Showing results for tags 'line color'.
Line color differs over another line
mickeforsberg posted a topic in AutoCAD Drawing Management & Output
Hello, Sorry if this has been answered before, I'm not sure what to search for. I just have one question. I have a layer with a black line. Over that I have another line from another layer, colored yellow. However, the yellow color differs slightly from the color I have chosen, when the line is drawn over the black line. Looks like it's about 50/50 of each color. I have tried to put the yellow line "above object" and sending back the black line. Do you guys have any suggestions? I uploaded an image to illustrate. The right example is what I'm trying to get, without breaking the black line beneath. Thanks! -
How Do You Change Line Color in Parts List - Mechanical 2010
gek2425 posted a topic in Mechanical & MDT
How Do You Change the Line Color the in the Parts List? - Mechanical 2010. The existing line color is red and for other drawings, it's yellow. -
How to get a CTB colour to display on-screen as will plot
bjsmith77 posted a topic in AutoCAD Drawing Management & Output
Hi Guys, I've been using CTB files to manage line colours, thicknesses etc - assigning a specific colour number to a line colour/thickness etc. This results in great looking plots, but aren't the colours that appear on-screen. I was wondering how can I make it look exactly like what you'll get but retain the automation/functionality of CTB files - rather than manually stuffing around with changing line weights/colours etc. Many thanks Ben -
Change color for every line in the drawing.
SteveCW19 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello. I currently have a 2D drawing of my company's building map. Some of the parts of the map were originally placed in red. I want the WHOLE MAP IN BLACK. The only way as of right now that I can do this is to go to -Tools - block editor then change each line separately. This is extremely time consuming. Does anyone know of a possible solution to get every single line in the document as black?
