azman
how to convert 2d polyline to polyline
azman
Hi,
i have 2D polylines and want to convert to polylines, but to no avail. Anyone?
tried to 'spline2pline' this line, but ACAD refuse to select it.
Tq
2dpl.dwg
Share this post
Link to post
nocturne00
can you elaborate more?
a 2D polyline is the same as a polyline.
now a 3d polyline is the one different from a 2dpolyline/ polyline
Share this post
Link to post
SEANT
The CONVERTPOLY command will transform a 2DPoly(Heavy) to a LightWeight Poly(Light) or vice versa.
Share this post
Link to post
inevelus
2d polylines are definitely NOT the exact same as polylines.
very close though.
draw a 2d polyline and a regular polyline and try to offset both of them and see what happens. the 2d will remain a 2d polyline but will now have about 10 times as many handles making it a little unmanageable for editing. the polyline will keep the same amount and spacing of handle.
a 2d polyline wil take up more memory than a regular polyline, as the vertex information is stored differently. the current 2d polyline system is how all 2d polylines used to be stored, and cad moved towards the newer way, "regular polylines" to cut down on memory use and regen time.
most importantly, i think we can all agree that splines suck.
Share this post
Link to post
SEANT
That does seem to be the prevailing opinion, though I’m not sure why.
Share this post
Link to post
Tankman
Most importantly, i think we can all agree that splines suck.
Originally Posted by SEANT
"That does seem to be the prevailing opinion, though I’m not sure why."
Is there a command to change a spline to a polyline?
Share this post
Link to post
SEANT
The Express Tools FLATTEN command will convert splines to polylines, though that may not be useful if the 3D geometry must be maintained.
I have not seen a routine to convert a 3 dimensional Spline to a 3dPolyline but imagine it would be fairly straightfoward to write.
Share this post
Link to post
titashtalukdar
At this I tried the Drawing, The Lines Exploded by typing Explode and then PEDIT it, andf it will join and make it into a polyline
Share this post
Link to post
camilocm
To convert Spline to 3d polyline:
Save as DXF and then re-open, all spline will be 3d polyline
dxf 12 will work, i don´t know other versions
Share this post
Link to post
SEANT
Good Suggestion. And, welcome to the forum. :thumbsup:
Share this post
Link to post
psych
Try this..
(defun spline-to-pline (/ i)
 (vl-load-com)
 (setq *thisdrawing* (vla-get-activedocument
  (vlax-get-acad-object)
       ) ;_ end of vla-get-activedocument
*modelspace*  (vla-get-ModelSpace *thisdrawing*)
 ) ;_ end of setq
 (setq spline-list (get-spline))
 (setq i (- 1))
 (if spline-list
     (setq msg "\nNumber of segments <100>: ")
     (initget 6)
     (setq num (getint msg))
     (if (or (= num 100) (= num nil))
(setq num 100)
     ) ;_ end of if
     (repeat (length spline-list)
(setq splobj (nth (setq i (1+ i)) spline-list))
(convert-spline splobj num)
     ) ;_ end of repeat
   ) ;_ end of progn
 ) ;_ end of if
) ;_ end of spline-to-pline
(defun get-spline (/ spl-list obj spline no-ent i)
 (setq spl-list nil
obj  nil
spline  "AcDbSpline"
selsets  (vla-get-selectionsets *thisdrawing*)
ss1  (vlax-make-variant "ss1")
 ) ;_ end of setq
 (if (= (vla-get-count selsets) 0)
   (setq ssobj (vla-add selsets ss1))
 ) ;_ end of if
 (vla-clear ssobj)
 (setq no-ent 1)
 (while no-ent
   (prompt "\nSelect splines: ")
   (vla-Selectonscreen ssobj)
   (if (> (vla-get-count ssobj) 0)
(setq no-ent nil)
(setq i (- 1))
(repeat (vla-get-count ssobj)
  (setq
    obj (vla-item ssobj
    (vlax-make-variant (setq i (1+ i)))
 ) ;_ end of vla-item
  ) ;_ end of setq
  (cond
    ((= (vlax-get-property obj "ObjectName") spline)
     (setq spl-list
     (append spl-list (list obj))
     ) ;_ end of setq
  ) ;_ end-of cond
) ;_ end of repeat
     ) ;_ end of progn
     (prompt "\nNo entities selected, try again.")
