jongor Posted July 15, 2013 Posted July 15, 2013 I'm trying to fillet the edge of a 3d solid guitar body and can't seem to make it happen. Any help, suggestions would be appreciated. Please see attached file.P Bass - Copy.dwg Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 How did you construct the outline of the guitar body in the first place? Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 (edited) You did not specify what radius you wanted on the fillet. I made a guess. Did you create the guitar body profile using a series of short line segments? Edited July 15, 2013 by ReMark Quote
JD Mather Posted July 15, 2013 Posted July 15, 2013 This is not a complex solid - it is a simple solid that could be simplified a lot more. Your sides are hundreds of planar faces. You should use tangent continuous curved to model something like this. Quote
jongor Posted July 15, 2013 Author Posted July 15, 2013 Complex to me... I used spline to create it and then converted that to a pline. Not sure what you mean by "tangent continuous", but I'll look into that. 1/2" radius. How'd you do that Remark? Quote
JD Mather Posted July 15, 2013 Posted July 15, 2013 Complex to me... I used spline to create it and then converted that to a pline. ... Why? You should have used the spline. Can you attach file with your original spline here? Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 I created a edge profile and extruded it around the path represented by your profile. I filled in the remainder of the body by offsetting the path 1/16" and extruding it. Finally, I unioned the two solids. Quote
jongor Posted July 15, 2013 Author Posted July 15, 2013 Tried this by exploding the 3dsolid and got a region, when trying to extrude a quarter-circle along that region I get "Cannot extrude along this path." I created a edge profile and extruded it around the path represented by your profile. I filled in the remainder of the body by offsetting the path 1/16" and extruding it. Finally, I unioned the two solids. Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 I exploded the region and used the PEDIT command to join all 400+ line segments/etc. which resulted in a closed polyline. That's what I used as my path. Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 Your guitar body profile (as path) and my edge profile shown circled in red. Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 The interior "filler". Then all you have to do is union the two solids together. Quote
ReMark Posted July 15, 2013 Posted July 15, 2013 No, I'm a machine. Next time follow JDM's advice and you'll have a much easier time of it. Quote
jongor Posted August 13, 2013 Author Posted August 13, 2013 I'm back at trying to do this, this time on a different body profile. Started with a spline this time and could get either method to work; extruding a profile along the edge or using the Filletedge 3d command. Using v.2014 now. j body.dwg Quote
ReMark Posted August 13, 2013 Posted August 13, 2013 Your profile is at fault. As you try to sweep or extrude it around the path it folds back on itself. Quote
ReMark Posted August 13, 2013 Posted August 13, 2013 I can extrude the guitar body but I can't fillet the edges completely. Odd. Quote
JD Mather Posted August 13, 2013 Posted August 13, 2013 (edited) Your spline is a mess. Forget about using splines - use tangent continuous arcs. Running a curvature analysis on your spline in another program shows many rough locations, but one in particular (at location of red arrow) (this one is difficult to see in AutoCAD - zoom way in at red circle in attached).j body_jd.dwg In general when creating a spline you want to use as few points as possible and let the software do the interpolation between points. It is a common misconception that more points = better curve. Also - I recommend that you work with the origin (0,0,0) at the approximate center of area of your geometry (if it were a symmetrical part - I would have the origin dead center). Edited August 13, 2013 by JD Mather Quote
