I think what Remark was getting at was-
Defpoints is somehow associated to Layer 0. If you Isolate Defpoints, it turns off Layer 0 (along with all other layers). You can see Defpoints, but not select it until you turn Layer 0 back on.
  • Replies 23
  • alisonn
    10
  • ReMark
    5
  • nestly
    3
  • Tiger
    1
Qball has it right, but the problem is that when you unisolate the layer it actually disappears from view altogether.
I think this is the problem that Alisonn is having.
Open layer manager both freeze and turn off layer 0 and also defpoints, Then unfreeze and turn them back on and do a regen.
You should now be able to select the defpoints layer again.
Don't know why it does this but it's happened to me many times.
  • 1 year later...
i had this issue "invisible viewport" tried everything with layers etc...
turned out if i double clicked into the viewport to make it active, then maximized the viewport the view port frame suddenly became visible and therefore i could erase it.
just dumb luck.
You could try deleting defpoints layer using LAYDEL and hitting N for name. it will delete the layer and everything on it.
