Showing results for tags 'text size'.
  1. So recently we got few assignments and we were given the given the video on how to like make 3D object and select it and a new page called layout is formed where all the views like top, front, side and isometric view can be displayed for the selected object. I have already set the Units and limits which is in mm and 297 x 210 mm and text size to 5, but when I am adding text in the layout which is in inches I believe its way too big ofcourse but the same thing when my Sir/Professor did there wasn't a problem but it could be that the page layout was already set in mm which I did later and the text size problem was fixed but now the problem was that the dotted lines suppose for a cube the one which supposed to be on other side are like really small and when I convert it to pdf form I am not able to see it which wasn't the case when my Sir did it and also I did not have the page border which I was having when the page layout was in inches. So if anyone knows how I can fix/set the layout settings/options correctly for the page layout/Base please let me know, it would be great if I can get reply quickly cause I have to complete these assignments as soon as possible.
  2. sandiegophil
    trouble with toolpalettes
    Hello, I am having trouble with the text size of the toolpalettes. All other items are just fine. If you have any suggestions it would be greatly appreciated. I am running 2016 and 2018, 2018 looks great, 2016 looks like the image below Regards, Phil
  3. I have created a new multileader with the settings that the multileader type is "block" so that the end of the leader will have a detail bubble on the end, my problem I am running into is the text size inside that bubble is too small, how do i adjust the text size with keeping the bubble the original size? I have the bubble the size I want it at by adjusting the scale to 10", anybody have an idea what to do?
