tzframpton Posted January 23, 2007 Share Posted January 23, 2007 Lets see who all participates. Post up anything regarding your own personal setup in AutoCAD, mainly alterations to the PGP File, any Toolbars/Tool Palettes, or even post up screenshots of your Workspace. try to show true customization, refrain from the AutoCAD defaults, and even give reasons of why you chose the customized object/commands. I'll start.... Altered Keyboard Commands: 1st off, my right click is used as Enter. C - COPY CR - CIRCLE V - LINEAR DIM VV - QLEADER BB - BREAK MN - MIRRER Q - MATCH PROPERTIES REF - REFEDIT RER - RECTANGLE T - TRIM X - EXTEND XX - EXPLODE S - STRETCH D - DISTANCE I use these commands a lot, and so i've trimmed them down to one or two key commands, which makes my left hand stay put on one side of the keyboard. i can get going pretty fast sometimes... Quote Link to comment Share on other sites More sharing options...
Galingula Posted January 23, 2007 Share Posted January 23, 2007 HOTAS (Hands on Throttle and Stick) system from an F-16 Block D. It doesn't look like much, but there's over 200 button presses you can program. And the wheels can be used for zooms and pans and what not. Actually quite convenient once your used to it. The throttle has a thumb button on it that can be programmed to act as a mouse, but it's worse than a mouse nib on a laptop so I don't use it Quote Link to comment Share on other sites More sharing options...
Seann Posted January 23, 2007 Share Posted January 23, 2007 The only ones I know for sure are listed in this first list but thats cause I know I changed them. Other than that I probably have alot more but becuase they have been changed for so long I don't remember what they use to be Regular pgp: c=copy v=copy ci=circle d=distance r=rectange F4=xref manager Now the fun ones: Keytweak (program) F1=cancel +(numpad)='(foot symbol) *(numpad)=+ Quickkey lisp: xlv=vertical construction line xlh=horizontal construction line x45=45 degree construction line x135=135 degree construction line atr=_AECLINEWORKTRIM (AECTrim) ze-zoom extents 1fl=turns on first floor layers 2fl=turns on second floor layers 1fle=turns on first floor elec layers 2fle=turns on second floor elec layers xxx= purge all but layers, turn off image frame, zoom extents, close Thats all for me unless I edit this... http://webpages.charter.net/krumsick/ (keytweak homepage) (quickkey lisp attached from dotsoft.com) quickkey.zip Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 23, 2007 Author Share Posted January 23, 2007 nice, i like your style. this is the reason i posted this, because i think everyone can benefit by seeing how we all do things, and you never know, you might pick up a few tricks of the trade. ima check out that Keytweak. i have something similar at home, never thought about bringing it to work in conjunction with AutoCAD. EDIT: crap, i sure wish i could set the " symbol w/o using the shift key. i could have used both the ft & in symbols in the number pad for sure. oh well.... Quote Link to comment Share on other sites More sharing options...
lpseifert Posted January 23, 2007 Share Posted January 23, 2007 I have these in my acaddoc.lsp file, used for manipulating the UCS (defun c:ue ()(command "ucs" "e")) ;align UCS w/ entity (defun c:uw ()(command "ucs" "w")) (defun c:uv ()(command "ucs" "v")) ;align UCS w/ view (defun c:up ()(command "ucs" "p")) (defun c:u3 ()(command "ucs" "3")) (defun c:uo () ;in section view, sets the UCS at an elevation (Y value) (setq pt1 (getpoint "Pick reference point: ") el (RTOS(* -1.0(getreal "Enter elevation: "))) CO (STRCAT "0," el) ) (command "UCS" "o" pt1) (command "UCS" "o" CO) ) (defun C:RZ ()( COMMAND "UCS" "Z" "90")) ; rotates UCS 90 degrees Also for "joining" 2 plines/lines (defun C:J (/ FR) (setq FR (getvar "FILLETRAD")) (setvar "FILLETRAD" 0) (prompt "Select two lines to join: ") (command "FILLET" pause pause) (setvar "FILLETRAD" FR) (princ) ) Also this to see certain variables at a glance (setvar "modemacro" (strcat "TextStyle: $(getvar,textstyle) " "TextHeight: $(getvar,textsize) " "DimScale: $(getvar,dimscale) " "DimStyle: $(getvar,dimstyle) " "EdgeMode: $(getvar,edgemode) " "PickStyle: $(getvar,pickstyle) " ) ) Quote Link to comment Share on other sites More sharing options...
