jamos Posted April 18, 2017 Posted April 18, 2017 Good day all your clever people. I have installed autocad 2018 and experience a problem that , in 3d modeling, it crashes the moment i try to switch from any view to REALISTIC view. All other 3d views is no problem, but when i click on the realistic view icon, it makes a fatal crash. Also it does the same when i try to open the materials browser. This is a fresh install and i have tried to repair the install. Everthing else works perfect. The file i am working on was created on my previous version, autocad 2014. Also, i am using a new laptop now. i7 version 7 processor, 16gig ram, nvidea gtx 950 2gig graphics, direct xi. I have tried now for hours on the autodesk site forums to look for a solution or a service pack or something, no succes. Can anyone please help if you had the same problem and managed to solve it??? Sorry if i posted this in the wrong spot, I'm not sure as to where it should go Quote
Cad64 Posted April 18, 2017 Posted April 18, 2017 I wouldn't expect any service packs for a while. 2018 was only released about 3 or 4 weeks ago. Have you run the 3DCONFIG command and tried enabling or disabling Hardware Acceleration? Quote
ReMark Posted April 18, 2017 Posted April 18, 2017 I've been unable to find anyone else using AutoCAD 2018 reporting a similar problem when switching visual styles. Sounds like ot is unique to your set up. I'd follow the advice given by Cad64 and see what happens. Quote
jamos Posted April 18, 2017 Author Posted April 18, 2017 Thank you cad64 and remark. I have made a note to try to switch the hardware deceleration off. I have read a posting on someone with the similar problem in 2017 and he also suggested that. I'll try that fisrt thing tomorrow Any suggestions on how i should set up the 3d configuration? I suposse one can change some settings once in there? Quote
ReMark Posted April 18, 2017 Posted April 18, 2017 From what I can recall there isn't much you can change. It's either enabled or disabled. Quote
jamos Posted April 18, 2017 Author Posted April 18, 2017 Good. I will see if i can fix this tomorrow. Thank you for your kind assistance Quote
rkent Posted April 18, 2017 Posted April 18, 2017 2018.0.2 update is available now. Not saying it will fix the OP's problem, just that they already released an update. Quote
Cad64 Posted April 18, 2017 Posted April 18, 2017 2018.0.2 update is available now. Not saying it will fix the OP's problem, just that they already released an update. There's an update already? They were probably already working on it before they released the program. Quote
Dana W Posted April 18, 2017 Posted April 18, 2017 How bout that. My 2018 LT is only three days old and already gets to be updated. I don't see it out there yet for LT but sure it's coming. Of course the first update I got after installing 2015 LT was to fix some bugs in Chinese character handling. To the OP, I doubt if a 2 gig video processor is going to run easy on realistic. Check your device manager in control panel and see if your NVidia card is even enabled and set as the default video processor. When I bought a laptop a couple years ago with a NVidia gt650 installed, it took me a couple of weeks to realize it was defaulting to the HD4000 on the motherboard rather than the add on card. Quote
Dadgad Posted April 19, 2017 Posted April 19, 2017 (edited) From what I can recall there isn't much you can change. It's either enabled or disabled. If you access it from OPTIONS you can choose to manually configure it, at least that is the case in 2013 Vanilla. Starting on the SYSTEM tab, as shown in the screenshot. Hardware Acceleration can be on, but with some non-essential and power zapping functionality turned off. Adaptive Degradation is also a useful tool, if you feel your FPS is lagging, perhaps under the weight of sofftware functionality which is routinely not utilized. Adjusting Dynamic tesselation, to reduce memory drain, or turning it off, may also help. Edited April 19, 2017 by Dadgad Quote
jamos Posted April 19, 2017 Author Posted April 19, 2017 Thanx. I'll make sure it is enabled, didnt even think to check that...... Quote
Dadgad Posted April 19, 2017 Posted April 19, 2017 Hardware Acceleration is a double edged sword. Sounds like a good thing, and it can be, but such is not ALWAYS the case. There are lots of threads wherein knowledgable forum members, trying to help others, make suggestions along the lines of... If your Hardware Acceleration is switched off, enable it. If your Hardware Acceleration is ENABLED, turn it off. But having it turned on, but tweaked, so as to only enable those functions which are important to you, at any given moment, while minimizing negative impact, might just be the ticket. Dana's suggestion in post #10 is certainly worth checking out. Quote
SLW210 Posted April 19, 2017 Posted April 19, 2017 I moved your thread to the AutoCAD Bugs, Error Messages & Quirks Forum. Quote
SLW210 Posted April 19, 2017 Posted April 19, 2017 2018 is pretty new, did you check to see if there was a newer Graphics Card Driver Available from either Autodesk or Nvidia? Quote
rkent Posted April 19, 2017 Posted April 19, 2017 How bout that. My 2018 LT is only three days old and already gets to be updated. I don't see it out there yet for LT but sure it's coming. Of course the first update I got after installing 2015 LT was to fix some bugs in Chinese character handling. To the OP, I doubt if a 2 gig video processor is going to run easy on realistic. Check your device manager in control panel and see if your NVidia card is even enabled and set as the default video processor. When I bought a laptop a couple years ago with a NVidia gt650 installed, it took me a couple of weeks to realize it was defaulting to the HD4000 on the motherboard rather than the add on card. It is there, was available the same day as plain AutoCAD. https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Update-2018-02-available-for-AutoCAD-and-AutoCAD-LT.html Quote
Cad64 Posted April 19, 2017 Posted April 19, 2017 Looks like that Update 2018.0.2 needs to be installed by EVERYONE using 2018, otherwise their subscription will expire on June 1st. I wonder if they have sent out emails to let everybody know? Note: The 2018.0.2 update fixes a defect that would otherwise have caused the product subscription to expire on June 1, 2017 with a pre-release product error message. Be sure to install this update before that time to avoid subscription expiration. Quote
Dana W Posted April 19, 2017 Posted April 19, 2017 It is there, was available the same day as plain AutoCAD.https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Update-2018-02-available-for-AutoCAD-and-AutoCAD-LT.html Thanks, had not actually looked this week. ima go get it tonight. Wouldn't want to expire. Funny, at work we installed 2016 two years ago, and it expired in a month, even though we had paid in advance for 2 seats for a year. No notice, it just came up with the typical expired message just like a trial version does. Quote
halam Posted April 19, 2017 Posted April 19, 2017 Looks like that Update 2018.0.2 needs to be installed by EVERYONE using 2018, otherwise their subscription will expire on June 1st. I wonder if they have sent out emails to let everybody know? Any consequences for employees not knowing if they are 'on subscription' or any other form of contact? Quote
Cad64 Posted April 19, 2017 Posted April 19, 2017 Any consequences for employees not knowing if they are 'on subscription' or any other form of contact? Yes, they are all fired! Can you imagine if you came into work early on June 2nd to try and get some extra work done and then find out that Autocad won't open because the subscription is expired? Then you have to sit there for a few hours waiting for your CAD manager to arrive to get the problem sorted out. Yeah, thanks Autodesk. Quote
