  1. Today
  2. Yesterday
  3. Last week
  4. pkenewell
    about grread deselect objects
    @masao_8 Here is a solution for a simple single selection add and SHIFT-Select to remove. Perhaps this will give you a basis for starting: ;; Function to do a simple Select/Deselect using grread. ;; By PJK - 6/16/2026 (defun pjk-grread-Select (/ done en grl grc grv ss) (if acet-load-expresstools (acet-load-expresstools)) (setq ss (ssadd)) (princ "\nSelect to add objects or SHIFT+Select to remove from selection set: ") (while (not done) (setq grl (grread T 15 2) grc (car grl) grv (cadr grl) ) (cond ((= grc 3) (if (setq en (car (nentselp grv))) (if (acet-sys-shift-down) (progn (if (ssmemb en ss)(ssdel en ss)) (redraw en 4) ) (progn (ssadd en ss) (redraw en 3) ) ) ) ) ((= grc 2) (setq done (if (vl-position grv '(13 32)) T nil)) ) ((= grc 25)(setq done T)) ) ) (if (> (sslength ss) 0) (progn (foreach i (mapcar 'cadr (ssnamex ss))(redraw i 4)) ss ) nil ) )
  5. Okay, thank you for reminding me!
  6. BIGAL
    Contour line help requested
    Welcome aboard, have you looked at a Bricscad version ? Its Civil option is gaining more interest.
  7. pkenewell
    Perhaps you could use the undocumented (acet-sys-shift-down) express tools function within the grread loop? Then you would have to manipulate highlighting with (redraw [3/4]) and use (ssadd) and (ssdel) to update the selection set.
  8. SLW210
    Doesn't that depend on PICKADD value? I do believe the default is select to add and shift select to deselect from selection set. To that end, it needs to be clarified from OP what they need, my WAG is something being already done with grread and need to deselect. AFAIK (and that's very little, mostly from my previous thread ) The left click is doable with grread, but it would ignore the SHIFT (also CTRL, etc.), so probably would need something else to show the SHIFT key is pressed. Which reminds me I need to get back to work on that and the centerline on rivers, roads, etc. problem when I get regular work caught up.
  9. mhupp
    Isn't that how CAD works already? you select something either by mouse clicke or window it will be highlighted hold shift to deselect it the same way. I know if you have to many things selected they are no longer highlighted.
  10. ichernitsky
    https://chernitsky.net/blog/DeAEC DeAEC is the perfect solution! DeAEC_2025.dll
  11. Steven P
    I think you would need to test for 'shift' being pressed and the test for a left mouse entity selection. Do a 'princ' on your grread loop to display what you are doing, shift and select something - which should give you what you want to test for.
  12. Is it possible to use the grread function to deselect objects by holding down the SHIFT key+left click?
  13. @yangguoshe in the future use Code Tags for your Code. (<> in the editor toolbar)
  14. Is this done for free? Do not create more than one thread for the same exact topic, I deleted the other thread.
  15. @yangguoshe Thank you very much! This is a great addition to Lee Mac's code. Thanks to all who responded! Nothing is impossible
  16. ;;;You can call Master Leemac's code, but do not modify it (defun c:ttt(/ CPB NEW-PT OBJ PT) (c:cb) (setq cpb (entlast)) (setq pt (cdr(assoc 10 (entget cpb)))) (setq obj (vlax-ename->vla-object cpb)) (setq new-pt (vlax-3d-point (getpoint pt "\n Specify the new location"))) (vla-move obj (vlax-3d-point pt) new-pt) (princ) )
  17. Earlier
  18. What I posted just renames an existing block does not copy or move just replaces at current location. Yes using bedit is an old way of doing things but it is normally instant. Old like me.
  19. I didn't think it was difficult or impossible to accomplish...
  20. ve built a parametric furniture automation system in AutoLISP/VLAX for BricsCAD Mechanical — covering wardrobes, walk-in closets, kitchen furniture and built-in cabinet assemblies (corpus, fronts, drawers, shelves, partitions). The system generates full 3D solid models from parameters, with automatic 2D documentation output. Curious if anyone here is working in furniture/joinery manufacturing and struggling with repetitive CAD work — or has tried building something similar in LISP. Also open to building a custom parametric furniture library for specific manufacturers — their dimensions, their construction standards. Happy to discuss the architecture or share a demo when ready.