   ) ;_ end of if
   (if (and (= nil no-ent) (= nil spl-list))
(setq no-ent 1)
(prompt "\nNo splines selected.")
(quit)
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of while
 (vla-delete (vla-item selsets 0))
 spl-list
) ;_ end of get-spline
(defun convert-spline (splobj n / i)
 (setq point-list   nil
2Dpoint-list nil
z-list      nil
spl-lyr      (vlax-get-property splobj 'Layer)
startSpline  (vlax-curve-getStartParam splobj)
endSpline    (vlax-curve-getEndParam splobj)
i      (- 1)
 ) ;_ end of setq
 (repeat (+ n 1)
   (setq i (1+ i))
   (setq p (vlax-curve-getPointAtParam
      splobj
      (* i
  (/ (- endspline startspline) n)
      ) ;_ end of *
    ) ;_ end of vlax-curve-getPointAtParam
   ) ;_ end of setq
   (setq 2Dp        (list (car p) (cadr p))
  2Dpoint-list (append 2Dpoint-list 2Dp)
  point-list   (append point-list p)
  z        (caddr p)
  z-list       (append z-list (list z))
   ) ;_ end of setq
 ) ;_ end of repeat
 (setq summ (apply '+ z-list))
 (setq arraySpace
 (vlax-make-safearray
   vlax-vbdouble ; element type
   (cons 0
  (- (length point-list) 1)
   ) ; array dimension
 ) ;_ end of vlax-make-safearray
 ) ;_ end of setq
 (setq vert-array (vlax-safearray-fill arraySpace point-list))
 (vlax-make-variant vert-array)
 (if (and (= :vlax-true (vlax-get-property splobj 'IsPLanar))
   (= summ 0.0)
     ) ;_ end of and
   (setq plobj (add-polyline
   2Dpoint-list
   vla-AddLightweightPolyline
 ) ;_ end of add-polyline
   ) ;_ end of setq
   point-list
   vla-Add3DPoly
   ) ;_ end of setq
 ) ;_ end of if
 (vlax-put-property plobj 'Layer spl-lyr)
 (vla-delete splobj)
 (vlax-release-object splobj)
) ;_ end of convert-spline
(defun add-polyline (pt-list poly-func)
 (setq arraySpace
   vlax-vbdouble
   (cons 0
  (- (length pt-list) 1)
   ) ; array dimension
 ) ;_ end of setq
 (setq vertex-array
 (vlax-safearray-fill arraySpace pt-list)
 ) ;_ end of setq
 (vlax-make-variant vertex-array)
 (setq plobj (poly-func
 *modelspace*
 vertex-array
      ) ;_ end of poly-func
 ) ;_ end of setq
(defun c:s2p ()
 (spline-to-pline)
) ;_ end of c:s2p
(prompt
 "SPLINE-TO-PLINE by Tony Hotchkiss. Enter S2P to start"
) ;_ end of prompt
Edited by SLW210
Add Code Tags!
Share this post
Link to post
McWaters12
When I try to convert a 2d polyline to a regular polyline, it then asks me to choose between options like 'open' 'fit' 'close'. I'm not really sure which one to choose. I have been choosing 'open' but then it's like i have to choose it thousands of times. I don't know what is going on.
Share this post
Link to post
SLW210
To get out of the pedit you should hit enter or escape.
Share this post
Link to post
shrimpbiscuits
Try using overkill. It worked for me. I learned it from a good friend, a legend in the CAD industry that goes by the name candymountain.
Share this post
Link to post
ReMark
shrimp: You're suggesting the use of Overkill to obtain what end result?
Share this post
Link to post
shrimpbiscuits
It will convert 2d polylines to polylines
Share this post
Link to post
ReMark
Well let's hope the OP did not wait until June 2008 for an answer. But it will prove useful to others with the same question.
You're in the running for today's prize for the person that resurrects the oldest thread. 4 years 6 months. LoL
Share this post
Link to post
shrimpbiscuits
Haha, yeah I know its old as hell but I did a search on google and couldnt find any answers on it so when I found this thread I joined today to make sure the answer is out there for anyone who may need it in the future.
Share this post
Link to post
SLW210
OVERKILL doesn't work here to convert 2D Polyline to Polyline.
CONVERTPOLY works just fine as does PEDIT.
Share this post
Link to post
shrimpbiscuits
Neither one of those worked for me for converting from 2d to a regular poly but overkill did just what I needed for some reason.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
