Ish
REQUIRE LISP FOR TO GET POLYLINE TEXT VALUE AT REQUIRE OFFSET
Ish
DEAR SIR,
I NEED A LISP TO GET OFFSET AND LEVEL OF POLYLINE.
VERTICAL SCALE AND OFFSET MAY BE DIFFERENT.  SOMETIME OFFSET REQUIRE 2,5,7.5 AND SAME VERTICAL SCALE 1:5, 1:10.
IN ATTACH CAD FILE THERE IS 2 SITUATION NEED SOLUTION.
**FOR MORE DETAIL SEE IMAGE.
ROAD SK.dwg
Edited by Ish
MODIFY
Share this post
Link to post
dlanorh
3 hours ago, Ish said:
DEAR SIR,
It is impossible to test a lisp on an image.:thumbsup:
The image also doesn't tell me the text size, text style, polyline details or layer details etc...
Share this post
Link to post
Ish
 NOW IN CAD FILE YOU WILL SEE 2 SITUATION.
ROAD SK.dwg
Edited by Ish
MODIFY
Share this post
Link to post
dlanorh
OK, is the baseline (level datum) always arbitrary (lines Y coord is not the level)?
Option 1 has a baseline in option 2 this is a closed polyline which makes intersection points more difficult.
Will try to have a workable solution on monday.
  • Thanks 1
Share this post
Link to post
Ish
YES BOSS the baseline (level datum) always arbitrary (lines Y coord is not the level)
YES - Option 1 has a baseline
option 2 this is a closed polyline - NO THAT IS ALSO  baseline (level datum). I JUST DRAW A RECTANGLE SIR, ASSUME THAT IS ALSO BASE LINE.
Share this post
Link to post
dlanorh
Please look at attached drawing extract of situation 2. I am assuming it was just for reference and not correct?
situation_2.dwg
Share this post
Link to post
dlanorh
OK. Can I also switch the positions of offsets and levels so it is consistent with Option 1?
Share this post
Link to post
BIGAL
This is my SRL.lsp and reports level from pick point, a good starting point. At moment only Rl is worked out and for vertical scale. The offset could be done using same method. You pick the datum text, enter vertical scale, a datum point and pt of interest it updates an existing text.
SurfaceRL.lsp
Edited by BIGAL
Share this post
Link to post
Ish
100% correct sir, becoz i write roughly, but you make correct one. blue polyline was a 3dpoly i convert that, thats why z elevation is there. assume no z elevation.
calculation must be based on datum and center line.
thanks
Share this post
Link to post
Ish
CAN  UPLOAD SOME IMAGE  OR SCREEN SHOT,  HOW TO USE THIS LISP ,
Share this post
Link to post
BIGAL
The program I wrote is used where you need a RL of a point based on a datum level it updates a existing text. Its about the method of how to do.
How are you making the pline, datum, and text rectang ? Why would you not just add to that procedure.
As I have said before purchase a commercial product it will do everything you want rather than the repeated questions of the next thing you want for free, hopefully your getting paid for this work.
I am happy to do it but will have a fee. I am an independent contractor I had to buy my CAD software if I wanted to even offer free stuff here.
Edited by BIGAL
Share this post
Link to post
Ish
hello sir
Share this post
Link to post
dlanorh
Sorry, very busy at the moment work wise. I should have something soon, just trying to iron out a few bugs.
Share this post
Link to post
dlanorh
OK. Apologies for the time it has taken, but I had a "rush" job to complete that took up most of my time this past week.
Attached is the Lisp for Option 1, along with a question for option 2 which I've labelled as "3".
The drawing contains the maximum detail needed for the section, as the rest will be added by the lisp. The polyline will be automatically converted to run from left to right. The datum line will be converted from a polyline to a line (if required) and again set to run left to right. I needed it to do this to simplify the offseting.
This produces the two "SOLUTIONS" with the given offsets. The 0.0 and 10.0 (or end of polyline) are added automatically so don't have to be entered. If you don't require all this let me know.
