysokosc / height ; ; Btns [0/1/2] - [cancel/ok/ok_cancel] przyciski / buttons ; ; MSelect [T/nil] - dopuszczenie multiple_select / allow multiple select ; ; DPos [T/nil] - zapamietanie pozycji okna / save window position ; ; DblClick [T/nil] - podwojny klik (wykluczone Cancel) / double click (not for Cancel) ; ; ------------------------------------------------------------------------------------------- ; ; Zwraca / Return: ; ; nil = nic nie wybrano (anulowano) / nothing was selected (canceled) ; ; INT = wybrano jedna pozycje / one position selected | MSelect = nil ; ; LIST = wybrano kilka pozycji / few positions selected | MSelect = T ; ; ------------------------------------------------------------------------------------------- ; ; (cd:DCL_StdListDialog '("A" "B" "C") 0 "Title" "ListTitle:" 40 15 2 nil T nil) ; ; =========================================================================================== ; (defun cd:DCL_StdListDialog (Data Pos Title ListTitle Width Height Btns MSelect DPos DblClk / f tmp dc res) (if (not DPos) (setq *cd-TempDlgPosition* (list -1 -1))) (cond ( (not (and (setq f (open (setq tmp (vl-FileName-MkTemp nil nil ".dcl")) "w" ) ) (foreach % (list "StdListDialog:dialog{" (strcat "label=\"" (if Title (strcat Title "\";") "\"\";") ) ":list_box{key=\"list\";" (if ListTitle (strcat "label=\"" ListTitle "\";")"" ) "fixed_width=true;fixed_height=true;" (strcat "width=" (if (not Width) "20" (itoa Width))";" ) (strcat "height=" (if (not Height) "20" (itoa Height))";" ) (if (not DblClck) (strcat "multiple_select=" (if MSelect "true;" "false;") ) "multiple_select=false;" ) "}" (cond ( (zerop Btns) "cancel_button;") ( (= 1 Btns) "ok_only;") (T "ok_cancel;") ) "}" ) (write-line % f) ) (not (close f)) (< 0 (setq dc (load_dialog tmp))) (new_dialog "StdListDialog" dc "" (cond ( *cd-TempDlgPosition* ) ( (quote (-1 -1)) ) ) ) ) ) ) ( T (start_list "list") (mapcar (quote add_list) Data) (end_list) (if (not Pos) (setq Pos 0) (if (> Pos (length Data)) (setq Pos 0)) ) (setq res (set_tile "list" (itoa Pos))) (action_tile "list" (strcat "(setq res $value)(if DblClk (if(or(not MSelect)" "(not (zerop Btns)))" "(if (= $reason 4)(setq " "*cd-TempDlgPosition* (done_dialog 1)))))" ) ) (action_tile "accept" "(setq *cd-TempDlgPosition* (done_dialog 1))") (action_tile "cancel" "(setq res nil) (done_dialog 0)") (setq res (if (= 1 (start_dialog)) (read (strcat "(" res ")")) nil ) ) ) ) (if (< 0 dc) (unload_dialog dc)) (if (setq tmp (findfile tmp)) (vl-File-Delete tmp)) (if (not DPos) (setq *cd-TempDlgPosition* (list -1 -1))) (if res (if (= 1 (length res)) (car res) res)) ) (princ "\n Type NVM to Invoke ") (princ) thanks
