--Samuel--
[3DS MAX] Problem with plug-in
--Samuel--
Hello,
I downloaded student version of "Autodesk 3DS MAX 2013". I would like to install the Apex/PhysX plug-in but I can't. When I try to run the Apex plug-in, Autodesk write "Apex plug-in is not made for this version of the program".
So, I would like to know if Apex/PhyX is available for student version of Autodesk and which manipulations have I to do.
Bye,
Samuel.
Share this post
Link to post
niegrau
I also downloaded a plugin called Multitexture Map (http://www.cg-source.com/multitexture.php), there is no guide how to install it.
it's a *.dlt file ! and I have placed it in my plugins folder but it doesnt show up anything when I run the Max.
F1 PLS !
Share this post
Link to post
Cad64
Maybe this is why:
It's compatible with scanline, Vray, Brazil and FinalRender. MentalRay is currently not supported.
Try putting the .dlt file in the "stdplugs" folder and see if that works.
Share this post
Link to post
niegrau
got it solved, it was a map so I also placed it in Map folder and ran the software and noticed I should have looked for it in the Map tab of materials. I am not sure though where its actually running from, from Plugin folder or Map folder.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
