--Samuel-- Posted December 28, 2012 Share Posted December 28, 2012 Hello, I downloaded student version of "Autodesk 3DS MAX 2013". I would like to install the Apex/PhysX plug-in but I can't. When I try to run the Apex plug-in, Autodesk write "Apex plug-in is not made for this version of the program". So, I would like to know if Apex/PhyX is available for student version of Autodesk and which manipulations have I to do. Bye, Samuel. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 28, 2012 Share Posted December 28, 2012 It says on their webpage that the plug-in is compatible with 2013, so you might want to contact the developer and ask them why it's not working: https://developer.nvidia.com/physxapex-dcc-tools Quote Link to comment Share on other sites More sharing options...
niegrau Posted August 15, 2013 Share Posted August 15, 2013 I also downloaded a plugin called Multitexture Map (http://www.cg-source.com/multitexture.php), there is no guide how to install it. it's a *.dlt file ! and I have placed it in my plugins folder but it doesnt show up anything when I run the Max. F1 PLS ! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 16, 2013 Share Posted August 16, 2013 I have placed it in my plugins folder but it doesnt show up anything when I run the Max. Maybe this is why: It's compatible with scanline, Vray, Brazil and FinalRender. MentalRay is currently not supported. Try putting the .dlt file in the "stdplugs" folder and see if that works. Quote Link to comment Share on other sites More sharing options...
niegrau Posted August 16, 2013 Share Posted August 16, 2013 got it solved, it was a map so I also placed it in Map folder and ran the software and noticed I should have looked for it in the Map tab of materials. I am not sure though where its actually running from, from Plugin folder or Map folder. Quote Link to comment Share on other sites More sharing options...
