Hello :D
I am quite new to 3D autocad and have a problem with disappearing materials on the surface of my 3D models. I spend hours adding materials and colour to my drawings using the 'ctrl' select option on the surface of 3D objects, but when I save the drawing and go back to it another time the materials seem to disappear.
This wouldn't be a problem if the drawing weren't so large, but it is a pain in the ass to keep repeating the same process which takes and long time. Thank you :)
Link to post
Once you apply a texture/material to an object it should stay put unless you are moving files around to different folder locations or renaming folders while the drawing is closed.
Link to post
