Showing results for tags 'drawing size'.
  1. Hey everyone, I'm a Landscape Architect using CAD and often experience the painful experience of plotting very large sets towards the submittal due date. My most recent set after everything was submitted was 158 pages and 230MB. Remember this is just the Landscape addition to a much much larger set. Something to note that brings me here is that from our last submittal to this one was the difference of about 100MB, but with a relatively minimal amount of actual changes occurring in the drawings. So this brings me to my question. Where did the 100MB come from? This question has two parts: FIRST (PLOT MANAGEMENT): I'd love to hear all of your standard order of operations when it comes to plotting for small file sizes. Are there any particular CAD settings to PDF that can reduce the file size? PDF quality control settings? etc? SECOND (DRAWING MANAGEMENT): Which parts of a CAD drawing end up contributing to the bulk of PDF file size? Do the xrefs attached to drawings have a large effect? Blocks? General overall file size? I feel as if there is a compounding issue that occurs but when there are so many drawings involved in architectural drawing sets it's hard to know where to begin.
  2. kaywond
    unit conversions
    Hi, For an autocad assignment, we have been given a drawing in engineering notation (feet and inches) and have to draw it with SI units dimensions. Doing the drawing was fine, BUT, I drew it in inches and thought that I could change it to millimetres. I have used the units command initially to set up engineering. Then after drawing returned to units to change to decimal. Dimensions turned out in inches regardless. I also tried the scale command to alter the scale, then dimension , still no luck. I went into the annotation menu got to modify primary units and alternate units and still no luck. Could someone please help. Not even my tutorial teacher knows how to do this.
