When I am typing in ACAD I type in all CAPS, however if I go to another program, like E-Mail, I need to switch the caps off. Any one know of a program that will do this for me automatically so I do not have to remember to turn if on and off everytime I switch from ACAD to a program and back to ACAD again? I found a program called CapsWiz at MajorGeeks.com that works perfect for this, however it is a program you must purchace. I am not against purchasing it, as I belive credit should be given to thoughs who deserve it, I was just wondering if anyone knew of a free program because this does not seem like a very dificult task to accomplish and with CapWiz I would be also paying for a bunch of stuff I dont need or want that comes with it.
  • Replies 30
  • AQucsaiJr
    11
  • StevenMc
    7
  • ReMark
    5
  • lpseifert
    5
Popular Days
One option: Leave CAPS LOCK turned off, and turn on AutoCAPS in AutoCAD.
hmm.... I did not know there was an auto caps in ACAD... Thanks for the tip... I'll look into this.
where is this setting? sounds like quite a handy one :)
is it a variable?
It's an option found in the Mtext Text Formatting toolbar. Dbl-clk on a piece of Mtext, click on the down arrow.
I cant acually find this AutoCAPS in the help as a command. I found it in the text but it seems to require you to manually change the case from lower to upper on each line of text, if I am reading it correctly.
Does this only work in MTEXT though? I don't use MTEXT.
It's an option found in the Mtext toolbar. Dbl-clk on a piece of Mtext, click on thr down arrow.
so it has to be MText then.
i only use single line text.
Dang! well that fixes the problem with MTEXT but anyone know how to do it for single line text?
Why not use Mtext? I find that it is more versatile and easier to edit.
Caps Lock key.
Well I can't answer for others but my problem with it is most of my clients run ACAD 2000 or below and MTEXT does some funny stuff on there systems.
this is a very common disagreement in a lot of offices and general use of AutoCAD.
Caps Lock key works great, but when I start typing in a document or e-mail and don't think to turn off the Caps Lock key it is very aggravating to have to re-type it.
Caps Lock key.
thats the problem though he doesnt want to keep pressing the CAPS lock key everytime he switches from other programs to AutoCAD :?
HAHA, I said the exact same thing when I read that! I need to find that feature! LOL
AutoCAPS in located under Options in multiline text. Upper right hand corner. Click the circle with the Down arrow in it.
