alisonn Posted April 4, 2011 Posted April 4, 2011 Hello I use previous drawings to continue with new jobs. so... I started to use defpoints as the layer for the the viewing window. This is so it doesn''t print out. However to make new sheets I copy and paste new sheets. The problem is I cannot delete the viewpoints as it in Defpoints and becomes invisible in Paper space. How can I delete one window? Quote
ReMark Posted April 4, 2011 Posted April 4, 2011 Using the Defpoints layer to "hide" objects we don't want printed is an old trick that should now be abandoned. You should be creating a layer specifically for your Viewports and setting that layer to "No print" in your Layer Properties Manager. You want to delete a viewport that is on the Defpoints layer? Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Yes i want to delete that layer. I bet it is impossible! Quote
ReMark Posted April 4, 2011 Posted April 4, 2011 Once you add a dimension to your drawing the Defpoints layer will be recreated. You do know that right? Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Hi RE MARK Thanks for replying to me by the way. I read it that it was a good idea to us defpoints as your viewport so it wouldnt print out but once done you cannot delete them as there is no way to access and grab hold of the line- it is invisible! Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 no i didnt know that once you add a dimension to the drawing it will be created. But I was just reading about it in your threads now . Quote
ReMark Posted April 4, 2011 Posted April 4, 2011 I believe it can be done. However, did you read my last post? Quote
Tiger Posted April 4, 2011 Posted April 4, 2011 The problem with a viewport on Defpoints not being selectable is a known problem. The simple answer is don't do it. Like ReMark said, create a layer named Viewport and set it to non-plot. Defpoints will always be present, that is just the way it is. And in this case, to solve this drawing, I would simply delete that file and start a new one. Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Okay Tiger. So start my drawing all over again really. Quote
ReMark Posted April 4, 2011 Posted April 4, 2011 You may not be able to select and delete the viewport because layer "0" is frozen. Is it? BTW...I just verified this using AutoCAD 2010. Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Yes it is not a solvable because I wont be able to get rid of the drawing in the window unless i place the window over an area that has no drawing in it in Model Space ( and try never to use this file again) .Make a new layer called View port and hope that the two windows do not conflict with each other. by either stoping the new window with its contents from being viewed in paper space or when printed out later. Many Thanks for the suggestions. Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Remark The layer is not frozen. So I cannot understand why i cannot grip the window Quote
ReMark Posted April 4, 2011 Posted April 4, 2011 Post the drawing here and let someone take a look at it. Quote
nestly Posted April 4, 2011 Posted April 4, 2011 Yeah, post the drawing, however if the issue is simply with a stubborn viewport, I don't see the need to restart the drawing, just re-create the viewport(s) on a new layout tab, and then delete the troublesome layout. Quote
nestly Posted April 4, 2011 Posted April 4, 2011 Perhaps Defpoints is Off, Frozen, or Frozen by VP in Paperspace for that layout? Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Nestly Defpoints not off and is not frozen and you lost me VP in paperspace for the layout Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 Nestly that is the whole point, I cannot delete the view point in order to delete the layer- Quote
alisonn Posted April 4, 2011 Author Posted April 4, 2011 I could nt send the file- the file is 2500 MB and it said it was too large to send, other than by return of email. Not sure if that was the right thing to do? Quote
nestly Posted April 4, 2011 Posted April 4, 2011 Is your problem with a "viewpoint" or a "viewport" ? Assuming it's a viewport, here's a quick video showing how to create/copy layouts, and how to control viewport visibility in Paperspace. http://www.screencast.com/t/kw1L0hLxSol If you still want to upload the file, delete everything except a few objects and "SaveAs" another filename. (Please don't delete the objects in your original drawing.) Quote
