tzframpton Posted February 26, 2010 Author Posted February 26, 2010 Here's an update on my PGP file actually: C, *COPY CR,*CIRCLE D, *DIST Q, *MATCHPROP V, *DIMLINEAR VV,*QLEADER MN,*MIRROR XX,*EXPLODE X, *EXTEND T, *TRIM TT,*TEXT P, *PLINE LK,*LAYFRZ R, *ROTATE REF,*REFEDIT WW,*LAYMCUR PP,*PEDIT RER,*RECTANGLE BB,*BREAK DSS,*DIMSCALE REV,*REVCLOUD QQ,*LAYCUR QS,*QSELECT FF,*FILTER VA,*DIMALIGNED DD,*DDEDIT DA,*DUCTADD PRP,*PRESSPULL Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 `, *QLEADER 1, *LayerCurrent 2, *LayerSet 3, *LayerOff 4, *LayerFreeze 5, *MLEADER 6, *LayerMatchSet 7, *LIST 8, *LayerP 9, *EXTRIM 0, *MATH MM, *MATCHPROP BP, *BPOLY OF, *LAYOFF FE, *LAYFRZ BC, *BSCALE CV, *COPY CH, *CHPROP D, *DIST IN, *-INSERT LA, *-LAYER LAY, *CLASSICLAYER R, *ROTATE GL, *GLUE DS, *DIMSTYLE REF, *REFEDIT QS, *QSAVE RE, *REGENALL LG, *LENGTHEN JT, *JUSTIFYTEXT DS, *DIMSTYLE SH, *AECLINEWORKSHRINKWRAP ww, *wipeout P, *PLINE CN, *NCOPY OK, *OVERKILL QA, *QLATTACH DC, *DIMCONTINUE AA, *ALAN T2, *TXT2MTXT FA, *FLATTEN XR, *CLASSICXREF IM, *CLASSICIMAGE V, *VPLAYER Q, *QSELECT OP, *OOPS TTF, *TEXTTOFRONT QD, *QDIM B, *BREAK ;APPLICATIONS IE, START IEXPLORE, 1,, WORD, START WINWORD, 1,, EMAIL, START OUTLOOK, 1,, ;C3D COMMANDS 3J, *AeccJoinFeatures AM, *AIMLEADEREDITADD CG, *CGLIST CA, *CGANG NG, *LABELDLGGENERALNOTE RL, *LABELREVERSEBEARING FP, *LABELFLIP RB, *LABELREVERSEBEARING CEO, *CURVEFROMENDOFOBJECT RCC, *REVERSEORCOMPOUND Some of these awe erroneous, but I've just never removed them. Quote
tzframpton Posted February 26, 2010 Author Posted February 26, 2010 Alan, what the hell is "glue"? Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Alan, what the hell is "glue"? It's an old (circa 1990) lisp routine that would allow you to join 2 lines or text into one. Quote
erratic Posted February 26, 2010 Posted February 26, 2010 LoLHow do you guys find these old threads? (Not that there's anything wrong with it). just to clarify - I was searching for a solution to another problem I was having - troubleshooting/ upgrading some tools - and found it that way... and since I obviously had a few cents to add - I did. Quote
erratic Posted February 26, 2010 Posted February 26, 2010 It's an old (circa 1990) lisp routine that would allow you to join 2 lines or text into one. that's a good question... "glue" ??? but if that's what it is/ was - I have commands/ routines that do just that! Quote
rkent Posted February 26, 2010 Posted February 26, 2010 I don't modify the PGP file, I use three main lisp files, one for autoloading lisp files, one for quick keys that mimick the pgp, and one for setting variables. They could be one file but it just makes it easier for me to edit shorter files. Sample of the acaddoc.lsp below. (AUTOLOAD "C:/ACAD/LSP/CCC" '("CCC" "CCL")) ;changes entities to current layer with pick, (AUTOLOAD "C:/ACAD/LSP/COPR" '("COPR" "CPR")) ;copy and rotate entities (AUTOLOAD "C:/ACAD/LSP/CR" '("CR")) ;crosshair rotate by picking or entering angle (AUTOLOAD "C:/ACAD/LSP/CX" '("CX" "S")) ;changes entities or sets to layer of selected entity (AUTOLOAD "C:/ACAD/LSP/DVW" '("CS" "DVW")) ;use this instead of DVIEW TWIST, pick object, CS to return to UCS and PLAN world (AUTOLOAD "C:/ACAD/LSP/FRZX" '("FRZX")) ;freeze layers including xrefs by pick (AUTOLOAD "C:/ACAD/LSP/IE" '("IE")) ;inserts