Denpac
Non Funtioning Layer Control Status Bar
Denpac
When I highlight any object in model space the layer control, color control or line type control does not change from the current layer status to the layer of the high lighted object if it is different. I am also not able through this layer control bar able to high light an object and use the fly out arrow to go into the layers and change this object to another desired layer for this object. I have never seen this function just not work before and can find no setting or preference that might not be turned on to make it function. Does anybody have any ideas to why it is not functioning?
Share this post
Link to post
MSasu
Please check that PICKFIRST system variable is set to 1.
Regards,
Mircea
Share this post
Link to post
Denpac
You are Awesome, Thanks!
Share this post
Link to post
MSasu
You are Welcome!
This is also accessible from Options -> Selection -> Selection modes -> Noun/verb selection; it is intended to resemble functionality of very old AutoCAD releases.
Regards,
Mircea
Share this post
Link to post