Command to run (once loaded) is ODL.
You will be asked for the vertical exaggeration. Default is 1 (1:1). If the exaggeration is 1:5 you only need to enter 5
You will be asked to select the polyline, then to select the Datum Line, followed by the Datum Line Level (default 0.000), and finally the offset distances (default 0.000). As mentioned above the lisp knows the 0.000 offset (start of polyline) and the end of polyline offset; these are added automatically, so you only need to enter the intermediate ones. This is all collected in a while loop and the offset distances are added to a list. Once all the intermediate offsets are added return the default (0.000) to exit the loop and produce the solution.
I will attempt to added Solution 2 to this once I know all the requirements.
ROAD-SK-TEST.dwg ODL.lsp
Share this post
Link to post
Ish
thanks for support sir
it solve my problem 70%
i have some suggestion for you plz consider.
see below
Situation -1
1.       Enter Vertical Scale Exaggeration (eg 1:5 = 5) <1> :
               Here we have 2 Vertical Scale 1:1 & 1:5    please add 1:10 also.
2.       Enter Datum Line Level <0.000> :
Here add pick text option
Pick Datum Level Or Type Datum Level <0.000>:
3.       Enter First Offset Distance or (0.0 to Exit) <0.000> :
Here don’t make fix offset 0.0 (by default is ok), may be some case I have first offset 10 or other value.
Here please add next line for fix interval
Enter the Interval (0.0 to Exit) <0.000> :
Example:
Enter First Offset Distance or (0.0 to Exit) <0.000> : 10
Enter the Interval (0.0 to Exit) <0.000> :2
If I type interval 2 automatically upto end of pline
Offset show 12, 14, 16, 18, 20 ….
Situation -2
 Cross section
I need value at pline vertex. As you show in solution that is perfect for me.
I need exactly like that.
waiting for your good reply.
Thanks
Share this post
Link to post
dlanorh
This is not a selection. If the vertical exageration is 1:5 you enter 5 if it is 1:10 you enter 10. The default is 1:1 <1>.
If you want this as selection list thats not a problem. There is no problem with the rest.
Share this post
Link to post
Ish
no sir , I dont want selection list . I thought this is for 1:1 and 1:5 ONLY, NOW 1 CHECK . THIS IS FOR ANY VERTICAL SCALE, GOOD. NO. 1
whAT ABOUT FIX INTERVAL:  (POINT NO 3.) AND CROSS SECTION
** PLZ ADD A CODE FOR LAYER .      OFFSET, LEVEL AND GRID LINE MUST HAVE A SEPARATE LAYER..
THANKS
Edited by Ish
MODIFY COMMENTS
Share this post
Link to post
dlanorh
Too late :P I've already changed it. I suppose I'll have to change it back now.
Interval already sorted. Cross Section with centreline is still in production.
Layer Name and colour for each? I can't code what I don't know
Can you standardise the datum level as just a number 30 instead of DAT:30 as this would make it easier to re-use code? I am also using the height of this text for rest of the text to be inserted in that section.
And is it possible to make the centreline a line instead of a polyline as this requires less verticality checking?
Edited by dlanorh
clarity
Share this post
Link to post
Ish
thanks sir, it means now i will type only one time and i will get value accordingly. good
for cross section i will wait sir. no problem
Yes, Sir you can use number 30 instead of DAT:30, i write it for more information.
Yes.  You can  make the centreline a line instead of a polyline.
it will be something like this
(setq clr (getvar 'clayer))
  (cond ( (null (tblsearch "LAYER"  "Coor Text")) (command "-layer" "_M" "Coor Text" "_C" 7 "" "")) (t (setvar 'clayer "Coor Text")))
thanks for good support.
plz upload update ODL.LSP
Share this post
Link to post
dlanorh
Attached is unfinished, but working updated lisp (Option 1 only). Everything will now be put into layer  "Coor Text".
ODL.lsp
Share this post
Link to post
