Make it stop! autosaving in the middle of a command
ok first off. I asked a question about how to prevent it from saving during a command. If your suggesting me to turn it off, then obviously you do not know how to read or just like wasting my time. I clearly said in my first post that i do not want to turn it off. (i revised it make it even more obvious) i like to have it on. It has saved my ass a number of times. I have a butt load of ram and a very good processor and video card and it rarely crashes. I only mentioned crashes because it does happen but not often enough to concern me. Im just annoyed that im in the middle of doing something and it locks up and starts to save. The fact that i save to a server further slows down the save process. If your computer isnt powerful enough to handle an autosave then by all means turn it off. But mine can handle it just fine. Its just an annoyance to me.
Obviously the answer is........ it is not possible.
thread closed
and you have recieved that answer first both times you have asked.
The admin or a moderator will determine when/if to close a thread. :rtfm:
Why did you not remove your threat, since you had time to alter your original question?
Manually saving will reset the timer, so set the auto save time to 10 and hit qsave every 9 minutes or more often. I qsave often and especially before rendering, plotting, switching to another drawing. I never see the auto save but I still have it set just in case I forget that one time in three months to save often enough and the program crashes.
Proves my point, autosave is not saving behinds as often as many think. Why do you think most programs do not have an autosave?
I have seen crashes corrupt the autosaves, so whether you use it or not SAVE is the only sure way to SAVE your work.
P.S. the first proclaimation from the OP was MAKE IT STOP! The correct answer to that is TURN IT OFF!
  • 6 years later...
Set up a message/task in Windows Task Scheduler to run at your desired time...
I set one up to start at 7:00 and alert me every 15 minutes:
e.g. short message: Time to save DWG
You can set it reset to your particular situation.
Also set Autosave in AutoCAD every 30 minutes just for fun...
If your job is set to work all day in the CAD environment it's not bad
Not a fix all but it's something. Somewhat annoying but so is when someone expels noxious gas
Edited by stevedrew
or resurrects a six year old thread.
  • 8 years later...
So did you ever figure out how to do it, OP? I don't know how someone doesn't manually save like every 5 min. I can tell now that this is not a natural reaction for everyone. I am a millennial and it's been metaphorically beaten in my head throughout my all school years to save often. I save after every small bit of changes that I make. Hope you found a way that works for you, though!!
  • Like 2
Agreed. I am 100% on the side of [turn Autosave OFF] and use one of the many ways to save your data file every time you do something you don't want to lose.
Never have I needed Autosave. CTRL+S is just a habit now, even in non-AutoCAD programs.
I also frequently Right-Click one of the Drawing Tabs and select Save All.
I also know the difference between Qsave and Save and use both appropriately. (Note: they are the same in AutoCAD LT or used to be, I am not sure about newer LT versions)
Saving your work is your job, not AutoCAD's.
I wonder if a LISP with a reactor would be less troublesome for those that do not trust going without an Autosave?
Or maybe this? A Better Autosave | AfraLISP
Or... (command ".save") to Visual LISP - AutoLISP, Visual LISP & DCL - AutoCAD Forums
Or... make a copy of current open drawing & place it into a predetermine folder - AutoLISP, Visual LISP & DCL - AutoCAD Forums
And... LISP - Automatic Save that runs at set intervals
I think the bottom line is how much are you prepared to lose in production time ? A autosave of say 1/2 hour to me sounds reasonable. Were I worked we had a power failure, a IT server disconnect. The power out showed how often people saved their work, renaming the sv$ helped. Another situation was some one just left dwg open for hours and there was some sort of problem, like SAVE I pushed our staff to  always CLOSE a dwg when walking away from your PC. Yes you can go the toilet or get a coffee.
