khoshravan Posted July 17, 2015 Author Share Posted July 17, 2015 Try SLW210's advice first. If you have no luck then try the Lenovo site. Thanks. Autodesk site is not available from my country. But I can access Lenovo site. In Lenovo site, I find the following: AMD Video Driver for Windows 8 (64-bit) - Lenovo G410, G510 Version: 12.100.1 4.6000 Date: 7/9/2013 Now trying to download it. http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g510-notebook? Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 17, 2015 Author Share Posted July 17, 2015 Without updating, I figured out that my graphic card is up-to-date. I check the date and version og mine with the one in Lenovo site. Therefore I didn't download it. Any other comment is very welcomed. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 17, 2015 Share Posted July 17, 2015 Is hardware acceleration enabled? What other programs are running in the background? Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 18, 2015 Author Share Posted July 18, 2015 Is hardware acceleration enabled? What other programs are running in the background? Thanks for your continuous support. Following site says: http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/how-to-increase-hardware-acceleration-in-windows-8/10aa6528-85ba-468d-bdcb-3afea0535a52?auth=1 In the Advanced Settings window, if Troubleshooting tab is present, then the graphics card supports hardware acceleration. I don't have this tab. so my com don't support HA Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 19, 2015 Share Posted July 19, 2015 I'm not sure if AutoCAD will recognize that a GPU doesn't support hardware acceleration. ReMark was referring to the setting in AutoCAD. If your GPU does not support it, you may need to turn it off as I think it is on by default. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 19, 2015 Author Share Posted July 19, 2015 I'm not sure if AutoCAD will recognize that a GPU doesn't support hardware acceleration. ReMark was referring to the setting in AutoCAD. If your GPU does not support it, you may need to turn it off as I think it is on by default. Dear Rob and ReMark Thanks for both your input I was able to resolve the issue. I didn't know that Remark is referring to turning off HA in AutoCAD. I thought it is related to OS After reading Rob's post, I went to Tools/Option, system tab and first option is Hardware Acceleration. I turned it off and it solved my problem. Although I didn't figure out what caused the problem and what is its relation to HA, but I am happy that problem has gone away. Thanks for both of you. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 19, 2015 Author Share Posted July 19, 2015 By default the HA was on and I turned it off Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 19, 2015 Author Share Posted July 19, 2015 When I try to upload an image, they appear twice.How can I solve this issue? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 20, 2015 Share Posted July 20, 2015 This is a frequent problem, ReMark has experienced it repeatedly, as have other forum members. I don't believe that there has been an explanation nor solution found yet. As annoying as it is, just go ahead and post, hopefully somebody will be able to figure out why it happens, and devise a work around. Quote Link to comment Share on other sites More sharing options...