a block by pick,sets scale by pick (AUTOLOAD "C:/ACAD/ISOVIEWS" '("ISOCAD"));generates isometrics (AUTOLOAD "C:/ACAD/LSP/LK" '("LC")) ;locks all but current (AUTOLOAD "C:/ACAD/LSP/LK" '("LK" "LKA" "LKX")) ;locks layer by picking, ulk to unlock by pick (AUTOLOAD "C:/ACAD/LSP/LX" '("LX")) ;extend a line by pointing or entering length (AUTOLOAD "C:/ACAD/LSP/ME" '("ME")) ;Multi Edit of text and attributes (AUTOLOAD "C:/ACAD/LSP/MEND" '("MEND")) ;mends two lines to one (AUTOLOAD "C:/ACAD/LLL/Text and attrib/MergeMText" '("MMT")) ;merge two mtext entities together (AUTOLOAD "C:/ACAD/LSP/MVR" '("MVR")) ;moves and rotates entity (AUTOLOAD "C:/ACAD/LSP/MVW" '("MVW")) ;make view window in viewports through paper space (AUTOLOAD "C:/ACAD/LSP/NEWORK" '("NEWORK"));changes polyline to wide, dashed line for new (AUTOLOAD "C:/ACAD/LSP/OFF" '("OFF")) ;freezes layers by pick, thaws with ON command (AUTOLOAD "C:/ACAD/LSP/OM" '("OM")) ;offset a line on current layer specified length (AUTOLOAD "C:/ACAD/LSP/O5" '("O5")) ;offset divides the value by half Sample of qkeys.lsp ;***************** ABBREVIATED KEYSTROKE COMMANDS ***************************** (acad-push-dbmod) (vmon) (DEFUN C:00() (SETVAR "CMDECHO" 1)(COMMAND ".layer" "s" "0" "")) (DEFUN C:2 () (SETVAR "CMDECHO" 1)(COMMAND ".FILLET" "R" "2" ".fillet")) (DEFUN C:25() (SETVAR "CMDECHO" 1)(COMMAND ".FILLET" "R" "2.5" ".FILLET")) (DEFUN C:3 () (SETVAR "CMDECHO" 1)(COMMAND ".FILLET" "R" "3" ".FILLET")) (DEFUN C:35() (SETVAR "CMDECHO" 1)(COMMAND ".FILLET" "R" "3.5" ".FILLET")) (DEFUN C:2D () (SETVAR "CMDECHO" 0)(COMMAND ".VSCURRENT" "2D")(PRIN1)) (DEFUN C:3D () (SETVAR "CMDECHO" 0)(COMMAND ".3DPOLY")(PRIN1)) (DEFUN C:33 () (SETVAR "CMDECHO" 0)(COMMAND ".3DFORBIT")(PRIN1)) (DEFUN C:333 () (SETVAR "CMDECHO" 0)(COMMAND ".3DFORBIT")(PRIN1)) (DEFUN C:AU () (SETVAR "CMDECHO" 0)(COMMAND ".AUDIT" "Y")(PRIN1)) (DEFUN C:AUC() (SETVAR "CMDECHO" 0)(COMMAND "ZOOM" "E" "layer" "s" "0" "" ".AUDIT" "Y" ".PURGE" "ALL" "*" "N" ".PURGE" "R" "*" "N" "LAYER" "S" "0" "" ".QSAVE" "CLOSE")(PRIN1)) (DEFUN C:AUQ() (SETVAR "CMDECHO" 0)(setq SPQdwg (getvar "savename"))(COMMAND "ZOOM" "E" ".AUDIT" "Y" ".PURGE" "ALL" "*" "N" ".PURGE" "R" "*" "N" "LAYER" "S" "0" "" "SAVE" SPQdwg)(PRIN1)) (DEFUN C:BI () (SETVAR "CMDECHO" 0)(COMMAND ".BREAK" PAUSE "F")(PRIN1)) (DEFUN C:BP () (SETVAR "CMDECHO" 0)(COMMAND ".BPOLY")(PRIN1)) (DEFUN C:CB () (SETVAR "CMDECHO" 0)(COMMAND ".COPYBASE")(PRIN1)) (DEFUN C:CC () (SETVAR "CMDECHO" 0)(COMMAND ".COPY")(PRIN1)) (DEFUN C:CD () (SETVAR "CMDECHO" 0)(COMMAND ".CIRCLE" PAUSE "D")(PRIN1)) (DEFUN C:CH () (SETVAR "CMDECHO" 0)(COMMAND ".CHANGE")(PRIN1)) (DEFUN C:CL () (SETVAR "CMDECHO" 0)(COMMAND ".CLOSE")(PRIN1)) (DEFUN C:CM () (SETVAR "CMDECHO" 0)(COMMAND ".CHAMFER")(PRIN1)) (DEFUN C:CPS () (SETVAR "CMDECHO" 0)(COMMAND ".CONVERTPSTYLES" "CONVERT.STB")(PRIN1)) (DEFUN C:CPST () (SETVAR "CMDECHO" 0)(COMMAND ".CONVERTPSTYLES")(PRIN1)) (DEFUN C:CON () (SETVAR "CMDECHO" 0)(COMMAND ".VSCURRENT" "CONCEPTUAL")(PRIN1)) (DEFUN C:CTB () (SETVAR "CMDECHO" 0)(COMMAND ".CONVERTCTB")(PRIN1)) (DEFUN C:C5 () (SETVAR "CMDECHO" 0)(COMMAND ".CURSORSIZE" "5")(PRIN1)) (DEFUN C:C7 () (SETVAR "CMDECHO" 0)(COMMAND ".CURSORSIZE" "75")(PRIN1)) (DEFUN C:CZ () (SETVAR "CMDECHO" 0)(setq CZ (getvar "cursorsize")) (if (> cz 80) (setvar "CURSORSIZE" 7)(setvar "CURSORSIZE" 100))(PRIN1)) ; DIMS ************ (DEFUN C:DA () (SETVAR "CMDECHO" 0)(COMMAND ".DIMALIGNED")(PRIN1)) (DEFUN C:DAA () (SETVAR "CMDECHO" 0)(COMMAND ".DIMANGULAR")(PRIN1)) (DEFUN C:DDI () (SETVAR "CMDECHO" 0)(COMMAND ".DIMDIAMETER")(PRIN1)) (DEFUN C:DL () (SETVAR "CMDECHO" 0)(COMMAND ".DIMLINEAR")(PRIN1)) (DEFUN C:DU () (SETVAR "CMDECHO" 0)(COMMAND ".DIM1" "UPDATE")(PRIN1)) ; DIMS ************ (DEFUN C:DI () (SETVAR "CMDECHO" 0)(COMMAND ".DIST")(PRIN1)) ;(DEFUN C:DR () (SETVAR "CMDECHO" 0)(COMMAND ".LEADER")(PRIN1)) (DEFUN C:DX () (SETVAR "CMDECHO" 0)(COMMAND ".TEXT")(PRIN1)) (DEFUN C:DWG (/ DW PRE DWPRE)(SETQ DW (GETVAR "DWGNAME")PRE (GETVAR "DWGPREFIX") DWPRE (STRCAT PRE DW))(PRINC DWPRE)(PRIN1)) Sample of settings.lsp ;3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ;---------------------- (command "UCSICON" "all" "ON" "INTERSECTIONCOLOR" "7" "INTERSECTIONDISPLAY" "ON") ;;;;;;;;;;;;;;;;;;;;;;; ;DIMENSIONS DIMENSIONS DIMENSIONS DIMENSIONS DIMENSIONS DIMENSIONS ;--------------------- ;(command ; "dimassoc" "2" "dimasz" "0.1" "dimatfit" "3" "dimcen" "-0.1" "dimclrd" "1" ; "dimclre" "1" "dimexe" "0.0625" "dimexo" "0.0625" "dimfrac" "1" "dimgap" "0.04" ; "dimlunit" "4" "dimtad" "1" "dimtih" "off" "dimtfac" "0.85" "dimtix" "off" ; "dimtmove""1" "DIMTOH" "OFF" "dimtsz" "0.000" "dimtxt" "0.1" "dimzin" "3" ;;;;;;;;;;;;;;;;;;;;;;; ;TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT ;--------------------- (command "DTEXTED" "2" "MTJIGSTRING" "RKENT" "MIRRTEXT" "0" "TEXTFILL" "1" "TSPACETYPE" "2" "CENTERMT" "1") ;;;;;;;;;;;;;;;;;;;;;;; ;PLINE PLINE PLINE PLINE PLINE PLINE PLINE PLINE PLINE PLINE ;--------------------- (command "OffSetGapType" "0" "peditaccept" "1" "PLINEWID" "0" "PLINETYPE" "2") ;;;;;;;;;;;;;;;;;;;;; In the CUI I have the Osnaps defined to FUNCTION KEYS F1=ENDP F2=PERP F3=NEAR F4=MID F5=QUAD F6=CENTER F7=APPINT F9=SNAP F11=NODE F12=INS Quote
alanjt Posted February 26, 2010 Posted February 26, 2010 Here's a nice stack of macros, etc. http://www.cadtutor.net/forum/showthread.php?t=40347 Quote
Susan-Skye Posted October 19, 2010 Posted October 19, 2010 All of this sounds fascinating, but does anyone know whether or not it could be applied to AutoCAD LT 2009? I'd love to be able to easily customize all my menus and have them auto-load on start-up, but it's harder with that stupid Windows-style ribbon in the top. Quote
designerstuart Posted October 28, 2010 Posted October 28, 2010 it seems mine are rather odd - i do use letters that make sense like c copy p pline etc but i also use easy to reach ones like q layer manager qq xref manager qqq ucs manager qqqq layer states d dimlinear dd dimaligned ddd dimradius dddd dimcontinuous and also some other logic like u new ucs uu save usc w world ucs ww previous ucs x xline vertical xx xline horizontal but i have a friend who only uses the number pad - he's real fast. uses stuff like: 3 rectangle 8 xref 5 line 55 pline 51 pedit 2 copy 22 offset but all of the commands are numerical. utterly crazy, but effective. Quote
troggarf Posted October 31, 2010 Posted October 31, 2010 First Post here on CadTutor... MENUBAR TASKBAR Right Click layer dropdown list and "ADD TO QUICK ACCESS TOOLBAR" so that whatever ribbon/tab I'm in, I can change layers. Uncheck "Use Icons" in the Status Bar instead of guessing what they mean (or hovering over the icon to read it) SS - SELECTSIMILAR I also plug in a USB Numeric pad and put it to the LEFT of my keyboard so that I don't have to take my hand off of the mouse to input Numbers Quote
