MemberX Posted February 6, 2012 Share Posted February 6, 2012 I wanted to know about Blocks which are predefined in tool pallets.If I want to change height of door in section drawing (aluminium door) as 2.1 m how can I change it. I used block editor but it changes by scale factor not exactly 2.1.How can I change it to 2.1 m? Also I wanted to now how to make tiles in hatch for drawing in section as it is not predefined in hatch.How can I make it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 6, 2012 Share Posted February 6, 2012 Are you referring to Dynamic Blocks? I wouldn't waste the time to create a hatch pattern for floor tiles shown in section. Use one of the hatch patterns that comes with AutoCAD. Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 7, 2012 Share Posted February 7, 2012 I moved your question to its own thread - please start a new thread for each new question. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 7, 2012 Share Posted February 7, 2012 The blocks in the tool palettes for doors are "Dynamic Blocks". Once inserted into the drawing use the blue arrows, etc to adjust the size etc. Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 7, 2012 Author Share Posted February 7, 2012 I am using those blue arrows but it is not reducing beyond 12 in height and width. I wanted to post my drawing but I don't know why I'm not getting option of images to be browse from computer it only available for http/ I have earlier posted my drawing through computer. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 7, 2012 Share Posted February 7, 2012 Select "Go Advanced" at lower right of Reply Box, then "Manage Attachments". Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 7, 2012 Author Share Posted February 7, 2012 here is.......... Even if reduce dimensions by scale it reduces in factor but not as 2.1 m or etc........ door.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 7, 2012 Share Posted February 7, 2012 Open in the Block Editor>Select "Window Height">Right-Click>Properties>Value Set>Dist Value List>Click in window and select the button [...] it will open a dialog box. Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 8, 2012 Author Share Posted February 8, 2012 I tried and it is all mishap....... only height of the door has been changed and rest of the things are as it is.Door handle is on its original position door.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 8, 2012 Share Posted February 8, 2012 You deleted everything. Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 8, 2012 Author Share Posted February 8, 2012 You deleted everything. NO ,there are so many constraint bars..I have hide all constraints .AS soon as I change height to 2 m Only the outer line of door changes to 2m.Rest of the thing remain on same position. Also I want to know where is section line which I required in plan to show the section name.line with arrows both side,I checked in pallet ..leder but it has only one direction arrow. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 8, 2012 Share Posted February 8, 2012 You do not require a section callout symbol with an arrow at both ends. As long as you have the "flag" (solid rectangular box) on one end and the arrow on the other it is fine. Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 20, 2012 Author Share Posted February 20, 2012 Still I am not getting how to edit this door for elevation.I want to change its width to 1.2m. It is showing so many pic point. door 1.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 20, 2012 Share Posted February 20, 2012 The file you posted is Imperial. Use the Metric Door and set the width options as shown above. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 20, 2012 Share Posted February 20, 2012 Here 1200mm = 1.2M Quote Link to comment Share on other sites More sharing options...
nestly Posted February 20, 2012 Share Posted February 20, 2012 Oh my goodness. The guy at Autodesk that created that dynamic block should be fired. It needs two stretch parameters and one flip, the rest is utter nonsense. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 20, 2012 Share Posted February 20, 2012 It is a bit overkill, though probably to demonstrate constraints. It is all irrevelent to the OPs question. Select "Width">Right-Click>Properties>Value Set>Dist Value List>Click in window and select the button [...] it will open a dialog box and adjust. P.S. That's why I create my own from scratch. Quote Link to comment Share on other sites More sharing options...
MemberX Posted February 23, 2012 Author Share Posted February 23, 2012 It is a bit overkill, though probably to demonstrate constraints. It is all irrevelent to the OPs question. Select "Width">Right-Click>Properties>Value Set>Dist Value List>Click in window and select the button [...] it will open a dialog box and adjust. P.S. That's why I create my own from scratch. there is no such option showing value set? in properties.Please halp Quote Link to comment Share on other sites More sharing options...
nestly Posted February 23, 2012 Share Posted February 23, 2012 Maybe this will help Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 23, 2012 Share Posted February 23, 2012 Select "Width">Right-Click>Properties>Value Set>Dist Value List>Click in window and select the button [...] it will open a dialog box and adjust. I have it here. Are you selecting the correct parameter? Quote Link to comment Share on other sites More sharing options...
