my ribbons missing
xxjoshiexx
when i load autocad it says "The ribbon does not have any tabs or panels currently loaded"
ive tried everything i can find and cant make anything show up there. im on page 4 of 800 in my AutoCad book and it doesnt say what to do if nothing is there in the way of tools to use.. how can i make my toolbars appear? ive tried typing "ribbon" but nothing... please help!!!!
Link to post
  • Replies 56
  • ReMark
    17
  • Polly64
    12
  • Dadgad
    6
  • Dana W
    5
papagyi
You can see about ribbon ......http://www.ellenfinkelstein.com/autocadtips/AutoCAD_tips_add_command_ribbon.html
This is your ribbon toolbar problem....http://worldcadaccess.typepad.com/blog/tips/index.html
Link to post
xxjoshiexx
when i click the workspace button it doesnt even have the options that the book or the website say should be there.. its got "customize" "workspace settings" and "save current as"...
Link to post
ReMark
Did you ever have toolbars at all? If not, could it be a bad install? If it were then the repair option may be the way to go. Anyone else use this computer other than you?
Link to post
papagyi
When you type in command "-toolbar",autocad can't any respone you should be do as Remark.
Link to post
  • 5 months later...
MsTechTeacher
From ReMark -
"Did you ever have toolbars at all? If not, could it be a bad install? If it were then the repair option may be the way to go. Anyone else use this computer other than you?"
I am missing all the toolbars and menus aside from about 3 in the drop down menu for some users, but not all. This is a high school computer lab and I can sometimes have students move to another computer and then the ribbon and toolbars work fine for them there for a period of time. Different students can use the same computer and everything is there.
The command lines come up on the other programs that are loaded and I am going to try the Reset CUI suggestion that was made, but are there any other suggestions out there?
Thank you so much!
Link to post
MsTechTeacher:
Welcome to the CADTutor forum. Are you actually referring to the Ribbon and its Panels or did you opt to work from the old pull down menus (now called Classic AutoCAD) by setting the menubar variable to "1"?
Link to post
  • 7 months later...
barraganarq
go to this page and read "menus and ribbon"
I just went to the initial setup.
that worked for me :D
good luck
Link to post
  • 3 weeks later...
christov182
This post has all the questions but no answers.
You spoke to microdesk and they told you to delete a reg key... . .
That's usefull. what one?
Link to post
  • 6 months later...
Sorry to bump an old thread but I had the same problem and the solution was:
Type "Menubar" in the command line, set to "1", you should then have the file, view, edit, etc bar at the top. Go to "Tools" then workplaces and select the "ACADE & 2D Drafting & Annotation" and the menubar will pop up.
Link to post
  • 2 weeks later...
I had the same message: "The ribbon does not have any tabs or panels currently loaded".
I have done what Millski said and it works!....I have recover all my Ribbons.
Thank you very much! I was allmost reinstalling my Autocad 2010 when I find this forum.
Sorry for my english.
Link to post
  • 1 month later...
MOS11BRAVO
The Ribbon does not have any tabs panels currently loaded; How do I reload these?
I had a fatal error and when I rebooted and brought up the ribbon, I got this message.
Link to post
  • 1 month later...
Well, I seem to be having the same problem. Been away for the last couple of weeks and just opened autocad now to find the ribbon has disappeared with the message "the ribbon does not have any tabs panels currently loaded". I've followed all the tips in this thread but still no luck in retrieving the ribbon! The odd thing is that the ribbon is only missing in "2D drawing and annotation" and "3D modelling" workspaces and yet is visible when I switch to "autocad classic".
Link to post
Yep....thats the first thing I tried....but didn't work. Maybe I should try shutting it down for longer?
Thanks for the quick reply, by the way! :-)
Link to post
I think I've tried everything....I did a search on this site and I'm still browsing through the many threads in the hope of finding a solution. Only other option is to just use AutoCad Classic workspace since thats the only one left with a ribbon.
Link to post
