CyberAngel
Multileaders, Annotation, and Background Masks
CyberAngel
I have a survey xrefed into a site plan. In the survey there is a multileader that needs to appear at two different scales, so I made it annotative. The same multileader sits on top of a hatch (which is in the site plan), so I gave it a background mask.
At 1"=20', the larger scale, I can adjust the mask so that everything looks fine. When I switch to 1"=10', the other scale, the mask is too wide, and there's a big blank space. When I adjust the mask at 10 scale, the mask becomes too narrow for the 20 scale text, which wraps onto a second line. Apparently, I can make one version look nice, or the other, but not both.
Has anyone else seen this? Is there some magic fix?
Share this post
Link to post
JohnKSteb
*For AutoCAD 2017
Tad old of a post but I found a slight work-around. This fix does not allow you to have different organization of text per each scale (ie. 3 line text for 50 scale and 2 line text in 100 scale). You will have multileaders that 'look the same', just larger and smaller. The only thing this fixes is the wipe-out within the multileader extending past the smaller scale when adjusting to the larger scale.
Step 1: Adjust large scale multileader background mask by 'double clicking the extend text box arrows' or sliding them manually to where you want the larger scale background mask to be.
Step 2: Right click on the same label.
Step 3: Hover over "Annotative Object Scale" (may be in the middle of right click menu).
Step 4: Select "Synchronize Multiple-Scale Positions".
*This resets the labels to the exact organization of text and location per the large scale multileader you edited.
Step 5: Change to smaller scale and relocate the multileader per your needs.
*Note: Any changed to the text will most likely require these steps to be repeated for desired results.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
