deeelare Posted October 23, 2013 Share Posted October 23, 2013 Basically what I said in the title, and I can't change it to something that's easier to look at. I can change the color of individual faces if I use the "adjust" tool, beyond that the only way I can change it is if I go to the "Realistically Colored Model" and turn on "Ray Shading" which basically renders it. When I select the body and hover over the current color it says "As Application Surface Color". Thats what the first attached picture is. In the 2nd attached picture, it is clearly not light red. And its still transparent which is bugging me more. Sorry for the format of the attached pictures. Quote Link to comment Share on other sites More sharing options...
deeelare Posted October 23, 2013 Author Share Posted October 23, 2013 Any insight would really be helpful. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 23, 2013 Share Posted October 23, 2013 it's all surfaces i suspect, whereas in autocad it would be better as solids. orig a solidworks file i expect. Quote Link to comment Share on other sites More sharing options...
deeelare Posted October 24, 2013 Author Share Posted October 24, 2013 That is most likely the case. Now for the million dollar question, is there a way to fix this? Because I swear when I opened a similar file on Monday (upgraded RAM in my laptop on Tuesday) it came in as a solid. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 24, 2013 Share Posted October 24, 2013 i've no idea of a quick way to do it....awaiting someone else to reply as i would like to know too....i've given up trying to get 3D models from our various equipment manufacturers as this is almost invariably the case is it surfaces then? a long way round (but quicker than re-drawing) would be to copy it, paste it over itself but on a different layer (so you have a reference copy), then thicken the surfaces one by one and most likely much more work as well (i'm a novice 3D-er) Quote Link to comment Share on other sites More sharing options...
deeelare Posted October 24, 2013 Author Share Posted October 24, 2013 I've been playing with it more to figure out where the problem actually is. The .stp files I open work just fine, but the .igs files open up transparent. I asked our supplier to resend something in a .stp just to see if that was it. And then of course theres the option that they had a clear material/color applied and for some reason I can't change it across CAD packages (I think he uses solidedge). Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 24, 2013 Share Posted October 24, 2013 First of all, you have posted an image from Autodesk Inventor in the Autodesk AutoCAD forum. Wrong forum. Second, you will need to learn to use the Options when opening to get solid bodies rather than surface bodies. http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf Third, if you really only need the surfaces, you can right click on the node in the browser and unselect Translucent to make them appear solid. Quote Link to comment Share on other sites More sharing options...
deeelare Posted October 25, 2013 Author Share Posted October 25, 2013 that had been bugging me for a few days now, thank you very much. now I just have to go about fixing all the errors. Quote Link to comment Share on other sites More sharing options...
