Nick-H- Posted October 21, 2009 Share Posted October 21, 2009 I have inserted an XREF into a drawing and it comes in rotated about 50 degrees , but when i open the xref its not rotated. How do i solve this? Also is there a way of bringing in an XREF and making it all grey? without chaning all the layers Nick Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2009 Share Posted October 21, 2009 From what I recall the External Reference dialog box looks very similar to the Block insertion dialog box in that the user can input a rotation angle in the dialog box or elect to Specify on-screen. Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 its all set to zero :S Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2009 Share Posted October 21, 2009 It doesn't matter what it is set to. As the user you can override it at the dialog box or enable Specify on-screen and set the angle when prompted upon insertion. Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 it will be a ucs problem from one drawing to another i think you can lock the layers of the xref and get them to gray that way but only on screen if i remember correctly ? using laylockfadectl Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 How to I go about sorting this UCS problem out? Nick Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 type uscicon inboth drawings that is if it is not allready dipladed are they the same ie in modelspace of you x ref and model space or your drawing that you are inserting in to are they the same if not make them the same in your new drawing using ucs command Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 sorry type ucs world in the xref drawing and check world ucs in the second drawing does take a bit of getting use to Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 The UCS's are both the same and it still rotated Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 can anyone help ? Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 do both drawings have the same world ucs ? Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 what do you mean by that? Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 go to each drawing in turn in model space type ucs return w return is the ucs icon the same Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2009 Share Posted October 21, 2009 Per your AutoCAD Help file. Always a good place to start. "There are two coordinate systems: a fixed system called the world coordinate system (WCS) and a movable system called the user coordinate system (UCS). By default, these two systems are coincident in a new drawing. Normally in 2D views, the WCS X axis is horizontal and the Y axis is vertical. The WCS origin is where the X and Y axes intersect (0,0). All objects in a drawing file are defined by their WCS coordinates. However, it is usually more convenient to create and edit objects based on the movable UCS." Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 sorry just being thick here, yeh the UCS are both the same Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2009 Share Posted October 21, 2009 No problem. Take a moment open Help go to the Index tab and type in UCS Dialog Box. Look to the right. Click on the Concept tab.Read it. Then read it again. Return here with your questions if any. Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 Right read that and by typing plan, the UCS went back normal and them the drawing rotated to how it was in the XREF. How to I find out what rotation the UCS was at? Quote Link to comment Share on other sites More sharing options...
davebate Posted October 21, 2009 Share Posted October 21, 2009 it does not really matter if they where not the same you will have to rotate the xref in your drawing to suit ually we all work to the same world ucs over a project (everything drawn to real life coordinates) and a common world ucs use rotate and referance option to relocate the xref if you do not know the exact angle of rotation not the best way to work Quote Link to comment Share on other sites More sharing options...
Nick-H- Posted October 21, 2009 Author Share Posted October 21, 2009 Its getting to me now, I meaured the angle with a dimension and put the precision high, it says its 50 degrees, so i rotate, and grid line arent perfectley straight but when i draw a straight line and then dimesion it against a grid line it says its 90 degress, im confused Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 21, 2009 Share Posted October 21, 2009 What angle type and precision are you using exactly? Have you tried using the REFERENCE option of the Rotate command? Quote Link to comment Share on other sites More sharing options...
