ryankevin15
MLeader LSP not working
ryankevin15
Hello,
My manager made this LSP file for me and it doesn't work and we are both not sure why. Seems correct to me.
How it works: Creates the E-Anno-Note layer, otherwise makes it current, then creates an MLeader (to avoid creating leaders on incorrect layers).
(DEFUN C:NN ()
 (setvar "cmdecho" 0)
 (if (not (tblsearch "layer" "E-Anno-Note"))
   (command "-layer" "n" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
 (command "-layer" "m" "E-Anno-Note")
 (COMMAND "mleader")
Thanks!
Share this post
Link to post
Tharwat
Hi,
Need to add double quotes.
(command "-layer" "m" "E-Anno-Note" [color="magenta"][b]""[/b][/color])
Share this post
Link to post
ryankevin15
Hi,
(DEFUN C:mm ()
 command "-layer" "m" "E-Anno-Note" "")
 (COMMAND "mleader" "")
Still doesn't work when I run this...
Share this post
Link to post
Tharwat
You have omitted one bracket before the command call.
Share this post
Link to post
BIGAL
The -layer N is new, M is make new and make current, so does two steps.
So a slight variation
   (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" "")
   (command "-layer" "s" "E-Anno-Note" "")
also
   (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
   (setvar 'clayer "E-Anno-Note")
Share this post
Link to post
ryankevin15
Thanks for the help. This works now.
Could I make it also adjust the settings of the MLeader before it is drawn so that it will make the right alignment in the middle of the bottom row of text (this is a standard CAD thing that doesn't seem to be the default).
Thanks in advance.
Share this post
Link to post
ronjonp
Thanks in advance.
You could add something like this to the code:
(if (setq e (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))
 (progn (setq o (vlax-ename->vla-object
	   (cdr (assoc -1 (dictsearch (cdr (assoc -1 e)) (getvar 'cmleaderstyle))))
 (vla-put-textleftattachmenttype o 5)
 (vla-put-textrightattachmenttype o 5)
Share this post
Link to post
ryankevin15
Anyone know of any way I can import an MLeader style right before it starts drawing the MLeader?
Share this post
Link to post
ronjonp
Make a template and insert it if the mleaderstyle does not exist.
Share this post
Link to post
ryankevin15
I will try this with my manager and see if it works. Thanks!
Share this post
Link to post
ryankevin15
I was able to adjust the leader in the style, but will this code locate the style on my computer or how does that work?
Share this post
Link to post
ronjonp
It just changes the current mleader style ( which might actually be bad practice ) ... I would check if the style exists and set it current, else import ( or create with code ) and set current.
Share this post
Link to post
ryankevin15
Here is my updated code. Can anyone add some code so that it will import the MLeaderStyle before making the MLeader? Our style is called "Ascent"
(DEFUN C:mm ()
 (command "-layer" "m" "E-Anno-Note" "")
 (command "-layer" "c" "2" "E-Anno-Note" "")
 (command "-layer" "ps" "style_1" "E-Anno-Note" "")
 (COMMAND "mleader")
Share this post
Link to post
ryankevin15
Actually, it looks like we need to create this MLeader style every time and set it to current if it doesn't exist...
Share this post
Link to post