eldin Posted November 1, 2010 Posted November 1, 2010 Wow! I love this tread! I use my keybord for mostly everything. I use LT, so (unfortunately) I cant use LISP for more functions, but here is my acad.pgp: Q, *LINE QQ, *PLINE QQQ, *SPLINE w, *WIPEOUT WW, *OPEN E, *EXTEND EE, *ERASE R, *OFFSET RR, *ROTATE FF, *MIRROR SS, *BREAK 1, *LINE 2, *COPY 22, *MOVE 3, *PEDIT D, *DIMLINEAR DA, *DIMALIGNED DC, *DIMCONTINUE DE, *DIMTEDIT DR, *DIMRADIUS DD, *DIST VP, *-VPORTS DV, *DIVIDE T, *TRIM TE, *MTEXT HH, *HATCHTOBACK ML, *MLEADER (Almost) All of my commands are on the left side of my keybord, so selecting a function takes the least time.. only for typing measures I use the numpad (right side), which I do with my right hand (mouse hand) Quote
BIGAL Posted November 2, 2010 Posted November 2, 2010 Following on from Seant re screen menu's this is a very usefull tool for inputing predefined variables its like a keyboard with pre defined answers that are returned to the command, you can open go to next list then close as required rather than leaving it on the screen. The other nice thing is that you display in the menu text such as how many bricks? 1 2 3 this will return 230 460 690 etc very good when working with standard objects. You can use lisp to pop the menu open and return a value and close again. Nice thing is various lisps can access the same menu no need for hard coding. Quote
designerstuart Posted November 2, 2010 Posted November 2, 2010 i also plug in a usb numeric pad and put it to the left of my keyboard so that i don't have to take my hand off of the mouse to input numbers that is a good idea Quote
Squirltech Posted November 8, 2010 Posted November 8, 2010 I use: C-Copy CR-Circle PP-Pedit LL-Lengthen O-Offset D-Distance REF-Refedit Q-Quick Leader Left mouse button, select and right mouse button, enter. I was helping a guy here just the other day who typed in "E X P L O D E". Another thing I've done is create a tool button to restore my OSnap settings. I also trimmed down my .pgp file to contain only the commands I actually use or remember using. I haven't gone as far as to locate all key in commands to one side of the keyboard but I'm all about shortcuts when it comes to running CAD. Thanks to everyone for their input. *EDIT - I also set my mouse buttons to be CTRL and SHIFT. My properties and Layer Manager are always open as well and my Xref dialog autohides. I use dual 19" monitors so that helps. Quote
Raithneach Posted November 10, 2010 Posted November 10, 2010 It drives everyone else crazy but it speeds up my work....Have customization, will use... 111, *OSNAPZ 2D, *PS_DETCENTER 3DD, *3DDWFPUBLISH AA, *ALIGN CHA, *CHAMFER C, *COPY D, *DIST A, *DIMALIGNED q, *DIMANGULAR B, *DIMBASELINE X, *DIMCONTINUE DI, *DIST Z, *DIMLINEAR RR, *DIMRADIUS E, *PS_solid_extrude EX, *EXTEND F, *FILLET HH, *HATCH L, *LINE LL, *QLEADER LI, *LIST W, *MOVE M, *MATCHPROP MI, *MIRROR O, *OFFSET PE, *PEDIT PR, *PROPERTIES H, *PS_HIDE RE, *REGEN SQ, *RECTANG REE, *Ps_Regen R, *ROTATE S, *STRETCH SC, *SCALE SS, *OSNAP T, *MTEXT TR, *TRIM XX, *EXPLODE ZZ, *ZOOM Quote
