rgutierrez
AutoLISP - Adding linetype & lineweight
rgutierrez
Hi Guys,
I'm creating a layer setting pull down menu, in order to migrate my cad to revit I would like to define the linewight. So far I managed to create a command with a dashed line:
(defun c:layA-SEC-LIH-005()
(command "layer" "m" "A-SEC-LIH-005""C" "magenta" "" "l""DASHED2" "" "")
and another one with the lineweight
(command "layer" "m" "A-SEC-LIH-005""C" "magenta" "" "_LW" 0.10"" "")
but I haven't been able to create one that combines the 2 of them.. any help?
Cheers
Roberto
Share this post
Link to post
feargt
not sure why u couldn't get it to work, but after entering the linetype, instead of exiting the command continue by giving the lineweight.
(defun c:layA-SEC-LIH-005 ()
(command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "_LW" "0.10" "" "" "")
Share this post
Link to post
rgutierrez
Hi feargt,
Still doesn't work, I get a prompt asking to "Enter and option" [? Make Set New Rename ON OFF Color LType LWeight Transparency MAterial Plot Freeze Thaw LOck Unlock state Description rEconcile]:
Doesn't work for you if you use the pull down menu?
Share this post
Link to post
feargt
copy this direct on to the command line
and see does it work. it works for me.
if it does not work, press f2 and copy the text out so I can see where it stops working for you
Share this post
Link to post
rgutierrez
as requested.. btw.. thanks for helping
Command: (command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "_LW" "0.10" "" "" "")
_-layer
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _m
Enter name for new layer (becomes the current layer) : A-SEC-LIH-005 Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _C
New color [Truecolor/COlorbook] : magenta
Enter name list of layer(s) for color 6 (magenta) : Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _l
Enter loaded linetype name or [?] : DASHED2
Enter name list of layer(s) for linetype "DASHED2" : _LW
No matching layer names found.
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: 0.10
Invalid option keyword.
Share this post
Link to post
MSasu
Please pay attention that you missed to indicate the layer that will set the linetype for:
..."_L" "DASHED2" [color=red]"[font=Verdana][size=2]A-SEC-LIH-005"[/size][/font][/color]...
or
..."_L" "DASHED2" [color=red]"[font=Verdana][size=2]"[/size][/font][/color]...
Share this post
Link to post
rgutierrez
I will try tomorrow on another computer.. still doesn't work for me.. g nite
Command: (command "_-layer" "_m" "A-SEC-HIDDEN" "_C" "magenta" "" "_LT" "DASHED2" "_LW" "0.10" "" "" "")
_-layer
Current layer: "0"
Enter name for new layer (becomes the current layer) : A-SEC-HIDDEN Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _C
Enter name list of layer(s) for color 6 (magenta) : Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _LT
; error: Function cancelled
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: *Cancel*
Share this post
Link to post
feargt
Thanks MSasu for picking that up:
(command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "" "_LW" "0.10" "" "" "")
Share this post
Link to post
BIGAL
You may want to create a global lisp defun that just passes the variables using either entmake, command or VL eg (newlay "A- SEC-LIH-005" 5 "dashed2" 0.1) then you can use in any lisp you make.
(defun newlay (lay col lt thick / )
(command "_-layer" "_m" lay "_C" col "" "_l" lt "" "_LW" thick "" "" "")
Share this post
Link to post
Snownut
BIGAL, there seems to be some issues showing up in ACAD 2015 in using the "command" function in LISP. It seems AutoCad is slowly moving away from allowing this. The better way is to use the "vl-cmdf" function, this will require the (vl-load-com) at the beginning of the LISP.
Share this post
Link to post
rgutierrez
Hi Guys,
What a great help, I want to thanks you all of you.
Cheers feargr, MSasu, Bigal, Snownut!!
cheers
Share this post
Link to post
BIGAL
Snownut following up I would probably use entmake or vl-addlayer now, did not want to confuse op, thats interesting perhaps create a new post 2015 & lisp ?
Share this post
Link to post
rgutierrez
Hi Guys,
Again thanks for all your help.. I was having a chat with the IT guy and he introduced me to http://notepad-plus-plus.org/ great program to create the autoLISP
Cheers
Share this post
Link to post
rgutierrez
Sorry.. next time for sure... thanks
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
