Angled line problem
Test.dwg
ya the monitor uses OSD.
The monitor is a LG Flatron W2442PA
  • Replies 26
  • ReMark
    11
  • phillyphantom
    10
  • Dana W
    3
  • Coosbaylumber
    1
I could discern no problem with your test drawing. I zoomed in on the intersection 10 ways to Sunday and still saw no problem. Then I did a really tight Zoom > Window on the intersection and again, no problem with the geometry. Both lines also show a "Z" elevation of 0.00 so that rules out a 3D related problem.
I think it is either a graphics card or monitor resolution issue. My best guess at this point is that it has something to do with your monitor.
Ya, I figured that would be the case as it does it in everyone of my drawings.
Well thanks anywasy for all the help. I will continue to search for settings on my video card and monitor and maybe I will eventually figure this thing out.
Concentrate on changing just one thing at a time. I'd start with the monitor and go back through the settings available to you either via the OSD or any specific software that can with it (i.e. - drivers). If that does not solve the problem then move onto the graphics card.
  • 6 months later...
Just in case anyone cares. The problem went away when I installed the new AutoCad a while back. Forgot to update this when I got 2011.
Glad to hear that your problem disappeared. Thanks for updating us.
try purging your file using "purge" command then click "purge all" then audit your file using "audit" command and select "yes" to fix any errors detected.
