bachrock Posted June 29, 2012 Share Posted June 29, 2012 When I export a drawing into pdf, the yellow color of the paint on the road changes to black. The export had worked fine until I c/p an image under my line-work. Anyone know why this is happening? Thanks. Quote Link to comment Share on other sites More sharing options...
jammie Posted June 29, 2012 Share Posted June 29, 2012 If you plot without the image does the same still happen? Do you use any CTB/STB files when plotting? Quote Link to comment Share on other sites More sharing options...
bachrock Posted June 29, 2012 Author Share Posted June 29, 2012 I detached the image from being an x-ref and the problem didn't go away. What are ctb/stb files? I haven't used either intentionally. Quote Link to comment Share on other sites More sharing options...
bachrock Posted June 29, 2012 Author Share Posted June 29, 2012 If you plot without the image does the same still happen? Do you use any CTB/STB files when plotting? Thanks for responding. I figured it out. For some reason the plot style was a black and white one. Quote Link to comment Share on other sites More sharing options...
