Flatten Command
Andy Clarke
 Share
Hi
Sorry if this has already been discussed and a solution has been found, i have been searching but can't find a solution that has worked for me.
i am currently working using AutoCAD 2012 LT and work with OS Site Plans and on a number of plans i have had a problem where some of the objects (lines, circles, arcs) are on a different Z elevation and have problems with snap and trim ect.
one solution i come across was creating a new command ( C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99 ) which in most cases has worked for me but have noticed some objects have been removed from the drawing.
i hope someone will be able to help as this has stressed me out over the past few weeks
Thanks
Andy
  • Replies 38
  • ReMark
    3
  • Andy Clarke
    13
  • steven-g
    6
  • Tuns
    13
You said objects were removed (deleted?). Could they have been moved to another part of the drawing that is not in your field of view at the moment? Have you done a Zoom > All or a Zoom > Extents?
ahh sorry i understand now
just checked and it looks like when using this command it moves all the objects around and doesn't remove / delete them
do you know of away of making everything with Z=0 but keeping everything in place?
Thanks for the quick response
nah the objects that are moved seam to be arcs (all i have found up to now)
Tuns i just copy and paste and command that someone else had made which works for 99% of the drawing but moves objects around
I'm just stumped as to what the 1e99 is... I woulda thought something like this:
^C^Cmove;all;;0,0,0;;
would work better. Did the original writer say what 1e99 is?
This explanation was written by Donnie Gladfelter and posted at the CAD Geek website.
"What the above macro does is moves the objects you select above the maximum range for AutoCAD which results in those objects being placed at the maximum height of 1e99. Now that all of the selected objects share a common elevation, we can move them down –1e99, and the final elevation will be 0. Put another way, the functionality of the FLATTEN command has been emulated through a Macro."
Ohh, thanks ReMark. I've just never heard of 1e99 before so I didn't have a clue. As for the original problem, I don't experience any issues with this macro. Nothing has moved out of place and all the arcs are still unchanged.
just tried to edit and use this command but it never worked
thanks for all the help so far guys
has anyone else experienced problems using this macro or has another solution to this problem? i feel like pulling my hair out
its moving the arcs away from the positions they where originally in before moving the Z co-ordinate
i have just tried this same command with another drawing that i have been struggling with and it is doing the same moving objects out of there positions
Edited by Andy Clarke
Amedment
I will just post it here as you have your profile set up to not receive a private message, and I trust everyone here to not send any spam. It's irohan@gvtc.com
Don't trust anyone, their out to get you :) If you get an e-mail go back to your post and EDIT the e-mail out
That's the same thing essentially. How would it make any difference in the outcome?
Yeah that was my plan. :lol:
 Share