  21. Simple enough to use getpoint to make it dynamic. Update helper MB with (setq ed (entget (vlax-vla-object->ename newobj))) ;same (setq spt (getpoint "\nCopy to Location: ")) ;add line (entmod (subst (cons 10 spt) (assoc 10 ed) ed)) ;update but why not just copy block then use rb?
  22. In the future please use Code Tags for your Code, not Quote Tags. (<> in the editor toolbar). Do you have a link to the original code? Can you show what you edited? I second, please attach a before and after .dwg. @dlanorh hasn't been here in a few years.
  23. Thanks @mhupp, but it's inconvenient to put a copy in 0.0.0. And if the block is located at the top right at a distance of 5 km from 0.0.0? Then you will have to search for this copy in a large file for a long time.
  24. Sample drawing with correct layers and what your looking for? For mtext update the entmake with the following. 71 is the text justification defaulting to mid center. use \n for next line. (defun rh:em_mtxt (pt txt lyr ang hgt) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") (cons 8 lyr) (cons 50 ang) (cons 7 (getvar 'TEXTSTYLE)) (cons 1 txt) (cons 10 pt) (cons 40 hgt) (cons 50 ang) '(71 . 5) ) ) ) (rh:em_mtxt '(0 0 0) "hello\nthere" "0" 0 0.5) rh:2azimuth can be replace with (angtos l_ang 1 5)
  25. I would maybe start again, if you look at this https://www.lee-mac.com/polyinfo.html it will find arcs etc in plines So if you want to label Lines, Arcs, Circles and Plines, you may need different code that looks at each entiity and correctly labels. I had a quick google and found a few programs I know that Kent Cooper has something similar to Lee's, but labels each segment. Search also "forums/autodesk".
  26. I have this Lisp (Edited by me) that works really well. However I would really appreciated being able to incorporate three things beyond my skill level: - Arc Lengths with the prefix "A" - Mtext output rather than standard Text (I tried simply changing TEXT to MTEXT and a few other tweaks without success) - Remove trailing 00" (I already have a work around for this but it would be great to have incorporated into the existing lisp) Any help is greatly appreciated. ;;Bearing and Distance 4 © 2020 Ronald Harman (dlanorh) ;;Released under MIT Licence https://opensource.org/licenses/MIT (vl-load-com) (defun rh:R2D (r) (* 180.0 (/ r pi))) (defun gc:round (num prec) (if (zerop (setq prec (abs prec))) num (* prec (fix ((if (minusp num) - +) (/ num prec) 0.5))))) (defun rh:midpoint ( pt1 pt2 / pt3 ) (setq pt3 (mapcar '(lambda (x y) (/ (+ x y) 2)) pt1 pt2))) (defun rh:2azimuth ( a_brg / d a_azi) (setq d (fix a_brg)) (cond ((and (>= d 0) (< d 90)) (setq a_azi (- 90 a_brg))) ((and (>= d 90) (< d 180)) (setq a_azi (- 360 (- a_brg 90)))) ((and (>= d 180) (< d 270)) (setq a_azi (- 270 (- a_brg 180)))) ((and (>= d 270) (< d 360)) (setq a_azi (- 90 (- a_brg 360)))) ) (setq d a_azi) );_end_defun ; converts radian brg to dms text (defun rh:2dms ( r_brg rnd / d_brg d m s b_str) (setq d_brg (rh:2azimuth (rh:R2D r_brg)) d (fix d_brg) m (fix (* (rem d_brg 1.0) 60)) s (gc:round (* (rem (* (rem d_brg 1.0) 60) 1.0) 60) rnd) );_end_setq (if (>= s 59.5) (setq m (1+ m) s 0.0)) (if (= m 60) (setq d (1+ d) m 0)) (if (>= d 360) (setq d (- d 360))) (setq s (rtos s 2 0) m (itoa m) d (itoa d)) (if (< (atoi s) 10) (setq s (strcat "0" s))) (if (< (atoi m) 10) (setq m (strcat "0" m))) ;(while (< (strlen d) 3) (setq d (strcat "0" d))) (setq b_str (strcat d "\260" m "'" s "\"")) );_end_defun (defun rh:em_txt ( pt txt lyr ang tht d72 d73) (entmakex (list '(0 . "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText") (cons 8 lyr) (cons 50 ang) (cons 7 (getvar 'textstyle)) (cons 1 txt) (cons 10 pt) (cons 40 tht) (cons 72 d72) (cons 11 pt) (cons 73 d73) ) ) );end_defun ;;BEGIN MAIN ROUTINE (defun C:BAD ( / *error* sv_lst sv_vals tht b_lyr_lst d_lyr_lst lyr_idx d_rnd a_rnd lans pik lyr_e l_lst lt dv txt b_lyr d_lyr l_obj l_ang a_txt l_txt m_pt i_ang d_pt) (setvar "DIMZIN" 8) (defun *error* ( msg ) (mapcar 'setvar sv_lst sv_vals) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred."))) (princ) );_end_*error*_defun (setq sv_lst (list 'cmdecho 'osmode 'dynmode 'dynprompt 'textsize) sv_vals (mapcar 'getvar sv_lst) );end_setq (mapcar 'setvar sv_lst '(0 0 3 1)) ;; User Variables (setq b_lyr_lst (list "Text_3.5 Bearing" "Text_2.8 Bearing Connection") ;; Bearing Layer list (first item is always default) d_lyr_lst (list "Text_3.5 Distance" "Text_2.8 Distance Connection") ;; Distance Layer list (first item is always default) lyr_idx 0 ;; Index for the above lists PLEASE DON'T CHANGE d_rnd 3 ;; Rounding for distance (Integer, number of decimal places) a_rnd 5.0 ;; Rounding for angles (Real Seconds of Arc) );end_setq (initget "Boundaries Connections") (setq lans (cond ( (getkword (strcat "\nUse Boundaries (" (nth lyr_idx b_lyr_lst)" & " (nth lyr_idx d_lyr_lst) ") or Connections Layers : ? [Boundaries/Connections] <Boundaries>"))) ("Boundaries"))) (if (= lans "Connections") (setq lyr_idx 1 pik "Boundaries") (setq pik "Connections")) (setq b_lyr (nth lyr_idx b_lyr_lst) d_lyr (nth lyr_idx d_lyr_lst)) (foreach lyr (list b_lyr d_lyr) (if (not (tblsearch "layer" lyr)) (setq lyr_e T l_lst (cons lyr l_lst)))) (cond (lyr_e (if (= (length l_lst) 2) (setq lt "layers" dv " , ") (setq lt "layer" dv "")) (setq txt (strcat "MISSING LAYERS\n\nOption " lans " " lt " : ")) (mapcar '(lambda (x) (setq txt (strcat txt x dv))) l_lst) (setq txt (vl-string-right-trim " ," txt)) (alert (strcat txt "\n\nPlease rectify missing " lt " or re-run\nand select " pik " option")) ) );end_cond (missing layers) (initget 6) (setq tht (cond ( (getreal (strcat "\nEnter Text Size : <" (rtos (getvar 'textsize) 2 3) ">"))) ( (getvar 'textsize)))) (cond ( (not lyr_e) (princ "\nSelect Lines : ") (setq ss (ssget '((0 . "LINE")))) (cond (ss (repeat (setq cnt (sslength ss)) (setq l_obj (vlax-ename->vla-object (setq ent (ssname ss (setq cnt (1- cnt))))) elst (entget ent) l_ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv ent 0)) a_txt (rh:2dms l_ang a_rnd) l_txt (rtos (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2 d_rnd) m_pt (rh:midpoint (vlax-get l_obj 'startpoint) (vlax-get l_obj 'endpoint)) );_end_setq (setq i_ang l_ang) (if (and (>= l_ang (* pi 0.5)) (< l_ang (* pi 1.5))) (setq i_ang (- l_ang pi) d_pt (polar m_pt (- i_ang (* pi 0.5)) (* tht 0.3))) (setq d_pt (polar m_pt (- i_ang (* pi 0.5)) (* tht 0.3))) );end_if (rh:em_txt m_pt a_txt b_lyr i_ang tht 1 1) (rh:em_txt d_pt l_txt d_lyr i_ang tht 1 3) );end_repeat ) );end_cond ) );end_cond (mapcar 'setvar sv_lst sv_vals) (princ) );_end_defun (princ)
  27. I understand @Nikon I don't like to re-writting lee's code but will give it a try. will need to move new & src to the other side of / and update cb and rb calls. (defun c:cb nil (LM:RenameBlockReference t nil)) (defun c:rb nil (LM:RenameBlockReference nil nil)) (defun LM:RenameBlockReference ( cpy src / *error* abc app dbc dbx def doc dxf new old prp tmp vrs ) -Edit Helper function "MB" at the bottom update entmod inside that with the specified location . Right now its set to 0,0,0