Seann Posted January 23, 2007 Share Posted January 23, 2007 We did this as a company to try and streamline the pgp files so everyone could work on anyone's computer. That lasted all of 5 minutes when we realized no one was ever going to use the same commands. If I can get a copy of our lead designers pgp I will post it. None of his commands are conventional and are all located on the left side of the keyboard and the 1st 4-5 keys ie. q,w,e,r,t and a,s,d,f and z,x,c. Very wierd but he drafts just as fast as we do. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted January 23, 2007 Share Posted January 23, 2007 All this is always loaded: Offsets by: 1 =1/8 316=3/16 2 =1/4 516=5/16 3 =3/8 716=7/16 4 =1/2 916=9/16 5 =5/8 1116=11/16 6 =3/4 1316=13/16 7 =7/8 1516=15/16 8 =1 16 =0.058 18 =0.046 20 =0.035 Rotate: 90 =90 180=180 270=270 others: ff = offset s = stretch d = Dtext dd = dimlinear da = dimaligned ddr= dimradius ddc= dimdiameter dg = dimangular dy = lengthen_dy zz = zoom_previous zs = zoom scale paper space zx = zoom e zoom s 0.95x x = extend qq = matchprop q = R14 ddchprop/ddmodify zzz= zoom p zoom w o = dimedit "o" ee = explode rr = fillet filletrad 1/16 h = xline horizontal v = xline vertical ds = dimscale rt = rotate ss = osmode=45 rtt= rotate special f = continuing fillet mm = toggle tilemode nn = toggle mspace/pspace sq = draws square df = dimfactor 10/254 ml = multileader rra= definite ray rc = non ortho rectangle jm = jump (offset+erase) ass= custom osmode setting mp = midpoint wr = dim text overwrite ew = erase node points ie = leader with ellipse head is = leader with "s" head iee= leader back to default pg = purge unused groups 36 = pedit/join uo = toggle ucsicon ttr= trim with rectangle fr = layfrz ls = psltscale to 0 arl= arc length dimension bn = split balloon ws = fillet welding symbol pl = perpendicular line brr= breakline ce= center line at midpoint between two parallel lines/plines cce= center cross to circles cr = center cross to rectangle dc = selected circles new diameter aa = draws angle iron tu = draws rectang tubing hss= hollow structural tubing cx = draws round bar break dss= copies and sets dimstyle + dimscale q1 = inserts text+numbered leader Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 23, 2007 Author Share Posted January 23, 2007 Holy cow you are definitely a keyboard guy. i like it.... Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted January 23, 2007 Share Posted January 23, 2007 My acaddoc.lsp..... (defun C:LL()(command "Dim" "Lea")) (defun C:VE()(command "DIM" "ver")) (defun C:HO()(command "DIM" "hor")) (defun C:AL()(command "DIM" "ALIGNED")) (defun C:AN()(command "DIM" "ang")) (defun C:DA()(command "DIM" "dia")) (defun C:OR()(command "DIM" "ord")) (defun C:RD()(command "DIM" "rad")) (defun C:RO()(command "DIM" "rot")) (defun C:AA()(command "AREA" "O")) (setq ocmd (getvar "cmdecho")) (setvar "cmdecho" 0) (command "undefine" "end") (setq scale (getvar "ltscale")) (setq scale (rtos scale)) (setq units "metres") (grtext -1 (strcat " Dwg Scale 1:"scale" "units" ")) (load "C:/AKCLISP/coffset") (load "C:/AKCLISP/sqoff") (load "C:/ACADLISP/MCR.LSP") (load "C:/AKCLISP/show.LSP") (load "C:/ACADLISP/chtext.LSP") (load "C:/AKCLISP/brgdist.LSP") (load "C:/AKCLISP/layoff.LSP") (load "C:/AKCLISP/txted.LSP") (setvar "cmdecho" ocmd) (setvar "lunits" 2) (setvar "luprec" 3) (setvar "aunits" 1) (setvar "auprec" 4) (setvar "angbase" 1.570796326795) (setvar "angdir" 1) (setvar "pdmode" 3) (setvar "pdsize" 0.5) (setvar "dimassoc" 0) (if (= (tblsearch "style" "ISO") nil) (command "STYLE" "ISO" "ISO" 0 1 20 "n" "n" "n")) (if (= (tblsearch "style" "I") nil) (command "STYLE" "I" "iso3098b" 0 1 0 "n" "n" "n")) (setvar "TEXTSTYLE" "I") My additions to acad.pgp.... A, *ARC AR, *ARRAY B, *BREAK BDY, *BOUNDARY BL, *BLOCK C, *CHANGE CH, *CHAMFER CI, *CIRCLE CO, *COLOR CP, *COPY D, *DTEXT DE, *DDEDIT DM, *MTEXT DO, *DONUT DR, *DRAWORDER DS, *DIMSCALE DV, *DIVIDE DX, *DXFIN DXO, *DXFOUT E, *ERASE EE, *END EL, *ELLIPSE EP, *EXPLODE EX, *EXTEND F, *FILLET FI, *FILTER H, *HATCH HA, *BHATCH I, *-INSERT IB, *DDINSERT L, *LINE LC, *DDLMODES LE, *LENGTHEN LI, *LIST LN, *LINETYPE LS, *LTSCALE LT, *LIMITS M, *MOVE ME, *MEASURE MI, *MIRROR ML, *MLINE MLE, *MLEDIT MS, *MSPACE N, *OPEN O, *OFFSET OO, *OSNAP P, *PEDIT P3, *3DPOLY PG, *POLYGON PL, *PLINE PP, *PAN PR, *PROPERTIES PS, *PSPACE PT, *POINT PU, *PURGE QS, *QSELECT R, *ROTATE RE, *REDRAW RG, *RECTANG RN, *REGEN S, *STRETCH SC, *SCALE SO, *SOLID SP, *SPELL SS, *STRETCH ST, *STYLE T, *TRIM TX, *TEXTSCR V, *VMAX W, *WBLOCK Z, *ZOOM I also have all my function keys assigned to various osnap modes. My acad drawing is basic and uncluttered...just the things I use a lot. I work with my right hand on the mouse and my left hand on the keyboard......it suits me and it's FAST. My mouse wheel is pan & zoom (in/out), left button = PICK, right button = ENTER. Quote Link to comment Share on other sites More sharing options...
erona Posted January 24, 2007 Share Posted January 24, 2007 I hate to cut & paste my PGP file. Below are the only ones I can remember. PGP: dd = distance cr = ai_molc (make selected object's layer current) q = qnew sa = saveas ref = refedit ae = attedit mcr = mocoro ma = matchprop LISP: 0 = set to Layer 0 1 = set selected object's color to 1 2 = set selected object's color to 2, and so on... up to 255 / = set current to layer to 0 * = set current to color to ByLayer - = set current to linetype to ByLayer -- = set to hidden linetype -*- = set to center linetype ** = set to dot linetype *1 = set current color to 1 *2 = set current color to 2, and so on... -1 = set current linetype to hidden -2 = set current linetype to center -3 = set current linetype to phantom, and so on... gw = global polyline width ll = linetype scale pj = polyline join ` = set object's color to ByLayer `` = set object's linetype to ByLayer romans = set current text style to Standard (romans.shx, 0.8 width factor) arial = set current text style to Arial (Arial.ttf, 1.0 width factor) Quote Link to comment Share on other sites More sharing options...
scubadoo Posted January 24, 2007 Share Posted January 24, 2007 reading this makes me realise how little i know about the 2% of CAD that i know how to use! Quote Link to comment Share on other sites More sharing options...
