gargoyle27 Posted November 16, 2010 Share Posted November 16, 2010 so i have a file of a design that needs to get burnt on our burn table but on closer inspection the design is a series of straight lines instead of curves, the only way i can think to smooth it out would be to basically draw it again but using a spline between each connection, but that would mean basically drawing the whole thing again, is there another way or a faster way this can be done? the concern is that it's getting burnt out to be about 100x20" and the straight lines may become obvious Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 PEdit>Join>Fit Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 could you elaborate a little more? i can't get it to work, i'm using 2009 if it matters Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 Wait, does Inventor have PEdit? Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 no idea, im using autocad, but i could use inventor if that works better Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 No, I was just going by your provided information. Execute PEdit, select your objects, JOIN, FIT. Just read the prompts. Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 i've tried, nothing happens here's the file s09strechednoflurdelee.dwg Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 WOW, those are odd. Execute BPoly and pick a point within the closed areas (for this it would be three areas) and it will create the needed closed LWPolylines. Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 oh sweet, thanks a lot, you're the man (assuming of course, that you are A man...) Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 oh sweet, thanks a lot, you're the man (assuming of course, that you are A man...) As far as I know. Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 *shrug* i didn't want to be sexist, carry on Quote Link to comment Share on other sites More sharing options...
Wilbri Posted November 16, 2010 Share Posted November 16, 2010 Pardon my naivity here. Was the drawing produced using lines and curves or polylines? The reason for this question is that I was not aware that it was possible to convert lines to polylines using PEdit command Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 *shrug* i didn't want to be sexist, carry onNo worries. Pardon my naivity here.Was the drawing produced using lines and curves or polylines? The reason for this question is that I was not aware that it was possible to convert lines to polylines using PEdit command That's one of the main purposes of PEdit. Quote Link to comment Share on other sites More sharing options...
Wilbri Posted November 16, 2010 Share Posted November 16, 2010 I am using 2007 and am unable to achieve a result using PEdit>Join or Fit using the drawing supplied. Selected PEdit, select crossing section to include all components, then J,or F, NO GO! Asking me to select a polyline which does not exist. Do I need to alter some variable perhaps? Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 16, 2010 Share Posted November 16, 2010 I am using 2007 and am unable to achieve a result using PEdit>Join or Fit using the drawing supplied.Selected PEdit, select crossing section to include all components, then J,or F, NO GO! Asking me to select a polyline which does not exist. Do I need to alter some variable perhaps? It won't on that drawing - going to do a little digging tonight as to why. Try it on a different one. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted November 16, 2010 Share Posted November 16, 2010 I've been playing around with the drawing, and I can't get it to joiin either. It's made up of 1174 closed polylines. I tried exploding them, and then joining them again and it caused a fatal error...the first I've seen in 2010. something about that shape autocad just don't like. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted November 16, 2010 Share Posted November 16, 2010 Just curious, was this drawn with Autocad to begin with or imported from something else? Quote Link to comment Share on other sites More sharing options...
gargoyle27 Posted November 16, 2010 Author Share Posted November 16, 2010 i don't know where it came from, we just have a folder full of designs like that for windows and gates etc. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted November 16, 2010 Share Posted November 16, 2010 i don't know where it came from, we just have a folder full of designs like that for windows and gates etc. Ah, just wondering. It is a very nice pattern, in any case. Quote Link to comment Share on other sites More sharing options...
qball Posted November 17, 2010 Share Posted November 17, 2010 You can Pedit and Open them. Then Join them. Spline may make any points into curves, which may not be desired. It looks like it was done on some other program and imported because it's not symmetrical. Quote Link to comment Share on other sites More sharing options...
