Missing Plot Styles - poof it's gone!
AmandaK
I was working in LT 2014, everything running just fine since we got this version. Then last night I went to plot to a pdf using "monochrome" like I always have, and now it says "monochrome.ctb (missing)". It's the weirdest thing since it worked literally 5 mins before hand.
I went thru the autocad help, but nothing seems to help and the "plot styles" menu selection is greyed out.
I looked thru the folders and all the .ctb files seem to be in the correct spot.
Any idea why this would happen, and how to fix it?
TIA.
Link to post
Check Options > Plot and Publish tab > Plot Style Table Settings (lower right hand corner). Is the default set to use color dependent plot styles?
Link to post