Designer Posted January 24, 2007 Share Posted January 24, 2007 Here are mine: 3P, *3DPOLY A, *ARC AA, *AREA AD, *ATTDISP AE, *ATTEDIT AR, *ARRAY -AR, *-ARRAY AT, *ATTDEF -AT, *-ATTDEF ATE, *ATTEDIT -ATE, *-ATTEDIT ATT, *ATTDEF -ATT, *-ATTDEF ATTE, *-ATTEDIT AV, *DSVIEWER AX, *ATTEXT BL, *BLOCK -B, *-BLOCK BA, *BASE BH, *BHATCH BM, *BLIPMODE BO, *BOUNDARY -BO, *-BOUNDARY B, *BREAK CR, *CIRCLE CE, *ADCENTER -CH, *PROPERTIES CH, *CHANGE CHA, *CHAMFER CP, *COPYLINK C, *COPY CL, *COLOR COLOUR, *COLOR DS, *DIMSTYLE D1, *DIM1 DAD, *ATTDEF DAL, *DIMALIGNED DAN, *DIMANGULAR DBA, *DIMBASELINE DC, *ADCENTER DCE, *DIMCENTER DCENTER, *ADCENTER DCO, *DIMCONTINUE DDA, *DIMDISASSOCIATE DDI, *DIMDIAMETER DED, *DIMEDIT DI, *DIST DIV, *DIVIDE DL, *DLINE DLI, *DIMLINEAR DM, *DIMSTYLE DO, *OPEN DN, *DONUT DOR, *DIMORDINATE DOV, *DIMOVERRIDE DR, *DRAWORDER DRA, *DIMRADIUS DRE, *DIMREASSOCIATE DS, *DSETTINGS DST, *DIMSTYLE D, *TEXT DV, *DVIEW DX, *SAVEAS E, *ERASE DD, *DDEDIT EL, *ELLIPSE ES, *EXTEND EX, *EXPLODE EXIT, *QUIT EXP, *EXPORT F, *FILLET G, *PKFSTGROUP -G, *-PKFSTGROUP GR, *OPTIONS GROUP, *PKFSTGROUP -GROUP, *-PKFSTGROUP H, *HATCH -H, *BHATCH HE, *HATCHEDIT HI, *HIDE I, *-INSERT -I, *INSERT IM, *IMAGE -IM, *-IMAGE IMP, *IMPORT IN, *INTERSECT IO, *INSERTOBJ IS, *ISOPLANE L, *LINE LA, *LAYER -LA, *-LAYER LE, *QLEADER LEN, *LENGTHEN LI, *LIST LINEWEIGHT, *LWEIGHT LM, *LIMITS LO, *-LAYOUT LS, *LIST LT, *LINETYPE -LT, *-LINETYPE LTYPE, *LINETYPE -LTYPE, *-LINETYPE LTS, *LTSCALE LW, *LWEIGHT M, *MOVE MA, *MATCHPROP ME, *MEASURE MI, *MIRROR MO, *PROPERTIES MR, *MREDO MS, *MSPACE MT, *MTEXT -MT, *-MTEXT MV, *MVIEW N, *NEW O, *OFFSET OF, *OFFSET OO, *OOPS OP, *OPTIONS OR, *ORTHO OS, *OSNAP -OS, *-OSNAP P, *PAN -P, *-PAN PA, *PASTESPEC PE, *PEDIT PL, *PLINE PO, *POINT POL, *POLYGON PP, *PLOT PR, *PROPERTIES PRCLOSE, *PROPERTIESCLOSE PROPS, *PROPERTIES PRE, *PREVIEW PRINT, *PLOT PS, *PSPACE PT, *POINT PTW, *PUBLISHTOWEB PU, *PURGE -PU, *-PURGE QT, *QTEXT R, *REDRAW RC, *REVCLOUD RD, *REVDATE RE, *REGEN REA, *REGENALL REC, *RECTANG REG, *REGION REN, *RENAME -REN, *-RENAME REV, *REVDATE RI, *REINIT RT, *ROTATE S, *STRETCH SA, *SAVE SC, *SCALE SCR, *SCRIPT SE, *DSETTINGS SET, *SETVAR SH, *SHADEMODE SN, *SNAP SO, *SOLID SP, *SPELL SPL, *SPLINE SPE, *SPLINEDIT ST, *STYLE SU, *SUBTRACT TE, *MTEXT -T, *-MTEXT TA, *TABLET TH, *THICKNESS TI, *TILEMODE TM, *TILEMODE TO, *TOOLBAR TOL, *TOLERANCE TP, *TOOLPALETTES T, *TRIM TX, *TEXT UC, *UCSMAN UN, *UNITS -UN, *-UNITS UNI, *UNION V, *VIEW -V, *-VIEW VL, *VPLAYER VP, *DDVPOINT -VP, *VPOINT VS, *VSLIDE W, *WBLOCK -W, *-WBLOCK WI, *WMFIN WO, *WMFOUT X, *EXPLODE XA, *XATTACH XB, *XBIND -XB, *-XBIND XL, *XLINE XR, *XREF -XR, *-XREF Z, *ZOOM Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 24, 2007 Share Posted January 24, 2007 All my piping & instrumentation symbols, pipe labels, sizes and layer setting commands are mapped to my digitizer. One pick is all it takes. That's 225 custom commands. My 16 button puck is also custom programmed. Quote Link to comment Share on other sites More sharing options...
