davebate Posted October 21, 2009 Posted October 21, 2009 use rotate reference option to align as said before no need to know the angle and it is always spot on Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 What angle type and precision are you using exactly? Have you tried using the REFERENCE option of the Rotate command? No ive not used that? how do I Quote
davebate Posted October 21, 2009 Posted October 21, 2009 Command: rotate Current positive angle in UCS: ANGDIR=counterclockwise ANGBASE=0 Select objects: 1 found Select objects: Specify base point: Specify rotation angle or [Copy/Reference] : r Specify the reference angle : _nea Specify second point: _nea to Specify the new angle or [Points] : this is the command line returns just type in rotate and follow the promts the reference angle can be any two points on the line the new angle just select the second line that you need to rotate to Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 Ive done that, and its still out, and ive just measured the angle is out by and its 0 degrees. what is going on haha! Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 if I upload the drawing can someone have a look at it Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Sure, why not. How badly can we mess it up? Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 Sure, why not. How badly can we mess it up? Here it is while your at it, can you put all layers onto one layer, and delete all the crap i dont need, i only need to be left with the building, furniture, toilets fittings ceiling grids... and grids and numbers :D http://www.sendspace.com/file/9b0o72 Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 Shall we take out the trash, walk the dog and water the lawn too? Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 please, i could do with a cup of tea aswell cheers Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 I got the drawing opened and there is stuff everywhere. I reoriented the UCS too. Do I keep everything inside the yellow border and get rid of everything outside of it or what? I used PURGE on it once and got the file size down from 5.65MB to 5.15MB. Putting all layers on one layer is usually NOT a good idea. Why do you want to do that? Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 you can delete most stuff, all i need really is doors, walls, room names, gridlines, ceilings columns, just the general building. just so i can put ductwork in, domestic pipework, A/C, heating pipework etc... just so it makes it easy when i use it as XREF so i dont have loads of layers i wont use, i try to get it down to just having these layers BUILDING (Xref) AC AC Text Vent Vent Text Heating Heating Text Domestic Domestic Text Quote
ReMark Posted October 21, 2009 Posted October 21, 2009 It probably would have helped if someone hadn't used so many nested blocks. Unbelieveable. I'm going to have to go soon. I've been doing this since 5:30 a.m. Will pick up where I left off on Thursday morning. Nite all. Quote
Nick-H- Posted October 21, 2009 Author Posted October 21, 2009 its the biggest on going building site in europe at the minute, could explain alot lol Quote
ReMark Posted October 22, 2009 Posted October 22, 2009 That's a nice short list of items to retain but after looking through all the layer names I notice your list is "generic" and does not match up with the layer names used. I really don't have the time or inclination to sort it all out. Sorry. Quote
Nick-H- Posted October 22, 2009 Author Posted October 22, 2009 its ok, i spent about 3 hours stripping it down to about 4 layers had to copy it an put it in a new drawing do now i have building ceiling furniture grids also im looking at ordering a new graphics card and 2gb more ram, will that help me problem this is the card http://www.overclockers.co.uk/showproduct.php?prodid=GX-194-AS Quote
ReMark Posted October 22, 2009 Posted October 22, 2009 As soon as I saw the website I thought "gamer". For your purposes it will be fine. I doubt it offers OpenGL 2.1 support. I'd have to check. I see it does offer DirectX 10 support. Quote
Nick-H- Posted October 22, 2009 Author Posted October 22, 2009 and how do i find out if it supports it? Quote
