cmscardoso Posted January 9, 2014 Share Posted January 9, 2014 Hello. Is it possible to import real time gps coordinates from Leica CS10 to Autocad? Is it a function in Autocad or will i need a third part software to accomplish that? Thanks for your help Quote Link to comment Share on other sites More sharing options...
Tuns Posted January 9, 2014 Share Posted January 9, 2014 Try doing what this person says here. I don't know if it will work for you but it is worth a shot. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 10, 2014 Share Posted January 10, 2014 Most data collectors can export a file as a xyz etc then you can import into Autocad easy as you have CIV3D, what did your original Leica service suggest they should know. I have a bit of knowledge about this and data collectors and survey instruments are being produced faster than Autocad interface hence go back to suppliers they normally do keep up. Quote Link to comment Share on other sites More sharing options...