dbroada Posted January 24, 2007 Share Posted January 24, 2007 Mine is mostly out of the box. I have C = copy ci = circle d = dtext and a button to print with default settings I am a command line person so only have a couple of toolbars showing - mostly for our "special" routines such as export all text off one layer and our revison cloud routine. In general I don't use that many commands anyway. I double click a lot though. Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 24, 2007 Share Posted January 24, 2007 me like this topic - I have real trouble helping my co-workers on their computors, they are mostly button-people wheras I have grown fond of short commands. The only real change I have made is D for DIST anc C for COPY. And more recently MVS for M View Setup. But just so you know, I will steal some of the lists posted here and apply them to my ACAD! :-) Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 24, 2007 Share Posted January 24, 2007 PGP file is right out of the box, we use "acaddoc.lsp" to define any overrides to that. "acad.lsp" is used to set support file search paths, PC3 path, CTB path, load company menu, etc. This way if somebody monkeys with something, a restart of AutoCAD fixes it. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 24, 2007 Share Posted January 24, 2007 (load "C:/AKCLISP/coffset") (load "C:/AKCLISP/sqoff") (load "C:/ACADLISP/MCR.LSP") (load "C:/AKCLISP/show.LSP") (load "C:/ACADLISP/chtext.LSP") (load "C:/AKCLISP/brgdist.LSP") (load "C:/AKCLISP/layoff.LSP") (load "C:/AKCLISP/txted.LSP") Alan, you may already know this..... just thought I would post this for the benefit of others. ...if you add one line like this: (setq mypath "C:\\AKCLISP\\") ...then revise your (load) statements to something like this: (load (strcat mypath "txted.lsp")) ...then your "acaddoc.lsp" file is portable as long as you change the "mypath" line. Another option of course is just to add "C:\\AKCLISP" to your support file search path. Another alternative instead of the (load) statement is to use (autoload). (autoload "txted" '("txted")) ...which doesn't actually load the lisp file until the function is called. If you never call the function, the file is never loaded. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 24, 2007 Share Posted January 24, 2007 I see - so you want to find out the "weirdos" among the forum. I am sorry to disappoint, but having been mad keen with r10, and changed just about everything in the pgp file, I realised that I would be having to redo all the changes with each update. So I made the effort to learn the AutoCAD default command abbreviations, so I can use any version unless some weirdos have been at it! I have Osnaps on the "F" keys which again is a bit easier now with the Accelerator keys, instead of having to delve into ANSI.SYS. I have three pet lisp shorties which I seem to use frquently - SCL (set current layer), CTCL (change to currrent layer) and CHOL (change object layer). The less the mouse has to travel, the quicker it is to draw. So keyboard entry for commands means that the crosshairs stay where the action is, instead of having to race around finding and then picking buttons. Quote Link to comment Share on other sites More sharing options...
Seann Posted January 24, 2007 Share Posted January 24, 2007 I have noticed however that the newer the version of autocad you learn on the more buttons and menu's the drafter uses. I use about 50/50 but the younger drafters clutter their screens with buttons while the old farts have a 19" monitor and 18.75" of drafting space. Quote Link to comment Share on other sites More sharing options...
dbroada Posted January 24, 2007 Share Posted January 24, 2007 I have noticed however that the newer the version of autocad you learn on the more buttons and menu's the drafter uses. I use about 50/50 but the younger drafters clutter their screens with buttons while the old farts have a 19" monitor and 18.75" of drafting space.YEP, I have one row of buttons an no command line, the boss has no buttons and a 2 line command line showing. Everybody else has a postage stamp screen and takes forever to get to a simple command. When we upgraded to 2006 we had a trainer in (not sure he knew any more than us) and it was fun beating him to do the commands, him navigating numerous levels of menu and us just typing the command. Quote Link to comment Share on other sites More sharing options...
